Studio RSR
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > USA - NY / NJ / CT / PA > E85 pumps in nj
      09-14-2013, 02:02 AM   #1
fc21
fc21's Avatar
Drives: 2007 335xi
E85 pumps in nj
I downloaded an app and they showed me some stations in Newark that sell E85 fuel but I'll have to call in the morning to see about that.
Can people post in here where in nj they get actually got their E85 fuel? Maybe create this as a sticky if it helps everyone? Lets see if that will happen.
Just locations of the E85 pumps. This isn't the thread to talk about pros and cons of E85. I'll make another thread for that haha. Post away!
2007 SGM 335xi 6MT (m-sport) jb4 G5 board/BMS DCI/BMS Clutch stop/CDV delete/AMS FMIC/BMS OCC/UUC SSK/KW v1/35% tint/OEM black lines/Lux v5.1/CF CSL trunk/AR downpipes/CSL reps/Forge DV/ BMS Charge Pipe/MORE TO COME
      09-14-2013, 08:43 AM   #2
Infamy
underground
Infamy's Avatar
63
Drives: alpine white 335 E92
2010 BMW 335i  [9.66]
Newark airport sells it.
      09-14-2013, 10:43 AM   #3
hemi to e90
dat boost doe
hemi to e90's Avatar
Poland
238
Drives: 10 335i 21 740li
best bet imho
      09-14-2013, 05:08 PM   #4
acidbbg
Drives: 335i vert
+1
It's near the car rentals..just follow the signs.
This car loves e85 mix.
      10-19-2013, 06:45 PM   #5
skim7x
skim7x's Avatar
Drives: 335i, C63 AMG
2007 335i  [10.00]
There's also that Power Gas station in West Orange...
Question: Aside from the risk of being shot/robbed/mugged, the e85 should be legit from that station, right? No chance of the gas being tampered with / diluted out?
I've been getting e85 from the Gulf Station at EWR, but it's a little out of the way for me, but I sometimes work by the Veteran's Hospital just around the corner from the Power Gas station in West Orange... would be SUPER convenient to just fill up a jug with some e85 and then get my e10 from my local Exxon...
'07 Space Gray 335i coupe - R.I.P.
COBB ProTuned | AMS | CP-e | BMS | Quaife
      10-21-2013, 09:00 AM   #6
skim7x
skim7x's Avatar
2007 335i  [10.00]
bump?
      10-21-2013, 01:19 PM   #7
fc21
fc21's Avatar
Drives: 2007 335xi
Originally Posted by skim7x
bump?
Now sure how we could go about confirming, short of taking the gas to get tested. Maybe ask the guy who runs the place but he could tell you anything.
      10-21-2013, 01:20 PM   #8
fc21
fc21's Avatar
Drives: 2007 335xi
You guys are running e85 mix of some sort without upgrading the fuel pump with no issues?? Been hesitant to do a mix. Figures I would upgrade the pump first.
      10-21-2013, 02:49 PM   #9
slo_335-e90
Drives: 2007 E90
I used to run a mix when I was on the JB4. Map 5 adjusts accordingly, and you'll feel a nice difference just be sure not to mix a heavy mix. I would run about 3/4 tank gas 1/4 tank e85, sometimes a little more. I found my pump having issues when I'd run 1/2 e85 1/2 93.
-335xi---Innotech Exhaust---AR 3" Catless---Pro tuned---HPF FMIC---ER Chargepipe---KW V1---Injen DCI---BMW Performance Front Bumper, Rear Spoiler & Door Sills---Vorsteiner wheels---much more-
      10-21-2013, 06:15 PM   #10
fc21
fc21's Avatar
Drives: 2007 335xi
Nice. I'm going to test it out when I have to refill again. Excited!
      10-21-2013, 08:08 PM   #11
fc21
fc21's Avatar
Drives: 2007 335xi
Question:
Since the e90 tank capacity is 16 gallons, a safe e85 mix is 12 gallons of 93 octane and 4 gallons of e85?
