ZPOST
Go Back   ZPOST > BMW Z4 Roadster and Coupe > General BMW Z4 Forum
  TireRack
      08-17-2023, 10:22 PM   #1
rho123
28
Drives: 2013 128i - sold, 2007 Z4C
bad ignition switch?
recently car won't start sometimes. Lights are on but won't turn over. I turn off the ignition and try again or twice it starts. It sounds like a bad ignition switch. Youtube shows it's easy to replace and recommended a cheap Ebay replacement. Any one else run across this problem? or buy one of Ebay?
Got I.C.E.?
      08-17-2023, 10:26 PM   #2
Our03z4
Drives: 2008 BMW Z4 3.0si Coupe,
If you car is a manual transmission it could just need the clutch stop adjusted at the petal.
      08-18-2023, 12:09 AM   #3
XMetal
XMetal's Avatar
Drives: Anything
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
I came across this issue on my e53 X5. I decided to go with OE BMW part just because I don't want to get stranded with an unknown eBay part. The OE part isn't too expensive that peace of mind is worth it to me - Just my opinion, of course.
      08-18-2023, 09:47 AM   #4
14Down
78
Drives: BMW M340i, X3 M40i, M Roadster
rho123,
Does it happen when cold or only after the car is hot? If only after the car has been run, it could be the starter. Happened to my '06 M Roadster. According to a former BMW tech, because of the location of the starter, the windings expand quite a bit with the heat and over time may wear out their coating. The car starts fine when cold, but when hot, the windings expand and rub against the case causing it to short out. Mine would start after it cooled down some. Replaced the starter and no problems since (though starter is a pain to replace because of location).
Good luck.
      08-18-2023, 01:25 PM   #5
CJW2OO4
CJW2OO4's Avatar
Drives: E86M,M2,F13 E86&E85M,E86,2E46
I just went thru this same issue. I started by swapping out the battery, then the ignition switch, followed by the starter.
The starter was the culprit. Even after all this I sometimes need to push the clutch down hard to get the car to start.
      08-18-2023, 04:18 PM   #6
rho123
28
Ok, I’ll swap out the ignition switch first and then work my way down to starter next if needed.
Got I.C.E.?
      08-18-2023, 04:20 PM   #7
rho123
28
Originally Posted by 14Down View Post
rho123,
Good luck.
Didn’t notice if it happens in hot weather but I’ll make note of it next time it happens
Got I.C.E.?
      04-14-2024, 04:25 AM   #8
Jlo89
Drives: BMW Z4
Update?
Oye mate,
Did you ever figure out the issue?
      04-16-2024, 05:51 AM   #9
rho123
28
Originally Posted by Jlo89 View Post
Oye mate,
Yes, I changed the ignition switch and fixed it.
Got I.C.E.?
zpost
