N55 VANOS Bolt Failure Prevention
10-17-2014, 07:08 AM | #289 |
112
Rep 159
Just FYI- I had my valve cover gasket replaced when the recall was performed but it wasn't listed on the service receipt as related to the vanos work. Just said an oil leak was observed during the standard inspection. I wasn't there to ask questions when picking it up but figured they might have been padding the books with warranty work. Either way I'm happy to have it replaced free of charge.
They did replace the oil but not the filter it seems. They didn't reset the service interval for oil either so I will be taking it for another free change in 4000 miles 😄 |
10-17-2014, 08:36 AM | #290 |
Rep 209
Does anyone know if the charge pipe has to come off for this recall? After getting mine done my car was intermittently shutting off on me at stops and even in motion. I took it back to the dealer and they said the "charge air pipe grommet" came loose and was causing this. I haven't heard of this and suspect that the dealer dropped the ball on something during the vanos recall process. Another forum member had their recall done and they forgot to tighten the spark plugs. My warranty is up and I just don't want to get charged for something they shat the bed on
http://www.e90post.com/forums/showth...7#post16785517 |
10-17-2014, 09:46 AM | #291 |
Initial G
Rep 41
I had the vanos recall done a few weeks ago and have a BMS CP. So before the work was done, I told my SA about the CP and asked if there was any need to remove it and replace with the stock one (previously, one of their techs recommended that I put back on the stock one just in case BMW of NA happened to be walking through their service bays - he was paranoid about BMW of NA voiding warranties apparently). The SA said that I could leave the BMS CP in place and that the work didn't affect that part of the engine.
10-17-2014, 09:52 AM | #292 | |
1204
Rep 2,818
Don't blame the dealership for shit that was already bound to go bad on your POS regardless. |
10-17-2014, 10:43 AM | #293 | |
Rep 143
10-17-2014, 11:44 AM | #294 | |
Rep 209
10-17-2014, 03:45 PM | #295 | |
Rep 75
10-17-2014, 03:53 PM | #296 | |
1204
Rep 2,818
The only part required is a new valve cover gasket and 8 new bolts. That's all UNLESS there are issues with either the exhaust or intake units such as bolts being loose or sheared off already. They do not replace both units "just because they're already there." BMW won't reimburse for that. |
10-17-2014, 04:11 PM | #297 | |
Rep 75
10-17-2014, 04:39 PM | #298 | ||
Oh rly?
46
Rep 339
Yep
Got my car this morning and the only thing it was changed was the bolts and new valve cover gasket. |
10-18-2014, 08:01 AM | #299 | |
Is it the shoes!?
3884
Rep 5,112
Be less of a condescending asshole next time you attempt to say something constructive. |
11-03-2014, 12:20 PM | #300 |
Rep 6
After reading about the vanos bolts problem I called my local dealership and was advised there is a recall for my 335i October 2010 build, didnt receive a letter, glad I phoned them !!
11-03-2014, 12:24 PM | #301 | |
Rep 10,120
11-03-2014, 12:26 PM | #302 |
Rep 1,086
Drives: '11 335i M-Sport [LeMans Blue]
I never heard from my dealership so I called today and get scheduled to have the work performed next week. They indicated that it is a "2 day job".. hum?
In 2,500 miles I am in need of maintenance; oil, air filter, and spark plugs. I had asked if they could do that work at this time and they said it might be a possibility. What are the chances of them doing the maintenance work now - I really don't want to take it back in a month.
'11 335i M-Sport xDrive Coupe [LMB] COBB V3 & PTF Tune | E45 |4in BERK DP | VRSF 5in FMIC | BMS Intake | ER CP | Exotics Tuning CF Lip | CF Diffuser | Eibach Springs | Bilstein Shocks '07 BMW 335i Coupe & BMW Z4 3.0i - Gone |
11-03-2014, 07:28 PM | #303 |
Rep 75
Exhaust vanos unit must be removed in order to get to the bolts. As far as I know, dealer changes two new vanos units. There is no part number for the bolts, they come bolted already on the new vanos units.
11-03-2014, 08:18 PM | #304 | |
687
Rep 2,770
2008 Honda S2000 - Current
2016 F80 M3 - SOLD!! 2011 e92 X-Drive Coupe - SOLD!! |
11-06-2014, 09:59 PM | #305 |
Rep 1,132
Had my recall done this past Monday, no mention on the paperwork of anything other than various bolts and a gasket.......... But my car do seem as though it's more responsive and my surging in reverse has seemed to have disappeared. I should add that I dropped it off at 8am and it was not done until 5pm. ( I was there at 4.45 and the tech still had the hood open and typing on his workstation computer....? )
11-06-2014, 10:41 PM | #306 |
Rep 537
Got the call from the dealer today about the recall. They said to schedule a loaner vehicle because it may be longer than a full day job.
Brandon
11-10-2014, 04:30 PM | #308 |
Libertarian
132
Rep 1,577
Just got my second VANOS letter. Hopefully the loaner is a 435i. If they are going to keep my car for a couple days, I'll rack up a thousand miles on it!
2011 335xi Coupe BSM (e92/N55/ZPP/ZCW, Alpina B3 Flash)
Bought 08/09/2013@53,340mi Current 3/13/2019@206,283mi Fail(s): tstat hous/water pump 89k, Chargepipe 106k, coolant tank 114k, FRM3 114k Maint: Walnut blast 101k, Trans/T-case Fluid 103k, OFHG 195k |
n55, solenoid, vanos |