      10-25-2013, 08:19 PM   #12
fc21
fc21's Avatar
Drives: 2007 335xi
So I went to the Power Gas station in West Orange. FYI, there are two Power Gas stations in West Orange. The one that sells e85 gas is on Sandford Ave. Got gas at 7ish. I had no problem at all. Safe area. Well lit and camera's outside. Seeing the e85 sign got me giddy. Took a few runs on 280. I did a 70/30 mix of 93 octane from Shell (v power) and e85 gas. Love the difference. As the driver, only felt the torque when I was really pushing it but not with this mix. Felt good. Maybe it's cuz I was paying more attention so I'll try this mix a few more times before upping the dosage.
      10-27-2013, 12:34 PM   #13
rob1024
rob1024's Avatar
Poland
42
Drives: 2008 e92 335i
With BMS bb flash you can run 50/50 mix with stock pump ,no problem
MHD/Wedge E60 flash/Alpina TCU /Fuel It st2/Dinan OC/RB inlets/Helix Fmic/Vrsf DP/Forge DV/BMS DCI/BMS CP/TC Kline SA/swift springs/MF lsd/OEM PE mod/front and rear M3 links/M3 strut brace/Powerflex race rear diff,camber link bushes/DEV diff brace/Megan toe arms/AKG Race subframe bushes/Hotchkis Sway Bars/18 TSW nurburring/Michelin PSS/BMW M perf 370mm Hexon RR600 on the way
      10-27-2013, 04:11 PM   #14
skim7x
skim7x's Avatar
2007 335i  [10.00]
Awesome... I've been mixing 5 gallons of e85 with the rest e10 and have a custom Cobb tinge through Jake at PTF... so smooth it's amazing... from what I understand, up to even 40% e85 mix is okay...past that is probably fine, but you should run a full tank of e10 every once in a while because e85 sucks up moisture and could cause cracks in lines after a long period of time. Don't quote me on that though. All I know for sure is that it's safe to constantly run 40% e85 mixes...
      11-01-2013, 07:01 PM   #15
Jnat
DisplacementReplacement
Jnat's Avatar
409
Drives: 2020 X3M
Mighty Joes in Shamong NJ rt 206 South five minutes from Atco Raceway sells E85 and cam2. Great people there and they sell a lot of it!
      01-23-2014, 03:24 PM   #16
JayCee335i
JayCee335i's Avatar
16
Drives: e93 335i
Powers gas station in West Orange???
Or south orange?
      01-23-2014, 04:13 PM   #17
Mit_Boost
Germany
135
Drives: E90 335
Did you log your car after you blended? Even with a flash tune, some cars have trouble running anything above 20% ethanol on the stock pump. Obviously the last thing you want to do is making aggressive pulls while running maxed fuel trims & leaning out WOT.
Or south orange?
205 Sanford St. Location, East Orange, NJ
      01-23-2014, 04:16 PM   #18
fc21
fc21's Avatar
Drives: 2007 335xi
Didn't do any logging. Did it a few times and stopped cuz it started getting cold. I know a mix will add some moisture to the gas lines and it was getting cold. Don't want to run into any cracking issues. Planning on upgrading my fuel pump and gas lines in the spring and doing some logging.
      01-23-2014, 08:31 PM   #19
JayCee335i
JayCee335i's Avatar
16
Drives: e93 335i
West Orange is a nice neighborhood with high taxes.You probably ment EAST ORANGE(mad hood).
      01-23-2014, 08:34 PM   #20
JayCee335i
JayCee335i's Avatar
16
Drives: e93 335i
@ Mit_Boost
Thank you brother
      01-23-2014, 09:14 PM   #21
fazman
Drives: 335 e90
Damn, and just a year ago u were stock with wastegate rattle... Look at u now with a bad ass ride
Once i get a spare ride for the wife i gotta play some catch up to u
      01-23-2014, 11:14 PM   #22
Mit_Boost
Germany
135
Drives: E90 335
@ Mit_Boost
Thank you brother
No problem, but for anyone planning on using E85 once the weather gets nice.....
DO NOT BUY POWER GAS E85! Honestly it is crap, and has been tested to normally be in the 60% range. I have a straight E85 tune, and EVERY time last summer I used Power Gas E85, I had timing corrections (which should never happen on E85).... The Newark Airport Gulf Airport has E85, it's a bit of a bitch to get to the station but I've never had problems with the E85 quality.
