CIC/NBT FSC Generator - Windows/Linux/OSX
04-07-2018, 05:32 PM | #23 | |
Rep 6
A like help the komunity How kann a send you a b1 file? from F10 (2010) |
05-04-2018, 05:12 AM | #26 |
Rep 41
generator issue
hi there
after extract the 1b file using the USB copie_scr.sh method I have the following error message with this generator: "Incorrect RSA Key Header/Footer File Likely Corrupted" can you help me solve this? my FSC.hex is: Code:
0101 001b 0001 2020 3939 3939 3939 0220 3939 3939 3939 3930 2020 2020 0141 3438 3532 3435 0100 0000 0000 0000 0000 0402 3230 3130 3033 3233 3030 3032 5a00 810c 80de bf80 3cf7 6526 b566 4915 99bb 910a dcbf f453 2282 9347 3309 8ad7 9cfb fb4c cfa4 b3b5 8ea7 7f8d a009 d7f4 fd63 818f ecba 6a17 3f84 ee2b 3799 b954 2f8a 43f5 9b56 d43b e5c4 8326 c1a2 10c1 3f67 2d49 7159 d142 c466 dc52 7dc6 20ed 6ed3 e59e d248 f731 5137 cd0c 0109 e14f 3ff3 cdee d0cd dc08 87f5 1769 467c 7f52 600a a228 de00 d929 cca2 490d 1e9c 3420 a8f5 9f1c a4fc f7c7 72fd 5c9e 6051 36f0 3e4f 6a77 6cc6 9300 78dd 9e89 ef8a 366d 4df2 d5f7 294b 14c6 7ce4 7b7b 6cb2 318e 3c51 7185 c7fc 37e2 ebb1 3b74 f732 371a af1a 546b 1b2f 526b a106 9f40 0828 8bd7 78e2 035b d94b 8502 acb9 9897 fc61 2ff0 e6ec c764 17bb 3852 b902 cec4 27ae 21b1 9cd9 1f Code:
AQEAGwABICA5OTk5OTkCIDk5OTk5OTkwICAgIAFBNDg1MjQ1AQAAAAAAAAAAAAQCMjAxMDAzMjMwMDAyWgCBDIDev4A892UmtWZJFZm7kQrcv/RTIoKTRzMJitec+/tMz6SztY6nf42gCdf0/WOBj+y6ahc/hO4rN5m5VC+KQ/WbVtQ75cSDJsGiEME/Zy1JcVnRQsRm3FJ9xiDtbtPlntJI9zFRN80MAQnhTz/zze7QzdwIh/UXaUZ8f1JgCqIo3gDZKcyiSQ0enDQgqPWfHKT898dy/VyeYFE28D5PandsxpMAeN2eie+KNm1N8tX3KUsUxnzke3tssjGOPFFxhcf8N+LrsTt09zI3Gq8aVGsbL1JroQafQAgoi9d44gNb2UuFAqy5mJf8YS/w5uzHZBe7OFK5As7EJ64hsZzZHw== Code:
AQEAGwABICA3NzM0ODcBIDI4NzM4NjMAZQFBMTcwMzA3AQAAAAAAAAAAAAQCMjAwOTA5MTQxNzU2WgCBDIBkLeLqyFDLoud0AWuZEJfZUXID9jqfjGNKTHt3pezeziEsmbhurCmabg1JR+oqt6iPnoy7KojsGut1ngS9y+QdqiL1buw5AZTxDNjsBIStf5YlKqrLo+5+k5SNHd4PgrobK2ovcpgkLB/TaXubRf3pN1aFbEiUtGkNocvU5GqIHwCTCY9nAEe0o+bVOnUTmTq9nd/AWACGnqlbg0u8iIh29+0eqUuDfwLbPIF/vCufFkHKd2mN0LzhRryym/a9Nmr+lyzb6oA+uV0wvdFmbcRR42FiyJGNNsgjykWcHTIcN4BXSVp9b5asg7OP0vTb8X9C2Fh8lWNQDG1SDAUoKBdqSg== |
05-04-2018, 06:40 AM | #27 |
430
Rep 170
The FSC.hex file doesn't appear to have been pulled correctly.
