06-06-2010, 02:27 PM | #67 |
Rep 912
"equipped with Macht Schnell Competition Spacer kit: (18mm front, 15mm rear)"
is this safe? i would imagine 18mm longer studs to raise some safety issue in addition to strain on the hub since the center mass of the rim is being pushed outward. but what do i know. some insights would be appreciated since i want a flush setup but afraid of potential prolonged issues. Last edited by bavarian06; 06-06-2010 at 02:32 PM.. |
06-06-2010, 02:54 PM | #68 | |
8252
Rep 18,839
Drives: BMW
We typically do not recommend running larger than a 20mm spacer (regardless of application) without moving to an adapter setup - or preferably, moving to a wheel with a different offset.
06-20-2010, 11:54 PM | #70 |
117
Rep 275
Just had Eibachs installed with 15mm front and 12mm rear spacers.
06-21-2010, 11:27 AM | #72 |
257
Rep 4,048
06-22-2010, 11:44 AM | #75 |
548
Rep 5,695
06-28-2010, 02:00 PM | #77 |
548
Rep 5,695
Yes we sure have!
06-29-2010, 04:32 PM | #78 |
Rep 99
What spacer sizes did you use for that comp package m3?
2011 M3 Coupe; Brilliant White/Amarone; Competition, Tech, Premium Packages; Everything Else...
07-02-2010, 12:49 PM | #79 |
548
Rep 5,695
07-02-2010, 01:46 PM | #80 |
Super modder
104
Rep 1,973
How much for an E90 M3 - 18mmF and 12mmR - MS type
Thanks! M
SOLD - 2005 E46 M3 ZCP - I/B on black CURRENT - 2011 E90 M3 - meticulously modified 2015 X1 Xdrive 28i |
07-06-2010, 05:01 AM | #82 |
Rep 1,245
could you go even more aggressive? Did the 12mm front and 5mm rear result in the wheels being flush with the fender?
I am really interested in doing this as well...
2011 AW/FR Extended E92 M3... fully loaded
07-12-2010, 09:15 PM | #83 |
Rep 1,245
07-13-2010, 11:35 AM | #84 |
Rep 1,159
Here is one dilema you may run into with larger than 5mm rear spacers. Since the rims are 1/2 wider it allows you to put wider tires on in the future. Once the tires wear out I no doubt plan on going wider. With that said. If you go 10mm rear and they are flush with the fender with stock tires, they will obviously rub if you go with wider tires. I am just using random spacer sizes but I think you get the point. That is why I am going to hold off on getting spacers.
07-13-2010, 12:17 PM | #85 | ||
8252
Rep 18,839
Drives: BMW
07-23-2010, 06:55 PM | #86 | |
Rep 1,245
For someone who is going to keep the oem tires with the zcp wheels, I am guessing you would recommend 15fr and 10rr?
07-26-2010, 12:22 PM | #87 |
548
Rep 5,695
07-26-2010, 04:46 PM | #88 |
Rep 1,245
david, that is the setup you used on the zcp m3 you guys did with the wider tires. Tom (a few posts above) mentioned that oem tires would need a more aggressive spacer setup.
I would like to make them as flush as possible. When I eventually change my tires for a wider stance, I will change my spacer setup if needed...
