New 2009 2010 BMW Z4 - ZPOST
Go Back   New 2009 2010 BMW Z4 - ZPOST > BMW Z4 Forum (E89) > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
      09-16-2017, 05:46 PM   #1
BaaQaf
Drives: 2012 E89 Z4 35i M Sport
Coolant Tank Relocation
Anyone got pics of relocation of the coolant tank ?
      09-18-2017, 02:32 PM   #2
NoQuarter
Drives: 2008 535xi / 2011 Z4 35Is
2018 BMW X2  [0.00]
2008 535xi  [0.00]
2011 Z4 35is  [0.00]
I haven't seen any posted anywhere for the E89
      09-18-2017, 09:17 PM   #3
BaaQaf
I tried digging couldn't find anything myself. However look like it will transfer to the other side with ease though accompanied with a bracket.
      10-11-2017, 01:27 PM   #4
BaaQaf
Just an update
Found what was needed, a simple bracket and just move the original tank to the other side.
Will update more this week
      10-27-2017, 05:10 PM   #5
BQ Tuning
BQ Tuning's Avatar
Drives: N54 E89 Z4 35i M Sport
All done...... There are three brakets that are used here. Two on the top as you can see and another on the bottom using the original grommet from the other side.
Everything will be all black. The red bushing are used to also help level coolant tank. It will be all refined when the plumbing is done. Still waiting on a part from Germany to come in to install. All BMW OEM plumbing pieces are being used.
If anyone is interested in the relocation kit LMK. You get to keep the original coolant tank
      11-01-2017, 11:17 AM   #6
Tangent
Drives: G01, F82, E89, F25
This might be a dumb question but what's the benefit to relocating it?
      11-02-2017, 09:11 PM   #7
BQ Tuning
BQ Tuning's Avatar
Opens up space on the passenger side for upgtades, like single turbos, inlet upgrades like i did . The coolant being on the driver is the cold side of the engine bay. BMW also has the coolant tank on the driver side in their other model cars with the N54
Tangent303.00
      11-06-2017, 07:45 AM   #8
Eracer76
Eracer76's Avatar
Drives: 2009 E89 Z4 35i
I'm interested in that 90 degree fitting for the overflow hose. Did you source that and have a part number? Mine is straight and I could sure use a 90 degree one like that.
2009 Z4 35i 6mt, SpeedTech 6266 Gen2 turbo kit, Tial WG, VRSF 7.5 race IC, ER charge pipe, Tial BOV, Radium Fuel cell w/ surge tank and twin Walbro 525 pumps, Radium FPR and return line, Bluetooth ethanol sensor, Phoenix intake manifold w/PI, JB4 tuner, PR coil packs, Custom oil cooler, ECS Radiator, Spec 3+clutch, Mfactory flywheel, single 3.5" into dual 3" exhaust, H&R springs, 19" TSW wheels, 235/19 & 275/19 RE11 tires
      11-06-2017, 11:29 PM   #9
BQ Tuning
BQ Tuning's Avatar
The 90* hose for the coolant tank that I use seen in the pic I got from the X6 M diesel Part# 17127576361 . You can also get part # 17127803838
The X6 is longer which can always be shorten
Another part of interest is the heater exchange return connector that T's into the main heater hose return line for the coolant tank to connect to instead of routing the line from the other side. Part # 11537805359
It replaces the following connector circled in red
      11-07-2017, 04:27 PM   #10
Eracer76
Eracer76's Avatar
Thanks for the info... as you can see, mine has a little kink in the hose, it hasn't been a problem, but I'd still like to fix it
BQ Tuning113.50
      11-16-2023, 08:43 AM   #11
Erez161
Erez161's Avatar
Drives: BMW Z4 SDrive35i
2009 BMW Z4 SDrive35i  [9.50]
  [0.00]
I’m interested in the brackets, I also emailed you.
Thanks in advance!
zpost
