      06-09-2013, 05:05 AM   #45
Artemis
Moderator
Artemis's Avatar
29419
Drives: BMW M2 Competition
Originally Posted by ozinaldo View Post
Artemis, I think we may add the "knock sensor issue" in this Sticky. Here is the ongoing thread that talks most about it:
http://www.1addicts.com/forums/showthread.php?t=839266
Thx Oz. Actually, that thread was already included in the HPFP failure section with a reference to a knock sensor issue.
However, for a better overview I divided similar phenomena in three (sub)sections (issues #5a|#5b|#5c): HPFP failure, knock sensor issue and charge pipe issue. The subsequent enlisted issues of the list were renumbered.
///M is art Artemis
      08-26-2013, 07:18 PM   #46
octainejunkee
octainejunkee's Avatar
25
Drives: M3 f80 Comp, MPE, stage 1
Originally Posted by Dackelone View Post
The 1M (and 135i) hood is just fine bellow 280 kph V-Max speeds. That is why BMW M will not offer a higher speed limiter aka "driver's package" for the 1M. At least that is the "story" I heard.
No one is really gonna be seeing those kinds of speeds - except for maybe a few car nuts over here. Like me. And my hood has been holding up just fine above 280 kph on my "tuned" 135i.
My car is de-ristricted and after a long drive on the autobahn at speeds of 180+mph the front end is looking sorry for itself.
The front wings have been bent out slightly and i can fit my finger in the gap between the top of the lights and the shut line where the wings meet.
atleast the bonnet (hood) stayed down i guess..
BSM 1M owned from new.
      09-16-2013, 10:46 PM   #47
nicoz
Drives: 1M
issue #13:
They changed 2 clips and put vibration deleting tape behind the panel.. problem solved!
      09-17-2013, 05:05 AM   #48
Artemis
Moderator
Artemis's Avatar
29419
Originally Posted by nicoz View Post
issue #13:
Thx. Implemented.
///M is art Artemis
      09-29-2013, 06:12 PM   #49
timbo_3101
Australia
18
Drives: Slow
Originally Posted by Ian///M View Post
Brake pedal vibration unexplained
+1
Has been an ongoing and worldwide issue for E9xM3 and 1M racers using stock brake pads. Have been through three sets of brake pads and three sets of rotors after less than 10000km, and unfortunately there are many others affected.
      09-30-2013, 07:18 PM   #50
pkimM3r
pkimM3r's Avatar
205
Drives: m3 saloon in granny mode.
No diff issues like m3?
      09-30-2013, 09:41 PM   #51
ozinaldo
ozinaldo's Avatar
Portugal
116
Drives: 1M
Yeah, Dackelone brought the same question up in a separate thread in the chassis sub forum and I just replied (just summarizing) "never heard of...doesn't mean it didn't happen or won't happen though".
I assume you are also asking the broken differential bolts issue and not regular differential noises.
If it really is a production related defect at least on some cars I would expect this to appear sooner or later with some 1Ms too. Vice versa doesn't make sense...of course unless for some reason BMW used different bolts in 1Ms which is probably not even possible and as a whole the differential and all its components are interchangeable between the two cars.
Let's wait and see. In the mean time I will be checking my differential soon
"The mark of a great car is one whose overall competence exceeds what you should expect from its individual components and the 1M does just that", Chris Harris.
BMW 1M-SOLD-: TECH: Evolve Race+N55mids, Evolve IC, Michelin PSS, ER cp, aFe filter, CDVx, Vorshlag camber plates, BMS OCC EXTERIOR: trunk spoiler, blacklines, black grills, IND goodies INTERIOR: Alcantara steering wheel, steel pedals, custom mats, MPower e-brake.
      10-01-2013, 05:27 PM   #52
PilotLx
PilotLx's Avatar
Drives: Black 1M Coupe
Exclamation Engine Fault !
While driving experiencing loss of power and after a while get the message:
"Engine Fault!
Full Engine power no longer available.
Possible to continue journey.(..)"
