02-16-2021, 05:30 PM | #15709 |
Rep 2
shawnsheridan Please send the E-Sys instructions and download if you get some free time. Thanks!
Can I also get the most up to date psdzdata for my 2014 f32 4 series. You are truly a legend. |
02-16-2021, 05:34 PM | #15710 |
General
10533
Rep 41,159
PM sent.
02-17-2021, 06:42 AM | #15711 |
Rep 2
Hi all,
Maybe I could find some help for bringing default settings to the REM. After messing with rear lamps (to be turned on in the day time) via bimmercode, the PDC stopped working and shows error "no parking assistance, please park unaided." Now I see that i get an error REM 8032C0 via diagnostic tool. I have tried to "code" back to default REM via ESYS with psdzdata (Read VO, Activate FA, Read ECU, Right click on REM ECU, Code). Where results were successful, although nothing has changed. (still got the same PDC error) I have noticed that while "coding" there is a note that "VCM update is deactivated, so it was not updated" Do I need to do something else to bring REM ECU values to default (such as Detect CAF for SWE)? I have checked my VO from VIN and it has opt 508 (PDC front and back, w/o camera) If I am missing any step in the coding workflow, please write me every single step i should do (and if i need to mess around with VCM or MSN options). N47 F31 2014 Thank you in advance! |
02-19-2021, 03:21 PM | #15712 |
Rep 3
I just bought a new-to-me 2017 440i and I'm excited to get started with some coding changes. Can you please help me get the appropriate E-sys, Launcher and psdzdata for my car?
Thank you! |
02-19-2021, 03:50 PM | #15713 | |
General
10533
Rep 41,159
02-19-2021, 03:53 PM | #15714 |
General
10533
Rep 41,159
PM sent.
02-20-2021, 02:40 AM | #15715 |
Rep 1
Hi All,
I'm new to this forum. I see that there's a lot of info to be found on coding. I have recently purchased an FLA mirror for my F30 330e (2016), bought the new steering wheel ring with FLA button, wired up everything, only needs coding. I tried using esys 3.25, but I believe that the PsdZData is too old for my car (51.3). Can somebody confirm if this is the case? Much appreciated. |
02-20-2021, 10:57 AM | #15717 | |
General
10533
Rep 41,159
02-22-2021, 06:18 PM | #15718 | ||
Rep 7
Can you send link to psdzdata for 2017 f30? |
02-22-2021, 07:27 PM | #15719 |
General
10533
Rep 41,159
I replied to your same PM.
02-23-2021, 08:51 PM | #15720 |
38
Rep 144
Drives: 2006 BMW 325i (E90)
Hello, thank you for the E-sys links and instructions before, but I think the links expired.
Is it possible you can send me the up-to-date psdzdata again, both lite and full? I would appreciate it, thank you so much. |
02-23-2021, 08:54 PM | #15721 |
General
10533
Rep 41,159
If you have Full, there is Zero reason to also have Lite, and not that you would ever need it, but you could just make Lite from full. PM sent.
mike512438.00 |
02-26-2021, 03:54 PM | #15722 |
Rep 1
Hello,I just clicked to ecu and code enire ECU`s in my vehicle. when im trying to code my hu for alpine retrofit. Now i have a limp mode. I searched for solution in all forums but cannot find a solution. Only thing i found is ``Detect CAF for SWE`` button to fix my DME. But that button is grayed out. Can I do this with new esys and/or new Psdzdata?
I m newbei in coding. Thanks for help. |
02-27-2021, 04:56 AM | #15723 | |
General
10533
Rep 41,159
02-27-2021, 07:42 AM | #15724 |
14
Rep 45
Hey shawnsheridan - would need newest E-Sys version including instructions (I'm still on 3.27 lol) plus latest psdzdata. Need to code our M240 in a few days.
02-27-2021, 02:03 PM | #15725 |
General
10533
Rep 41,159
E-Sys 3.27.1 remains preferred for coding. PM sent.
02-27-2021, 10:25 PM | #15726 |
Rep 32
I had the auto stop start coded out since the summer of last year and worked great, yesterday the car randomly kept putting itself into stop start mode? It was at the beginning of the last bar of fuel so it may just be conserving but it kept happening after fuel up and I've previously ran the fuel even lower and it never happened. If I restarted the car in park it would run fine but as soon as I would engage drive it started again.
Going to try recoding it, any ideas otherwise? |
03-02-2021, 11:40 AM | #15728 |
General
10533
Rep 41,159
PM sent.
03-05-2021, 02:40 AM | #15730 |
Rep 11
Drives: BMW M340i, 335i (gone)
Software link please
Greetings shawnsheridan, could you please send me the software link? Cheers!