It looks like there are bytes inserted into the header between positions 0x17 and the start of the VIN at 0x1D. (VIN should start at 0x1A) I've removed 3xBytes to align the VIN, and RSA keys within the file. (Rename AstroZ.pdf to AstroZ.hex) ***This file will generate a key, but they code may not work as "File Likely Corrupted"*** |
05-04-2018, 11:43 AM | #28 | ||
Rep 41
But it could have been any of script activated or emulator (100% has a emulator) or self signed certificates or perhaps my USB stick (32GB sdcard with adaptor) Quote:
it worked though updating the maps to 2018-1 via the same 32GB SD card using the generated lifetime code. thanks for this EDIT: finished updating Last edited by AstroZ; 05-04-2018 at 12:02 PM.. Reason: EDIT: finished updating :) |
05-06-2018, 08:28 AM | #29 |
Rep 6
Hello, maybe someone can help me to get FSC code? I have 1b file from my car, but then I add it on "BMW_CIC_FSC_Generator" I can't select region and maps.
05-06-2018, 10:30 AM | #30 | |
430
Rep 170
1. The generator defaults to premium, but requires you to set the map type first. Click on "Premium" and a dropdown will appear. Select the type of map you need 2. You don't have internet connectivity. An error message should have popped up telling you that it couldn't download support files. |
05-06-2018, 11:20 AM | #31 |
Save the manuals!
6019
Rep 6,750
Whenever I launch the FSC_generator.EXE it just opens a MS DOS window which shuts itself down in one second. Any idea what is wrong here?
'16 M3 | '23 718 Spyder Past: E92 M3, F87 M2, E39 M5, etc |
05-06-2018, 12:54 PM | #32 | |
Rep 6
05-16-2018, 06:09 AM | #33 |
Rep 6
Hello maybe somebody can help me.
I am driving a E92 with CIC Navigation (Navi Prof). I successfully got my 1B File. I am trying to update my MAPS to Europe Premium West 2018.1 with (1x USB) I generated about 5 different FSC (with and without lifetime) and so on. I plug in the USB some seconds later the Navi Prof recognize the USBUpdate and want the FSC. But it altways says invalid FSC... I tried the method with jaegers generator and the other one with changing the FSC.Bat to 0x28 0x10 Smb may know where the Problem is? |
05-16-2018, 06:28 AM | #34 |
430
Rep 170
ExiizZ
Is your CIC set up with Europe Premium West? If your CIC came with a different map type or region, you will need to add that FSC to your CIC before you can update the maps. ( https://cartechnology.co.uk/showthread.php?tid=23198 ) If you have a retrofit CIC, the 1B file retrieved may not match what the CIC is expecting. (Emulator, Script Activation...) |
05-16-2018, 07:46 AM | #35 | |
Rep 6
Without any West or East. Can this be the failure? The NAVI Prof was standard no retrofit Last edited by ExiizZ; 05-16-2018 at 07:58 AM.. |
05-16-2018, 08:49 AM | #36 | |
430
Rep 170
The GUI Generator will automatically grab the correct values out of the Lookup.xml file, but if you want to use the DOS version, the values should be 0x28 0x2D Code:
<SgbmId id="NAVD_000004CE_255_004_194" SWID_FscShort="0028002D" name="Road Map Europe West PREMIUM 2018-1" supplier="NTQ" sop="01.09.2017" |
ExiizZ1.50 |
05-16-2018, 09:44 AM | #37 | |
Rep 6
06-02-2018, 06:07 AM | #42 |
430
Rep 170
@Aaronexx - Both the links and the generator are working. (It's really easy, if you use portalseo's USB stick method to get the 1B file)
06-10-2018, 05:41 AM | #43 |
Rep 10
help
can anybody help me please.
My FSC generator give me a codes but they dont work. I have 2010 CIC with europe premium 2009-2 and I like to update to europe east premium 2018-1. Can someone find me a fsc code that works. MY VIN is: VJ95858 |