After arriving home, checked error code ECU P3OFF
with description:
"Pre-Control boost control, pressure to leak from pressure line; error on loader 2;"
Any ideas, suggestions?
COBB tuning Stage1 + FMIC Wagner
EVOLVE Race Catback exhaust / PFC Z-type brakes
Afe intake PRO 5R / CP + Forge BOV
Passport Escort 8500ci Plus
      10-02-2013, 05:00 AM   #53
PilotLx
PilotLx's Avatar
Fault detected!
I've installed aFe Silver Bulllet Throttle body spacer,
after 300km charge air induction tract broken
http://www.1addicts.com/forums/showt...7#post14751067
      08-15-2014, 05:11 PM   #54
Artemis
Moderator
Artemis's Avatar
29419
Due to a change in realOEM.com most links to part # in the log (first post) were broken.
Links are now updated and operational again.
///M is art Artemis
      08-15-2014, 07:18 PM   #55
BMW M Power Mexico
BMW M Power Mexico's Avatar
Mexico
455
Drives: E60M5,E821M,F15X5V8
My diff is grinding when doing right turns. It's been getting worse for the last month. Will try the "liquid" solution soon.
BMW Car Club de México
¡Estás Invitado!
http://bmwclub.org.mx
      08-16-2014, 07:37 AM   #56
Artemis
Moderator
Artemis's Avatar
29419
Added "hood lift at high speed (>220kph|>135mph)" as issue #18 to the list (actually a normal phenomenon rather than an issue).
///M is art Artemis
      04-16-2015, 09:59 AM   #57
1978.530i
13
Drives: BSM 1M
A couple of issues...
1. When turning right with wheel all the way over, i get a clunck noise and feel.
2. My auto windows occassionally don't go all the way up and i get an error message / indicator.
      09-05-2015, 03:23 PM   #58
-cj-
199
Drives: '20 X5MC | '20 Z4
I've been getting this 'pinging' sound when my car is moving. I can't reproduce if I lift the car up and roll each wheel individually. I failed to check the dust shields when I had the car off the ground, but rolling the wheels should have tested for this, right?
Here's what it sounds like. This is actually two sound clips in one. One of them I have the Akra flap open and the second I closed it to help record the sound. I had the phone out the window --- it isn't normally that loud, but loud enough that I can hear it when I go past an object at slow speeds.
Thoughts?
Clip: https://www.dropbox.com/s/1x5n5sxvvg...attle.m4a?dl=0
      03-11-2016, 02:22 PM   #59
EldRick
Drives: 1M VO - #161 US
Add one more HPFP to the failure log. Mine crapped out at just under 10K miles.
Engine Malfunction! Reduced Power!
From the moaning sound it was making, I guessed cracked charge pipe, but the dealer replaced the HPFP under my Extended "Warrantee". They even had one in stock, which tells you something about the reliability of this item...
And three months later, the charge pipe boot popped off at the top (I did have a mild Cobb tune on the car). Surprisingly, the dealer offered to do the labor if I wanted to replace the OEM with a metal charge pipe, which is going on at 11,000 mile service this week.
      02-09-2022, 08:16 PM   #60
FIRSTM
Buck Sgt
FIRSTM's Avatar
Drives: 1M
Just wanted to bring this thread back to life lol Our beloved 1M have the leaky coolant problems like most other n54 engines. Plastic connectors they use became brittle and will crack, the plastic connector to the cylinder head thermostat crack and came apart after I found out car was leaking fluid. Now i smell burnt oil and it seems to seep down from somewhere to the exhaust, and found some info that it may be from valve cover gasket.
      09-07-2022, 10:28 PM   #61
markslc1
Drives: 2011 1M, 14 X5 x35i
Thoughts?
Thoughts?
Ever figure this out? I'm having similar issue.
      09-08-2022, 06:32 PM   #62
iDontRemember
Ding Dong!
iDontRemember's Avatar
106
Drives: AW 1M
Thoughts?
Last time I had a similar sound was when something got trapped in the rear brake shield.
