Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Can I reuse spacers?
      05-05-2013, 07:51 PM   #1
gatorheel
Drives: 2007 e90 n54
Can I reuse my spacers? When they were taken off they got a little chipped and I wanted to make sure they are still safe to reuse. PICTURES ARE IN NEXT POST. (Side note. I have a dremell and could sand down the jagged areas). Thanks.
2009 n54 e90 / Sport Pkg (ZSP) / Premium Pkg (ZPP) / black sapphire metallic / Logic7 / AMS FMIC / BMS 3" DP / BMS OCC / Alpina TCU Flash / ER CP + ForgeDV / Cobb
Last edited by gatorheel; 05-05-2013 at 08:02 PM.. Reason: to clarify that pictures are in next post.
      05-05-2013, 08:01 PM   #2
gatorheel
pictures...
here are pictures.
      05-05-2013, 08:18 PM   #3
VTECaddict
Where'd my VTEC go?
VTECaddict's Avatar
Drives: 06 330i 6MT
As long as it still sits flush with the rotor you're fine.
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit
M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear
      05-05-2013, 09:02 PM   #4
gatorheel
Cool. Thanks.
      05-05-2013, 09:22 PM   #5
Game
Game's Avatar
7404
Drives: G87 M2 (sold)
Man those got beat to hell.
      05-06-2013, 07:47 AM   #6
gatorheel
yeah, i have a feeling anti-seize was not applied at install. shop was not the best.
      05-06-2013, 01:19 PM   #7
VMRWheels
VMRWheels's Avatar
2038
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
Those spacers have seen better days. They might be okay as long as they're flush against the hub, but I might consider replacing them at some point.
In any case, definitely apply anti-seize on your next install!
      05-06-2013, 02:03 PM   #8
gatorheel
thanks everyone. appreciate the feedback.
      05-07-2013, 01:49 AM   #9
Hybrid For Life
Germany
78
Drives: Out of Spec
Damn those look ruff, but as previously stated as long as they sit flush on the hub they should work fine
      05-15-2013, 12:47 PM   #10
gatorheel
update
I ended up cleaning them off w/ wire brush and then dremel-ing off the jagged pieces. They will sit flush now but I am concerned that the raw metal portions will be conducive to corrosion. What do ya'll think?
      05-15-2013, 01:03 PM   #11
VMRWheels
VMRWheels's Avatar
2038
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
I wouldn't be super worried about that. While most spacers have some form of anodizing or a protective coating, it will often get worn off over time anyway. Most of the spacers I've seen all have some level of corrosion on them.
Just paint that area and call it a day. Be sure to apply anti-seize on there as well, so that next time they need to come off they won't be stuck.
      05-15-2013, 02:21 PM   #12
gatorheel
good stuff. thanks.
reuse, spacers
