2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Car wont stay running after resetting adaptions
      02-06-2024, 03:55 PM   #23
ChiltiCoatl89
ChiltiCoatl89's Avatar
Originally Posted by JimThot View Post
2011 535xi, n55. I had gotten the code 101F01 and when reading i saw a procedure to readapt the engine by unplugging the purge valve and letting it idle for 15 min and then plugging it back in. I did this and the engine light didn’t come back and also took it for a quick test drive and it was great. So i left the car over night. Next morning the car started but ran rough and died on itself. I’m not getting any codes other than the same 101F01 code and then a bunch of misfire codes form all cylinders. Can someone explain what is happening?
I'm looking inside the Forums, there is a Thread on the original Code you had from your first message. Type in your problem code and N55 and it should appear on google results. You will see that it is within our Forum.
      02-07-2024, 10:44 AM   #24
JimThot
JimThot's Avatar
40
Drives: 2009 E92 335i
i’ve searched around looking at the original code, i have a new issue now where the car just shuts itself off after startup like the video i sent earlier.
      02-07-2024, 01:22 PM   #25
zrile
zrile's Avatar
Croatia
91
Drives: BMW F31 320xd
wouldn’t this cause a fault code to come up
Yes, but you can easily reset error if it is not faulty.
      02-07-2024, 01:25 PM   #26
JimThot
JimThot's Avatar
40
i replaced spark and coils, still same issue. my thought is that the dme has the wrong values and is shutting itself down upon startup. i’m not sure how to fix it if it is the issue though
      02-10-2024, 12:12 AM   #27
zrile
zrile's Avatar
Croatia
91
Me neither.... sorry forclate response, i'm not always here... i really want to help to anybody but i have basic mechanic knowledge and always suggest to try cheap things first and sensor testing by "picking". 😄 update us if you fix issue!
      02-10-2024, 01:14 AM   #28
JimThot
JimThot's Avatar
40
i have an update, it’s funny but my dad who usually works with me on bmw’s came back from a trip and he somehow got it to keep running by constantly revving the engine on startup even though i tried the same thing. It seems like it’s only surging once and a while so we bought a new air mass flow sensor and will see if it fixes it. currently it intermittently bogs and surges on cold start.
zrile91.00
      02-10-2024, 02:09 AM   #29
ChiltiCoatl89
Yeah, sometimes things like that go overlooked and we tend to extend out minds into places further into diagnosing, concluding to possible complex issues, when sometimes, it can be something simple, I really hope that fixes your issue.
zrile91.00
      02-14-2024, 08:13 AM   #30
zrile
zrile's Avatar
Croatia
91
I think it is some air leak.....
      02-25-2024, 05:49 AM   #31
ChiltiCoatl89
Clean and Inspect your Vanos Solenoids for good measure.
      02-29-2024, 08:45 PM   #32
JimThot
JimThot's Avatar
40
welp the car just spun another rod bearing after just replacing all 6… time to make another post to figure out what else could have caused this.
5post
