Next Level Auto Brokers
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Suspension | Brakes | Chassis
      08-30-2023, 02:59 PM   #1
Rahul718
144
Drives: F82 Comp 6mt
Question on rear tire-to-strut mount clearance
Hey all,
Just need a sanity check. I recently moved to all seasons on my ZCP, so even though I retained the same OEM size, it turned out that the tire width is quite a bit wider than the Pilot Super Sports it replaced. As a result, it is rubbing on the outside in the fronts. I had a scare where I thought the tires were rubbing on the insides with the strut perch, but I have about a 1 finger gap clearance.
My question is, how does the rear inner clearance look? I'm not too familiar with the rear suspension and the path of travel of the tire relative to the strut. Does it look like I could be at risk of rubbing the inside against any of the strut components? I don't think so and the clearance looks plentiful, with the tire not being in the path of anything, but just wanted to confirm with you guys here.
Tire and strut mount are both circled.
Thanks
      09-01-2023, 11:56 AM   #2
Rahul718
144
bump
      01-23-2024, 11:18 AM   #3
Rahul718
144
4 month bump. Anyone?
      01-23-2024, 11:27 AM   #4
jfritz27
jfritz27's Avatar
1107
Drives: 2018 F80 CS
That's plenty of room to the strut
Rahul718144.00
      01-23-2024, 04:46 PM   #5
Rahul718
144
Nice, thanks for that feedback! Looked adequate to me but I wasn’t sure how much the wheel tilts inwards when going over bumps, dips, etc
      01-25-2024, 09:00 AM   #6
M3SQRD
M3SQRD's Avatar
2164
The rear tire camber does increase with compression but it’s still only a small fraction of an inch. The rear shock also sits further inboard relative to the front strut’s position. So, as jfritz27 stated above, you have plenty of clearance between the rear shock and rear tire tread/sidewall.
Rahul718144.00
      01-26-2024, 10:46 AM   #7
Rahul718
144
Thanks for the confirmation
      03-23-2024, 04:17 PM   #8
Rahul718
144
M3SQRD
Got around to taking a picture with measurement as a reference point. It’s showing 2.75” from the inner wheel lip to strut, so assume minus 1” for additional tire width for safe measure. That’s 1.75” clearance with the suspension loaded. I’m curious… would any amount of wheel alignments (OE spec, nothing custom) drastically change this rear clearance, or would it more or less maintain this much of clearance?
Thanks
      03-23-2024, 07:05 PM   #9
M3SQRD
M3SQRD's Avatar
2164
M3SQRD
Thanks
Camber is the rear alignment setting that will alter wheel clearance the most but it’s still relatively small. If the tire diameter is ~27” then a 1 deg increase in negative camber would move the top of the wheel inward ~0.235”.
      03-23-2024, 07:37 PM   #10
Rahul718
144
M3SQRD thanks for the reply.
I didn’t know there was a camber to mm conversion. Good to know though!
Really appreciate your knowledge in this area!
f80post
