N55 VANOS Bolt Failure Prevention
04-05-2014, 10:07 AM | #133 | |
Rep 1,409
2011 X3 35i with M pack + 2011 135i w/6SPMT | 255 square tire setup | Quaife 3.46 LSD | Diff lock down bracket | Bilstein B8+Swift SpecR springs+H&R FSB | CDV delete | BMS Oil Tstat bypass | ER FMIC & CP | N54Tuning DP | GC Street Camber Plates | M3 FCA +guide rods+RSFB's+Tranny mounts | Manzo toe arms | Cobb Stg2 agressive tune | Hawk DTC70 brake pads | RB SS brake pistons | Goodridge SS brake lines | Custom brake cooling ducts
04-05-2014, 10:20 AM | #134 | |
98
Rep 292
i sent another letter in. let's see where it gets me |
04-06-2014, 02:04 PM | #135 |
Rep 16
VANOS
Hi,
I have a 2011 335i with the N55 production date 04/10, so I am certain my car is impacted... I sent a e-mail to BMW NA, I talk about the recall in China, the fact that they know there is an issue by their TSB (is that what is call?) and perhaps we should point out the potential to loss of life, due to a sudden loss of power in the letters as finding yourself on say, an overpass in the middle of the night with reduce or no power could be a serious problem... Any how, did anyone figure out if the bolts could be replaced without removing the VANOS units, by removing one bolt at the time? It appears that the real issue is the bolts, I don't understand why the whole VANOS units are being replaced, unless no action is being taken before damage occurs due to bolt failure. |
04-08-2014, 07:39 PM | #136 |
Rep 3,189
Hi all, figured I would make my first post to document the sheer luck I had. Picked up my 335i a week and a half ago. Drove it for three days and on the third as I was merging on to the high way, check engine light came on. Took it to the local dealership and sure enough it was a vanos bolt failure. The lucky part being that I still had 3600 miles left on the warranty. Figured I would just add to the list as it has a build date of 7/10. I will be writing a letter to BMW NA as I can't imagine how pissed off I would have been if it was out of warranty.
04-09-2014, 07:28 AM | #137 | |
98
Rep 292
I wish this would happen to me under warranty! |
04-10-2014, 11:51 AM | #138 |
Guest
Rep n/a
Drives:
04-10-2014, 12:25 PM | #139 | |
enthusiast
117
Rep 997
Drives: 2011 e92 lci 335xi
04-10-2014, 03:15 PM | #142 |
98
Rep 292
The bolt heads snap off and oil squirts out of the hole (inside the motor) thus causing a drop of oil pressure in the VANOS actuator which in turn prevents it from controlling the cam as well as it needs to. The ECU detects this and throws a code. Eventually, all the bolts can snap off and bad shit can happen as a result.
04-10-2014, 04:18 PM | #143 |
Rep 929
Drives: 2011 BMW 335i xDrive manual
I called my SA as well to find out when I can get it done. Seems like it hasn't hit the dealers yet but he said that he put me on a list that gets checked weekly for recalls and that I should be expecting a call as soon as they get it.
04-10-2014, 04:40 PM | #144 |
17
Rep 170
WOW, I just left my car for service yesterday and I was talking to my service agent, who is my friend, about the bolts problem. We had to put on some specific wording so that they could check it out. But now, I'll call him and tell him about the recall. hope I get the job done right away then, I mean, my car is already in for service, LOL!!
Alpine White 2011 335i M-Tech Coupe, AR Downpipe, N55 JB4 Stage 2, ER Charge Pipe, BMS Intake, Front 10mm Spacers, Rear 12mm Spacers, Red Air-Scoops, Tee Mod, All Windows Tinted.
04-10-2014, 09:35 PM | #147 |
29
Rep 57
Wife's 7/10 build 335i sedan (37K miles) threw the "Engine Malfunction - Reduced Power" light 3 days ago. Took it right to dealer as car is under factory warranty. First they replaced HPFP as car threw that code.
Then they kept it an extra day to try to chase an intermittent TPMS issue. Instead car threw SES light and code 2D55. In the service notes its says "Removed Cylinder Head Cover. Inspected and found 2 bolts to intake vanos unit loose. 1 other bolt broke away. Removed intake cam, recovered broken piece successfully. Reinstalled intake cam. replaced both VANOS adjusting units as outlined in SIB 12-14-12" Get your car into the dealership ASAP! We bought this car brand new and my wife drives her car VERY gently... If it can happen to her, it can happen to anyone! |
04-11-2014, 12:53 PM | #148 |
Rep 48
Add me to the list.....
2011 N55 335i. popped up code ND55 and have an appt next thursday to bring her in to the stealership. I'm at 41,000 miles and will show up armed with the SIB that relates to this. Question to those that have gone through this already: Because its an SIB, does that mean that i should expect BMW to cover the costs due to the known issue? i bought the car second hand, so i am not the original owner and i it is NOT a CPO. Or does the fact that there is an SIB only exist to show the tech's how to address the issue when it comes into the garage, with the full cost exposure going to the customer? thanks |
04-11-2014, 01:35 PM | #149 |
Rep 929
How are you not under factory warranty? Your car is within the 4 years and 50k miles. The factory warranty is tied to the car not the owner.
04-12-2014, 08:03 AM | #150 |
Rep 459
04-12-2014, 09:51 AM | #151 | |
Libertarian
132
Rep 1,577
2011 335xi Coupe BSM (e92/N55/ZPP/ZCW, Alpina B3 Flash)
Bought 08/09/2013@53,340mi Current 3/13/2019@206,283mi Fail(s): tstat hous/water pump 89k, Chargepipe 106k, coolant tank 114k, FRM3 114k Maint: Walnut blast 101k, Trans/T-case Fluid 103k, OFHG 195k |
04-27-2014, 08:22 PM | #152 | |
Rep 9
Follow up: Vanos bolt failure
05-06-2014, 09:21 AM | #153 | |
Rep 48
Car is currently at the dealer. my SA just informed me that the "VANOS adjustment units" are the cause of the issue and will be replaced (under warranty) I told him i want to know if any bolt heads were sheared, and if so, where all of them recovered. the car also is exhibiting a long crank at engine start. I told him i suspected it was due to a failing HPFP. My SA informed me that the Tech thinks the long crank could be related to the VANOS issue. either way, i'll keep you posted. |
05-08-2014, 07:31 AM | #154 |
Rep 9
NY Times, 4-10-2014. BMW recalls 156,000 US cars for vanos problems.
http://www.nytimes.com/2014/04/11/au...ines.html?_r=0 BTW, my x5 small check engine light is on...just got it back from dealer for a month long vanos system replacement. Nothing on the computer says anything is wrong. Good grief! |
n55, solenoid, vanos |
