      09-24-2014, 08:42 PM   #67
Chunner
Chunner's Avatar
153
Drives: BMW 135is | #341/586
bump
2013 BMW 135is Coupe | Dinan Stage 3 | M3 Subframe Bushings | Dinan Monoball Joints | Dinan Toe Links | 1M Strut Bar | MPS AS/3 - VMR 710's 18x8.5 ET45 / 18x9.5 ET50 | MPSS - BMW 313's 18x7.5 / 18x8.5 | Min Grey, Savanna | Prem, Tech | DCT | Beast #341/586 |
2021 BMW X7 M50i | Alpine White | Children Hauler
      09-24-2014, 09:55 PM   #68
Joaco135
Joaco135's Avatar
Drives: 2020 M2C LBB
Anyone have a .pdf copy of the bulletin?
      09-25-2014, 03:59 AM   #69
Dackelone
European Editor
Dackelone's Avatar
Germany
10604
Drives: N54 e82
Originally Posted by Jettt View Post
Thanks bro!
MY car is at the dealer now getting a new shifter, so hopefully they just put it on there without me having to ask. But incase they dont, now I know what to ask for.
Most dealers will not update your SW unless there is a problem to fix or a repair that involves an update. Sometimes the sw updates are a pain bc hardware can fail or fail to take the update. So its just easier not to bother - unless its really called for.
      09-25-2014, 08:09 AM   #70
Jettt
Gun Slinger
28
Drives: slow and with caution
I just got a call from my dealer telling me that my new shifter is in and that the car wont turn on because its failing to read the new software. They said it will be a couple days before they get it figured out and they will give me a call back.
Hopefully they get it all figured out. Ill keep everyone posted.
      09-25-2014, 11:01 AM   #71
saveferris
Drives: 2011 135i
Adding my two cents. I had the update installed last week. Prior to that I had the issue a lot of others have noted with idling, lag, stalling, etc.
I can report that the update fixed all of that. The car is basically back to what it was supposed to be and the idling, lag, etc. issues are completely gone. If you experience those get to the dealer and get the update.
      09-25-2014, 12:08 PM   #72
ucsbshawn
ucsbshawn's Avatar
36
Drives: M3, 135i, 320i
Originally Posted by houtan View Post
Does anyone with this latest update have a cobb accessport? want to find out if you have contacted cobb after the flash and find out if they support this version of the SW. i want to get the update, but want to make sure i can reflash afterwards.
Anyone with COBB have the update?
      09-25-2014, 03:03 PM   #73
Overpar56
Proud AARP member in good standing
Overpar56's Avatar
28
Drives: Me nuts
I heard that can be a problem if it doesn't take the first time. I swear this car runs Windows Vista.
2012 135i DCT, Lemans Blue/black leather, PPK1, PE, Stoptech Sport rotors and Sport pads, unhealthy crackles and burbles and an aging demonic driver.
      09-26-2014, 10:31 AM   #74
jmz135
40
Drives: '11 MT E82
2005 Honda S2000  [0.00]
2011 BMW 135i  [0.00]
This is great news. This issue drove me crazy when I first bought this car. I tried several times to get the dealer to fix it with no real luck. I followed some of the similar threads in the past and had the DME updated to the latest back in June. It solved the car stalling issue, but the throttle response issue never went away (most noticeable with AC on and decelerating to a stop then trying to go again). Basically noting would happen for 1.5 seconds and then the car would surge forward.
I don't want to get too excited over this since I was told the last update would fix it too, but I have my fingers crossed.
Thanks a lot to e36addict for letting us know about the SI B 12 15 14, hopefully my dealer will admit to having the update.
      09-26-2014, 12:23 PM   #75
loesch
loesch's Avatar
Drives: 2011 BMW 135i M Sport
@e36addict Do you know if anything similar can be applied to the manual trans cars? We have the same issue but it just isn't quite as bad because it doesn't cause us to completely stall out. Poor throttle response and delay in throttle input especially along with slightly fluctuating idle, especially w/ AC on.
2011 135i M Sport 6MT LeMans Blue | Active Autowerke Gen II axle back | Berk d******* | N54 gutted mids | FuelIt Walbro 450 fuel pump | Pure Turbos Stage 2 | 3.5bar TMAP | Pure Turbos inlet pipe | BMS intake | BMS oil catch can | ETS intercooler | ETS charge pipe | BMS JB4 w/ ISO firmware | BMS backend flash stacked on PPK | Eibach springs | Whiteline rear subframe bushing inserts | cosmetic tidbits
      09-27-2014, 10:49 AM   #76
ucsbshawn
ucsbshawn's Avatar
36
OK so no one with COBB, can anyone find out what the DME Rom version is?
      09-27-2014, 11:20 AM   #77
houtan
houtan's Avatar
707
Drives: 2011 135i
2011 135i  [9.80]
+1
I would like to know as well.
      09-27-2014, 05:34 PM   #78
CRuben09
CRuben09's Avatar
119
Drives: 2021 M3
I think I'm in love with this sw update after seeing the video and all that burbling!!! I just want to take my car in and request it, I'm tired of the forward surges.
2019 X3
2011 135i Alpine White DCT N55 All Stock
Built on 10/10 Proud owner since 12/12.
      09-28-2014, 05:45 PM   #79
Overpar56
Overpar56's Avatar
28
Drives: Me nuts
I don't know if you'll get the overrun sounds w/o PPK1 or other mods like the OP has
      09-28-2014, 07:47 PM   #80
CRuben09
CRuben09's Avatar
119
Drives: 2021 M3
The OP doesn't have PPK. At least that's what I interpret from his post.
2019 X3
      09-29-2014, 09:44 AM   #81
e36addict
Drives: 2013 X1 35iX
You are correct.
      09-29-2014, 10:29 AM   #82
Overpar56
Overpar56's Avatar
28
Drives: Me nuts
Originally Posted by e36addict View Post
You are correct.
Maybe I'll get twice the snap crackle and pop then. Way cool.
      09-30-2014, 09:17 PM   #83
Joaco135
Joaco135's Avatar
Got mine today from the dealer and sure thing, the fluctuation is gone and the lurch forward is also gone,
      10-01-2014, 10:02 AM   #84
TX135i
47
Drives: 2012 135i Coupe DCT
Did it have any effect on the rolling stop throttle lag issue? I'm getting mine updated on 10/14 as well as the VANOS bolt recall done, and I'm so looking forward to seeing the results of the new SW.
      10-01-2014, 10:20 AM   #85
jmz135
40
Drives: '11 MT E82
This is also what I am most interested about. It's the biggest annoyance with the DCT.
      10-01-2014, 11:06 AM   #86
TX135i
47
I agree totally. And it's just plain dangerous (not to mention embarrassing). The idle fluctuation problem to me always seemed silly that they could not make it react properly, but that throttle lag issue is clearly unsafe.
I do hope to get a few more burbles in the deal though!
      10-01-2014, 03:15 PM   #87
YangEnterprise
YangEnterprise's Avatar
Drives: 16 BMW M4 - JAVA GREEN
When I took my car to get the Vanos recall fixed, they also updated my software. My dct was lagging and had rpm spike while AC was on.
I noticed after the software update, the burble and backfire my car use to make is less pronounced and pretty much gone.
I don't know which software they used to update my car. Anyway to check?
      10-01-2014, 05:06 PM   #88
jmz135
40
Drives: '11 MT E82
It sounds like they used the May/June software on your car, that was similar to my experience after getting an update back in June.
Not sure about a way to check, though shouldn't it say what software they did on your itemized sheet they gave you?
I have an appointment with my dealership next Tuesday to get this update.
