BMW M3 Forum (E90 E92)
European Auto Source (EAS)
      05-22-2019, 12:17 AM   #23
derbo
Derbo Tuning
derbo's Avatar
3610
Drives: BMW M3
I have to say this is awesome to keep some sort of tire pressure check without sensors in the wheel. During my post track day drive home, I got a warning that my tire was low. Sure enough my valve stem inner core was failing! Luckily I had the pump and it was a slow leak and I made it home safely.
IG:ruhrohz_m3
Journal: Link
E9x ZCP Suspension Info: Link
Track Chat Discord: https://discord.gg/VsKbTyqBVj
SF Bay Area: DM For coding services
DrFerry6728.50
      05-22-2019, 01:09 PM   #24
nolaman1970
Drives: 2011 BMW M3 E93
2011 BMW M3  [0.00]
External TPMS Sensors.
I recently installed an Avin Android display, one of the options I ordered was the TPMS External Sensors. They are valve stem mounted with batteries that are replaceable. So now I can see my tire pressures. They sell internal and external for their system. Overall I am happy with the Avin, a few minor quirks with the "M" button stopping the audio, brings you to the I-Drive screen. Love having Waze on the screen.
      05-22-2019, 01:25 PM   #25
derbo
Derbo Tuning
derbo's Avatar
3610
Drives: BMW M3
That is interesting. I wonder if it could be compatible with BMW TPMS (probably not). I really don't want to deal with an aftermarket head unit at the moment.
IG:ruhrohz_m3
Journal: Link
      11-27-2019, 07:35 PM   #26
Coolhydro
14
Drives: Ducati , f30 335i sport
Can this be done using BimmerCode’s expert mode?
      11-28-2019, 01:52 AM   #27
derbo
Derbo Tuning
derbo's Avatar
3610
Drives: BMW M3
I'm not sure. I've only used BimmerCode with cars that were compatible with ESys. I haven't used it with an e89 chassis yet.
IG:ruhrohz_m3
Journal: Link
      06-18-2020, 02:17 PM   #28
///Mobbin
///Mobbin's Avatar
1478
Drives: m3
derbo sincerely appreciate the write up, worked like a charm on my e92 m3!
Originally Posted by derbo View Post
MK60_M3 is M3DSC
Was going to mention this difference applies to E9x m3’s, M3DSC is the name of the module
For my purposes I’m doing this for the track where my cold tire pressure is much lower than TPSM can cope with. Sometimes I start as low as 26 psi. Will be testing this out for track purposes in a few weeks and will report back.
2021 Alfa Romeo Stelvio Quadrifoglio | 2.9L | Trofeo White Tri-Coat | 8-spd
      06-18-2020, 11:39 PM   #29
derbo
Derbo Tuning
derbo's Avatar
3610
Drives: BMW M3
MK60_M3 is M3DSC
Was going to mention this difference applies to E9x m3's, M3DSC is the name of the module
For my purposes I'm doing this for the track where my cold tire pressure is much lower than TPSM can cope with. Sometimes I start as low as 26 psi. Will be testing this out for track purposes in a few weeks and will report back.
No problem!
It made sense to convert to FTM to save on buying tpms sensors without fully sacrificing some sort of tire pressure check.
I should edit the post to be that for future use.
IG:ruhrohz_m3
Journal: Link
      06-20-2020, 07:33 PM   #30
The-Traveler
Drives: E92 M3 & G30 530e
Anyone know whether this can be done in reverse? My Canadian spec car came with FTM but I really want specific tire pressure readings for a variety of reasons. If I get the sensors and module, would there be wiring there for it? Coding I can do, no problem.
EDIT: If you're going to throw TPMS module and sensors into the garbage, I'll offer $100 + shipping to Canada. Thanks.
      06-21-2020, 01:49 AM   #31
derbo
Derbo Tuning
derbo's Avatar
3610
Drives: BMW M3
FTM doesn't have wiring and I'm not sure if you have the wiring there for the RDC module. You can check the location to see if the cable is there from the original post. If they are there, it's possible but only one way to find out after that.
FYI the CIC won't show specific pressures like the new NBT in the F cars so I personally think it's probably not worth the trouble.
IG:ruhrohz_m3
Journal: Link
      06-21-2020, 10:20 AM   #32
The-Traveler
Really?! Half of the google images that show CIC have pressures, and half don't. Any idea why?
https://www.google.ca/search?q=bmw+c...=1334&bih=1466
      06-21-2020, 10:38 AM   #33
derbo
Derbo Tuning
derbo's Avatar
3610
Drives: BMW M3
https://www.google.ca/search?q=bmw+cic+tpms&client=safari&source=lnms&tb m=isch&sa=X&ved=2ahUKEwj72oC1mpPqAhW9TDABHUUACgMQ_ AUoAnoECA0QBA&biw=1334&bih=1466
Those are f body cars
IG:ruhrohz_m3
Journal: Link
      06-21-2020, 10:42 AM   #34
The-Traveler
Thanks
      06-26-2020, 05:44 PM   #35
cchen9_
VisionAutoworks
Drives: 2013 AW E92 M3 ZCP
Successfully did this as well yesterday. TY!
