ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Navigation, Audio, Bluetooth, Stereo, Electronics Talk
  TireRack
      10-22-2012, 10:55 PM   #23
WestCDA
Drives: 2006 Z4R 3.0si
Originally Posted by mhughett View Post
So my question is why does Autozone and Advance show that the correct size is H6 or H5 when the 48extAGM is the clone of the OEM battery?
Because the 48extAGM is the clone of YOUR oem battery, perhaps, and other cars may differ?
      10-23-2012, 06:11 PM   #24
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
65
Drives: 2006 Z4MC Interlagos
Originally Posted by WestCDA View Post
What battery group is it? My car has a group 47/H5. I tried purchasing a group 48/H6 as others said they were a direct replacement, but the the battery was too long for my factory brackets. I don't recall the details, but it wasn't a simple matter of sliding an adjustment to allow the larger battery to fit (I would rather not have returned it).
The group 47/H5 is 9 9/16 long, the 48/H6 is 11 inches long. The height (7.5) and width (6 7/8) are the same.
If I look up the replacement using Canadian Tire's parts locator, it returns the H5 size. If I use the US sites for O'Reilly or Auto Value they return both Grp 48/H6 and Grp 47/H5 as possible replacements. If I use the US Walmart battery lookup, it returns H5 only. I tried multiple years and M/non-M variants where possible.
It appears people should double check their existing battery dimensions before making a purchase ...
I'll need to check. I do know the new one is longer and the tray was designed to manage both.
2006 Z4MC - #LL93158
SS Race Cans, RE X Pipe, DKF Sec 1, Fabspeed Headers, OE STB, AS Shifter, Dave Z CDV, GC Coil Overs, Stoptech lines, Hawk DTC Pads, RE Clutch Stop, RE Transmission Mounts, Vibra-Technics Engine Mounts, Poly FCAB & RTAB, LeatherZ M Shift Boot, Tekarbon Rear Spoiler, CF Grills, Advan RS DGM
      10-24-2012, 06:55 PM   #25
Jumbosock
Jumbosock's Avatar
76
Drives: 2007 M coupe
I'm eventually going to add my input for the Lithium Pro L925. I'm still running some tests. The car alarm draws some amperage (not sure how much)... so should we be testing how many days the car will last and still start with the alarm activated or inactivated or both? Bad news is my battery failed the 5 days test with the alarm activated. =( I was hoping to last a week with this battery.
      10-25-2012, 04:04 PM   #26
Jumbosock
Jumbosock's Avatar
76
Really bad news! Just melted my expensive lithium battery. It did NOT like my trickle charger. Probably user error on my part. Oh well, I'll call the company. Glad my car didn't burn down... which might have happened had my brother not smelled it.
Edit...pretty sure my trickle charger was not compatible with my battery. Expensive lesson but that's how it goes.
      10-26-2012, 09:29 AM   #27
WestCDA
Ouch! Did the Lithium battery come with any guidelines on acceptable charging practices and/or hardware?
      10-26-2012, 09:39 AM   #28
inTgr8r
inTgr8r's Avatar
2432
Drives: M2 Comp
Damn... That sucks!
...details on the charger you used?
'21 M2C Hockenheim Silver
'18 718 Cayman S Lava Orange (sold)
'13 E92 M3 Santorini Blue (sold)
'07 Z4 M Coupe Alpine White (sold)
      10-26-2012, 12:17 PM   #29
Finnegan
Dog Listener
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
Whoa!
Man, really sorry to hear that.
      10-26-2012, 02:05 PM   #30
Jumbosock
Jumbosock's Avatar
76
I'm an idiot. Even though there is voltage protection they plainly say not to use a trickle charger on their batteries. I am just glad I didn't burn my car down. I am not sure if I will buy another one. After further reading there are too many limitations with the battery as far as charging and jump starting. Here is info from their site:
Can you jump start a dead lithium ion battery?
No. Lithium ion batteries are especially susceptible to cell damage when they are empty. A good lithium ion charger will actually “soft start” and roll the output current back when it detects a lithium ion battery at a very low SOC. This being the case, jump starting would send an uncontrolled amperage into a very low lithium ion battery. Bad idea. Don’t do that. Use a lithium ion battery charger or a 12V AGM charger at its lowest setting (1~2A) and slow charge the Lithium Pros battery back to 20% SOC. After that it can be charged like normal.
Do I have to buy a special charger?
Not really. 12V Lithium Pros batteries can be charged with any voltage regulated battery charger without a desulfation mode. Trickle chargers should not be used. AGM type battery chargers are highly recommended since the finishing voltage is regulated and typically lower than for a flooded lead acid battery. At no time should the battery charger exceed the max amperage and voltage rating on the battery.
