another high boost N54 engine failure
10-05-2010, 04:48 PM | #45 | |
Rep 1,179
i would have expected more issues on this engine platform due to the OEM boost parameters (which are in the "quite safe" area) vs. higher boost environment of some of the tuned cars already running strong and consistent. its clear and apparent that this is not a mechanical failure, but more of a situation aggrevated by the lack of adequate timing control. As seen on the other engines' failure (enrita's) the problem may or may not be the same, but the same results are evident. On his car there was a detonation related failure, which affected a portion of the piston crown and breaking the down the ringland area. It should be noted by anyone thinking of tuning a forced induction car, to read Turbo Basics 101, and have some grip on the how f/i is different from n/a, plus timing and detonation principles. What these changes do to a f/i car vs an n/a car. this is not an indictment of one tune over the other ... just simple, basic facts available to those willing to learn -- before flipping the switch. Last edited by shifterboy45; 10-05-2010 at 04:58 PM.. |
10-05-2010, 04:49 PM | #46 |
3441
Rep 79,211
Drives: C6 Z06, 09 335i, 10 335xi
10-05-2010, 04:51 PM | #47 | |
once Treppiede
63
Rep 915
Meantime, Vasillalov posts twice and stays on topic, then... ...even after Vasil does try to stay on topic and stops arguing with you? It seems like you're just looking to argue. Calm down brother, I don't agree 100% with his statements about flash tunes and I am not particularly fond of GIAC and their pricing/flashing approach, but you're out of line. I am sorry that another N54 was sacrificed, I am surely taking note and trying to learn from this unfortunate episode. -Walter
2013 E92 M3 | 6MT | AlpWhite | SilverNovillo | CarbonTrim | ZCP | PremiumPkg | Alarm
2009 E92 335i | 6MT | AlpWhite | CoralRed | AlumTrim | M-Sport | Nav | Logic7 | Alarm (sold to a friend - still in the family) |
10-05-2010, 04:54 PM | #48 | |
Rep 1,179
i hadnt even gotten to this post till after i posted -- hope we dont sound too much alike -- |
10-05-2010, 04:55 PM | #49 | |
3441
Rep 79,211
Congrats your not part of the solution but part of the problem even still. Next (PS my post was relevant to his post, regardless if it makes him look bad, it is what it is; furthermore, he continued to point fingers at other tunes and other tunes faults without reading into other causes of the failure, so he was still off topic and even more wrong). |
10-05-2010, 04:57 PM | #50 | |
Joint Chiefs of Staff
4922
Rep 115,999
CPS offsets can not be applied in one engine revolution and you know that. They must come in over several revolutions to prevent false misfire codes from being triggered. Setting the map output over target results in an instant timing drop. Just like your customer datalogs showing an instant timing increase to 20+ degrees during fast manual shifts. The map outputting is simply the fastest way to influence timing. As far of the rest of it, I am not arguing with you about your views of Terry, etc. Mike |
10-05-2010, 04:59 PM | #51 | |
4922
Rep 115,999
Mike |
10-05-2010, 05:04 PM | #52 |
442
Rep 18,331
I wonder if he went ahead and used the NGK plugs that he was inquiring about? I think Enrita also used these same plugs..
http://www.e90post.com/forums/showthread.php?t=384541 |
10-05-2010, 05:08 PM | #53 | |
Rep 7,377
Seems my failure happened straight away and the heat generated melted the plug while his failure was more gradual over time.
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
10-05-2010, 05:09 PM | #54 | |
3441
Rep 79,211
Edit- enrita said stock plugs. |
10-05-2010, 05:17 PM | #55 | |
1743
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
Misfire diagnostics aren't a concern if a high boost meth failure scenario. Its far more preferable to induce a misfire/limp than grenade a piston ring. So no timing retard rate limiting need be used. And you should know that CAN logging is limited to 10/sec so pointing out a mid-shift timing spike is disingenuous. Especially considering that you now know that short term timing corrections are represented in the datalogs. But let's know deviate from the topic. |
10-05-2010, 05:20 PM | #56 | |
Rep 1,054
That's some really hard work for the tiny little N54. |
10-05-2010, 05:21 PM | #57 |
Rep 4,936
It seems to me the obvious reason for the whole problem is running to much boost. From what i understand about ignition/timing etc ( witch is not alot). you could run 16psi and have just as good power as the guys running 18+psi if you have good timing.
[SIGPIC][/SIGPIC]
10-05-2010, 05:22 PM | #58 | |
Rep 10,587
top speed and mile runs really put a test on the car and the tuning.
10-05-2010, 05:23 PM | #59 |
Rep 2,014
Exactly what I was going to say. That and everyone wants to have the fastest xxxxx before the snow starts falling so they can have bragging rights until the sun comes back out.
10-05-2010, 05:34 PM | #60 | |
4922
Rep 115,999
This could be a meth failure related problem but the bigger thing to take from this thread is running 18-19-20psi on pump+meth or even race gas+ meth is not without its risks. Many customers in both camps run 18+psi with zero CPS offset daily. Mike PS. On the CAN logging I've heard 10 samples/second is about the limit of the ECU but I thought you advertised 30 samples/second? |
10-05-2010, 05:44 PM | #61 | |
1743
Rep 17,960
Drives: A Lot
10-05-2010, 05:46 PM | #62 |
That guy
117
Rep 5,740
Drives: 2015 Cayman GTS
10-05-2010, 05:55 PM | #63 |
Rep 1,179
I have yet to see a BMW toss a piston, unless it was an oiling/lubrication problem or a hydro-lock where water was introduced in to the intake.
I'm sorry to hear about this fellows tragedy, but as this all plays out, wouldnt it be a good time to reflect on how much knowledge you have about what is going on in the combustion chamber, how are pistons designed, what ignition timing is and how it plays its part in the 720degree principle. if BMW can run their Formula 1 cars on seasoned (used) M10 four cylinder engine blocks -- put out 1200hp+ at 30+psi boost and keep things together, i think these cars should be able to deal with 500hp with no problem. take it step by step, without jumping to immediate conclusions.. i commented based on the ringland failure, without pictures and parts disassembled im really taking an educated guess. so i dont want to seem like im part of the confusion. |
10-05-2010, 05:59 PM | #64 | |
3441
Rep 79,211
That last 24 MPH is a lot of work. That is about the jist of my WOT, after that its daily driving on minimal to low boost. |
10-05-2010, 06:03 PM | #66 |
3441
Rep 79,211
Bmw 335i E92 MT, BMS JB3 2.0, BMS SLD, BMS Boost/IAT Gauge, BMS DCI, BMS 02 s*ms, Heat shield, Riss Racing MCV, AR Cat*ess DP´s, AR OCC, Simons Catback, ETS Intercooler, CM VC2 Methkitt, CM meth elbow. My car--->http://www.garaget.org/?car=141758
