2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Cosmetic Maintenance (Wash/Wax/Detailing/Exterior Restoration & Repairs) Passenger Headlight Assembly Out
      11-27-2023, 06:34 PM   #1
ralbert1998
Drives: M235
Angry Passenger Headlight Assembly Out
Hi all, I have a 2015 BMW M235i xdrive, and I got the daytime lamp malfunction. After taking a look, I see that there is a ton of moisture in my passenger side headlight while the drivers side is dry. The passenger assembly itself is completely out, both angel eyes and the top LED strip, while my headlights and high beams do still work when turned on (so does my yellow indicator bulb). My question is, has the moisture caused a short/damage to my headlight? Will I need to replace the whole headlight or potentially just the module? Will I need to do any coding for this replacement/could I just swap in a used part?
Thanks in advance!
      11-27-2023, 09:49 PM   #2
Dom147
Drives: 2014 BMW 228i, 2017 BMW M240i
2017 BMW M240i  [0.00]
afaik no coding is necessary with the replacement of the assembly. Not sure about the modules.
      12-05-2023, 12:23 PM   #3
Dom147
Using a code reader will give a very detailed response as to what the problem is. My Autel MX808 did a good job of letting me know that one of my wires powering the assembly was shorted and it closed the circuit to prevent any further damage.
      01-16-2024, 12:05 PM   #4
owenscj21
owenscj21's Avatar
53
Drives: 2016 BMW 228i M Sport
Just curious... any updates? I'm in the same exact situation with my driver's light assembly. It's very likely the moisture has caused some corrosion issues. The moisture entering the unit needs to be addressed. Very likely with a new assembly. ($1600 CAD from a local BMW dealer). I'm not even sure the assembly includes the modules.
I'm trying to hold off as long as I can. March at least. Unless I have catastrophic failure.
2016 228i M-Sport 6M RWD- CTS Intake, CTS FMIC, VRSF charge pipe, CTS catted downpipe, FTS Stage 2 ECU
      01-17-2024, 11:55 AM   #5
Dom147
The assembly does not include the any of the modules. It does however include the bracket located just below the headlight.
      01-17-2024, 12:36 PM   #6
owenscj21
owenscj21's Avatar
53
Ouch... looks like I've got a serious bill incoming
      01-17-2024, 01:12 PM   #7
Dom147
Yeah, it will certainly pay to figure out what works and what doesn’t work
      01-18-2024, 11:15 AM   #8
owenscj21
owenscj21's Avatar
53
Indeed. The assembly is guaranteed. I'm hoping the main control module is salvageable.
I'm still curious to see how OP made out.
      01-19-2024, 08:09 AM   #9
ralbert1998
Drives: M235
Hi all, heres a small update. Scanned codes with an advanced reader as recommended by one of the posters, found out the issue was with my adaptive headlight module; essentially the water ingress shorted it out (its located at the bottom of the headlight) and the whole angel went out. My solution (once it warms up as this car is currently my daily since my normal daily is down for the count) will be to remove the headlight, clear the vent, then use silicone and seal the seams. I'll swap out the adaptive headlight module with a new one (https://www.ebay.com/itm/225251218128) hoping that this non-OEM replacement will work for me. I'll update this as I go but don't expect any updates till it warms in march/april and there are no safety issues with the light at the moment
      01-20-2024, 11:35 AM   #10
Dom147
Woah i had no idea there were non-oem replacements. Huge win for us if they work.
Keep us updated!
      02-05-2024, 11:37 AM   #11
owenscj21
owenscj21's Avatar
53
Any updates?
My car went into the shop this morning for diagnosis on the failed DRL. Fingers crossed.
2addicts