      10-26-2012, 02:16 PM   #31
Jumbosock
Jumbosock's Avatar
76
I'll post some melted pictures later. It looks scary.
      10-26-2012, 04:47 PM   #32
WestCDA
Look forward to seeing the pictures, and thanks for posting the limitations. If I'm ever caught away from home with a dead battery, the ability to jumpstart is a necessity for me. Not very practical in a grocery store parking lot to find a low amperage charger (and available power), then wait for the battery to charge back up so you can carry on ...
      10-26-2012, 05:30 PM   #33
Jumbosock
Jumbosock's Avatar
76
Again, I hooked it up to a trickle charger when they tell you not to. I was just really dumb and hooked it up without checking.
      10-26-2012, 05:34 PM   #34
Finnegan
Dog Listener
Finnegan's Avatar
Wow. Scary stuff indeed!
I agree, it's lucky this is all that happened. Could have been much worse.
Crossing "lithium battery" off my list!
      10-28-2012, 01:20 PM   #35
WestCDA
I'd have a word with the battery manufacturer if I were you. Yes, they have a mild warning on their FAQ that 'Trickle Chargers should not be used'. However, they also state:
Second, every lithium ion battery has (or should have ;D ) a battery management system. This system checks for high voltage, low voltage, over current, short circuit, or over temperature. If these conditions exist the BMS literally disconnects the battery from its load and turns off the output terminals. This mini-computer inside a battery adds cost especially if it is sized to handle your starter! For this reason larger lithium ion battery packs are usually less expensive per watt-hour than smaller ones.
I'd say the 'battery management system' in your battery failed rather spectacularly - looking at your pictures, I'd say it's a safe bet that at some point yours was 'over temperature'?
      11-24-2012, 08:45 AM   #36
inTgr8r
inTgr8r's Avatar
2432
Drives: M2 Comp
Updatess?
I know there are more of you out there
      11-24-2012, 03:17 PM   #37
F360C
Drives: E86 S54
I am running the Odyssey PC680 along with a custom mount i fabbed up from some aluminum. The battery weighs about 15lbs and the mount can't be more then a pound. I don't keep it on a trickle charger but it will hold a charge for at least two weeks in a none heated garage.
07 Z4 M Coupe AW/IR
      11-24-2012, 08:11 PM   #38
inTgr8r
inTgr8r's Avatar
2432
Drives: M2 Comp
Nice
Ill likely do something similar.
I don't really need trunk space so I'll leave it in the OE location.
      11-24-2012, 08:26 PM   #39
F360C
Drives: E86 S54
Originally Posted by inTgr8r View Post
Nice
Yeah I didn't need the trunk place either so I just stuck with the stock mounting location. The mount I made is rock solid for the little bit of aluminum I used. I can grab the battery with my hand and rock the car.
07 Z4 M Coupe AW/IR
      11-25-2012, 09:04 PM   #40
inTgr8r
inTgr8r's Avatar
2432
Drives: M2 Comp
Originally Posted by Finnegan View Post
This will be a living document that members can update and also refer to. It's only going to be as useful as folks make it, so, please participate!
Here is a link to a Google Spreadsheet. Link allows editing, you don't need to be a Google user.
Instructions: Please add your information, and note forums username and update date.
Care to plug in your data
      11-25-2012, 10:21 PM   #41
Incompatible
Drives: 07 AW Z4C 3.0Si
F360C, can you be specific on what submodel Odyssey PC680 you used? There appears to be several variations. Thanks
If you can't take the time to teach a kid something good, someone will take the time to teach them something bad.
      11-26-2012, 03:40 AM   #42
SmartBastard
Stupid as shit
SmartBastard's Avatar
Austria
26
Drives: '08 M Coupe
Great list, good job guys!
I had to replace my battery back in August, because the original OEM battery started to "grow" and acid was pouring out of it, I'll add the battery I replaced it with next weekend when I'm in my winter-sleep-garage.
      11-26-2012, 12:33 PM   #43
3002 tii
3002 tii's Avatar
2286
Drives: Z4 M, X5, GX460
I went with Autozone's Duralast H6 AGM for $159.99 for my 3.0si
http://www.autozone.com/autozone/par...er=319460_0_0_
Follow for latest mods
      01-24-2013, 07:24 AM   #44
CJW2OO4
CJW2OO4's Avatar
Drives: E86M,M2,F13 E86&E85M,E86,2E46
Does anyone know if a 94r battery fits in our cars? (Same battery as e46)
battery
zpost