IG @cchen9_
      06-28-2020, 09:44 AM   #36
deadlyhate
Drives: BMW E90 LCI 335i N55B30
Hello,
I tried doing the same to my E90 LCI 335i (N55 engine) 2011, but with partial success.
I did the following:
1. Removed physically the RDC module
2. VO setting $2VB - Removed
3. VO setting $265 - Added
4. I was able to FA Write - CAS ( I did not write LMA, LMA, because they are not in my list)
5. Programmed the ECU
CIC: RPA_CIC
aktiv
CIC: RDC
nicht_aktiv
CIC: RDC_SAFETY
nicht_aktiv
KOMBI: RDC_ALIVE
nicht_aktiv
KOMBI: MMI_ENA_RPA_RDC
aktiv
KOMBI: RDC_VERBAUT
nicht_aktiv
KOMBI: DSC_MIT_RPA_CC
aktiv
KOMBI: RDC_DISP_SWITCH
nicht_aktiv
Unfortunately I do not have M3DSC or MK60_M3. I have DSC and when I try to read it I get:
Error in CABD! Look at CARBI.ERR and ERROR.LOG!
COAPI-2020: ECU does not answer: IFH-0009:No response from controlunit DSC_87
So basically I did everything without one(and final) step, because I cannot allocate it.
My CIC module now shows FTM instead of TPMS, but it is saying
Status: FTM system error!.
The vehicle check is saying OK, and I do not get malfunction error. However I want to be have it working (the FTM).
Does anyone have any suggestions/clues what I did wrong or what can I do to finish the process?
      06-28-2020, 12:01 PM   #37
derbo
Derbo Tuning
derbo's Avatar
3610
Drives: BMW M3
Originally Posted by deadlyhate View Post
Hello,
CIC: RPA_CIC
aktiv
CIC: RDC
nicht_aktiv
CIC: RDC_SAFETY
nicht_aktiv
KOMBI: RDC_ALIVE
nicht_aktiv
aktiv
KOMBI: RDC_VERBAUT
nicht_aktiv
aktiv
nicht_aktiv
I don't know the value in the non-M DSC but I would assume it would be related have the word RPA in it. If all else fails, you can just code your DSC with a blank .MAN file to reset to defaults with the new Vehicle order since you added $265.
Edit:
I found a variable that shows this in DSC_87 that looks like it should work.
Depending on your version it would be in the format of <version>_RPA
For example if your DSC_87 is version C08.
C08_RPA: wert_01 (Direct RDC) wert_02 (indirect RDC)
If you read yor DSC_87 settings and search the TRC file, you should be able to find this RPA value and change it to wert_02.
IG:ruhrohz_m3
Journal: Link
      06-28-2020, 12:36 PM   #38
deadlyhate
Edit:
Thank you for your quick response.
According to the full module scan (the initial one when you scan the CAS), I have both
C08_RPA
wert_02
and
RPA
aktiv
Already set to the "correct" ones.
I will "fight" it a bit more and will probably try with the blank MAN default reset.
Thanks again for the response!
      06-28-2020, 12:42 PM   #39
derbo
Derbo Tuning
derbo's Avatar
3610
Drives: BMW M3
C08_RPA
wert_02
and
RPA
aktiv
did you reset the FTM? initialize and drive?
IG:ruhrohz_m3
Journal: Link
      06-28-2020, 12:44 PM   #40
deadlyhate
Edit: Are you referring to the reset via the CIC menu? If yes - yes, I have. I still get the same error visualized on the (as on the picture). No other consequences
      06-28-2020, 02:03 PM   #41
derbo
Derbo Tuning
derbo's Avatar
3610
Drives: BMW M3
Did you unplug the TPMS RDC module?
I don't remember, but I think I had the same error and had to initialize and drive around for a bit and then it fixed itself.
IG:ruhrohz_m3
Journal: Link
      06-29-2020, 07:41 PM   #42
cchen9_
VisionAutoworks
I actually had the same (not exactly sure) error trying to do mine and made a post here, but figured it out lol. The DSC programming never took because my IGN wasn't "ON". Make sure your ign is ON while you read or write that module, it should read and write without any COAPI error. May sound stupid but coding the DSC module last according to the instructions, there had elapsed enough time for the car to turn off power.
Hopefully you figure it out!
IG @cchen9_
      07-03-2020, 06:36 PM   #43
The-Traveler
Were your individual tire pressures visible in iDrive before you removed this feature?
Anyone interested in donating their RDC module towards a good cause? Some jerk is drilling screws into my tires (5th time in 3 years) and only on the rears. I am now looking to retrofit TPMS as opposed to the RPA that Canadian cars defaulted to in 2011.
Thanks.
Not sure if wiring is there to be honest, but hopefully.
      07-04-2020, 03:18 PM   #44
cchen9_
VisionAutoworks
Thanks.
AFAIK the factory tpms does not show tire pressures, at least I never saw them.
IG @cchen9_
m3post
