Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N55 Turbo Engine Tuning and Exhaust Modifications - 335i Tuning > Major Codes!!!!
      02-22-2017, 08:38 PM   #1
D's Bimmer
235
Drives: 2016 340 Xi
Major Codes!!!!
Driving home from work this afternoon the car felt off. I have been getting this odd "feedback" from my MT at high rpm's. Kind of like a dull vibration.
Anyways, on the way home, my car went into limp mode, code city....
Intermittently, I have had the following two codes over the past few weeks:
2CF4 - Oxygen sensor before catalytic converter, dynamics:Slow Response
2D2F - Oxygen sensors before catalytic converter:Multiple fault
Both are O2 related codes.
I pulled an initial log this morning for an initial map for a custom tune that Ken is doing for me and this is what it looked like....
http://www.datazap.me/u/diggler70/lo...=0&data=4-5-15
Then this afternoon...
2EE0 - Combustion misfiring, several cylinders:Fuel injection deactivation
2EE2 - Combustion misfiring, several cylinders:damaging exhaust gas after start sequence
2EF4 - Combustion misfiring, cylinder 6:Fuel injection deactivation
2EF6 - Combustion misfiring, cylinder 6
2EFE - Misfire, several cylinders
2F04 - Misfire, cylinder 6
Reduced power, rough idle and chugging pulse from the engine. Could this be caused by a faulty O2 sensor? I had one of them replaced a couple of months ago. I think that there are two in my car if I understand correctly.
Thanks,
2016 340Xi M-Sport Sedan | BMW M Performance Exhaust l APEX SM-10 Wheels
      02-22-2017, 09:46 PM   #2
Boosted2000Si
Boosted2000Si's Avatar
26
Drives: None
Google the codes and post what they are
      02-23-2017, 08:01 AM   #3
bahn
Drives: 2007 E92 335i 6MT
Thanks,
Probably two unrelated issues. That log looks good except for the timing corrections. How old are the spark plugs, what kind are they and what are they gapped to?
Did these codes appear during a WOT pull or were they during normal driving?
These cars will deactivate the injectors on a cylinder when repeated misfires occur until the car is turned off and turned back on.
Answer the above questions and we can go from there.
      02-23-2017, 08:12 AM   #4
D's Bimmer
235
Drives: 2016 340 Xi
The plugs are new about 2 months ago. I believe they are gapped to 0.20 but would need to confirm.
These codes initially appeared on a WOT. They still appear and the car still runs rough and half engine light. Even after repeated restarts and sitting over night.
      02-23-2017, 08:23 AM   #5
bahn
Any chance of getting a log of it happening? I'm wondering if your rail pressure is dipping and causing misfires during a WOT pull.
      02-23-2017, 08:26 AM   #6
D's Bimmer
235
Drives: 2016 340 Xi
I am at the shop with it now hoping to find out more. Will log as soon as I can but I definitely can't WOT. I went back to the Stock O Map last night as well. Problem still persists.
      02-23-2017, 08:43 AM   #7
bbnks2
1207
Drives: 135i N55
Lol, replace the o2 sensor? Seems obvious but idk...
      02-23-2017, 11:40 AM   #8
D's Bimmer
235
Drives: 2016 340 Xi
It looks like the brand new Bosch spark plug in cylinder 6 had an issue. The insulation sleeve inside the plug became dislodged and would completely cover the tip. We swapped cylinder 1 and 6 and the misfire issue followed it. Just gonna replace the one new plug for now and see if that fixes everything.
      04-17-2019, 08:57 PM   #9
kievlanine@gmail.com
Drives: E90 335xi
I am having similar issues, have you had a resolution for this?
      10-12-2021, 07:45 PM   #10
Nolan2221
Drives: BMW 335i n55
What ended up fixing this? I’m having the exact same fault code and problem.
      11-12-2021, 06:59 AM   #11
D's Bimmer
235
Drives: 2016 340 Xi
After additional testing it appears to be a problem with my fuel injectors. A pricey repair is ahead it seems. $3k US
      11-13-2021, 09:13 PM   #12
jlegelis
jlegelis's Avatar
Drives: 2013 E92 N55 MT MSport
You don't mention miles, but 'fuel injectors' on a 2016 seems suspect given 'misfires'.
What about coils, wires, etc and all other ignition related components? Stick with the stock tune until you get it figured out...
      03-07-2024, 04:31 AM   #13
wrevilo
24
Drives: 2010 E92 335i N55 6MT
I know I am dragging up an old thread, but my car has been running noticeably poorly over the past couple of days and I too have received errors 2CF4 and shadow code 2D2F.
Luckily, my car is going into the garage this weekend to replace the high pressure fuel sensor and a couple of gaskets around the turbo where I have air leaks, among other works.
I have ordered a replacement lambda sensor 11787596924 (Bosch 0258027019) in case this is needed. I'll report back - hopefully this doesn't turn into needing to replace injectors!
/edit/ annoyingly the replacement lambda sensor I ordered with overnight delivery hasn't arrived! /edit/
      04-04-2024, 05:05 PM   #14
ilikemycar
Drives: 2011 E90 335i
Same issue here dude. Is it fixed now?
      04-05-2024, 05:46 AM   #15
wrevilo
24
I don't actually have my car back yet! The job snowballed somewhat to include the tensioner, belt and pulleys on the front of the engine and now front drop links. I'll report back when I have the car.
      Yesterday, 02:21 PM   #16
EnzoKhan
Drives: 335xi M Sport e92
2011 BMW 335xi  [0.00]
Do you have any updates?
I replaced my upstream O2 sensor about a year ago with BMW OEM sensor but suddenly started getting the exact same codes. Car drives just fine though.
2011 e92 with 130k miles.
