02-11-2024, 11:47 PM | #5831 |
General
10445
Rep 40,797
Need to search BDC CAFD for the corresponding FDL Codes.
02-12-2024, 12:08 AM | #5832 |
Rep 29
02-12-2024, 12:13 AM | #5833 |
General
10445
Rep 40,797
It depends on if you are using BU as standalone Coding App or with E-Sys, but either way, you need to Read BDC, and it will open up in FDL Editor, where you can search and change FDL Codes.
02-12-2024, 12:23 AM | #5834 |
Rep 29
BU standalone, on FDL editor there are to many entries with no description, don't have a clue in what to change. There are no information on XML cheat sheet either.
02-12-2024, 12:25 AM | #5835 |
General
10445
Rep 40,797
What is the name of BDC CAFD?
02-12-2024, 12:35 PM | #5837 |
General
10445
Rep 40,797
02-12-2024, 11:24 PM | #5838 |
Rep 29
02-13-2024, 12:03 AM | #5839 |
General
10445
Rep 40,797
Sorry, I do not understand what you ask about Decimal Values. Post same picture as mine from your BU.
02-15-2024, 09:40 AM | #5840 |
Rep 1
Hey shawnsheridan could you send me the link for ESYS + psdzData LITE (Assuming I don't need the full one from what the original post mentions)? I have a 2014 F15 50i and I need to flash the AAG Trailer Control Module on my vehicle.
02-15-2024, 09:47 AM | #5841 |
General
10445
Rep 40,797
PM sent.
03-25-2024, 03:19 PM | #5843 |
87
Rep 52
Hi Shawn,
Can you send me the download links for e-sys and instructions for the latest. I had v 2.8 but it kept failing also stating token invalid and no certs found. Also, what are the latest PC requirements. Thanks, Mike |
03-25-2024, 05:21 PM | #5844 |
General
10445
Rep 40,797
PM sent.
04-13-2024, 02:36 PM | #5846 |
General
10445
Rep 40,797
PM sent.
04-20-2024, 04:19 PM | #5848 |
General
10445
Rep 40,797
No. Cheat Sheets fell out of favor long ago for cheat.xml files used by LauncherPRO / BimmerUtility.
04-24-2024, 01:21 PM | #5849 |
Rep 2
Help with AAG module
Everything seems to be flashed correctly to the AAG module but getting the following error on trailer module in BimmerCode:
802840 Power Supply KL30f left missing / interrupted Dash screen shows: Trailer Electrics overload: Trailer not lit or only partially lit. Turn off electrical devices in trailier. If fault persists, consult service center. CAFD appears flashed to AAG module 235 in HO-WORT Used new factory retro fit wiring and new AAG module. No trailer attached. Any ideas. Can share any screenshots etc that may be relavant. |
