02-15-2024, 11:58 AM | #1 |
21
Rep 51
OEM nav screen repair/replacement solution
I haven't seen this mentioned anywhere, but if you want to retain your original nav screen, I found a pretty cheap solution. As I discovered, you CAN swap in the screen from E83 and it's not too bad of a process.
I suck at making videos, but here's how you can fix your screen without spending $1500+ on a used replacement unit. Technically, this isn't a fix, but a retrofit of an (almost) identical unit from E83, which can be had for much cheaper. If you are somewhat hands-on and don't feel like watching the video - here's the jist of this project:
Comment below with any questions and I will do my best to answer. Unfortunately, my video did omit some parts that may be important. |
