Go Back   6Post.com | BMW 6-Series Forum > BMW 6 Series Forum > General 6-Series Coupe, Convertible, and Gran Coupe Forum
      03-23-2024, 05:57 AM   #1
rayb615
Drives: 2014 bmw 650i gran coupe
which side is dm2 on
Hello new to the forum and this is my first post. Recently bought a 2014 bmw 650i gran coupe with n63tu and it has been misfiring and has high pressure fuel system fault codes. I swapped the high pressure fuel pumps and the code was originally on dme 1 and now it has moved to dm2. Was wondering if anyone can let me know which side dm2 is on so i can replace that side’s high pressure fuel pump. Thanks in advance.
      03-23-2024, 07:50 AM   #2
Oris4
19
Drives: 2012 BMW X5 35i
Bank 1 is pass side and bank 2 is drivers side in US cars
I changed both when I did mine at it was just a matter of time, also used fcp for lifetime warranty/replacement.
Are you getting any other codes?
      03-23-2024, 08:08 AM   #3
Walt White Coupe
Walt White Coupe's Avatar
222
Drives: 2013 650ix Coupe, 23 C8 Vette
I don't know if this warranty extension applies to your situation but it might.
      03-23-2024, 07:38 PM   #4
rayb615
Oris4 these were the codes on the dme modules before i swapped the pumps to different sides. And im planning on ordering everything on fcp euro for this car lol. I know that i will probably have to change the wiring connector, you have any advice or anything on which wire goes to what side of the connector? and I really appreciate your reply back.
      03-24-2024, 07:36 AM   #5
Oris4
19
I had pretty much all of those codes prior to doing my fuel pumps. My car is a 15 gran coupe and I did not have to change the connectors, hopefully you don’t have to as well. it is common to get the gasket in the Cam followers as well. Be sure to clear all the codes before start up.
6post.com
