BMW M3 Forum (E90 E92)
      07-30-2018, 11:37 AM   #1
amrazM
mTekMods
amrazM's Avatar
Drives: like a granny.
Power Steering Reservoir Upgrade
Small write up on what I did over the weekend, I upgraded my PS reservoir to the newer style unit found in the F series cars and also the 1M. Good solution to those who have issues with fluid expanding and finding their reservoir covered with dirt and oil.
I'm also selling these with the fitting pre installed and with clamps, I'll post another thread.
Old ugly one.
[IMG][/IMG]
New unit with fitting to make the unit PNP
[IMG][img][/IMG]
Sucking it dry
[IMG][/IMG]
New unit installed.
[IMG][/IMG]
2011 Frozen Black/Fox Red E90 M3 650+WHP
G-Power Supercharged
First DCT to Manual Conversion Worldwide
KW CS, BBS RI-A, BW Headers, Snow 2.5
ItsGary1457.50
      01-11-2019, 03:14 PM   #2
GORDON.M3
GORDON.M3's Avatar
1423
Drives: E92 M3 • F25 X3 M-Sport
Can you tell me the size of the fitting so I can make mine plug and play too? I'm going to check the local hardware store for it. Thanks!
INSTAGRAM: GORDON.M3
North American Mr12Volt Carplay/Android Auto Distributor
DINAN | EVOSPORT | VAC | ARP | RD SPORT | NEEZ | EIBACH | CSF | IND | BILSTEIN | KLASSEN | BREMBO | ENDLESS | BBS | BPM SPORT | PROJECT MU | EVENTURI
ItsGary1457.50
      01-19-2019, 07:39 PM   #3
burnrbr
Drives: 2017 M3 Comp DCT
Make sure you use two adapters so the original hoses go to the appropriate large and small ports. The large port is for pump supply and the small port is the return. This will ensure the higher pressure return from the pump is not shot up at the reservoir lid which will prevent fluid leakage.
      02-13-2019, 01:44 PM   #4
wyatth
3549
Drives: E90 ZCP
How's this working for you? Can you link to your PnP install bits?
      02-16-2019, 06:57 AM   #5
dv13
Drives: 2011 e90 m3
This is pretty cool. If you are looking for a less expensive/time intensive solution to the original problem of PS fluid spray leaks from the reservoir, you can get this from FCPeuro for $1.50
https://www.fcpeuro.com/products/bmw...et-32411128333
Lifetime replacement when it goes bad and it fits just about every car (e46s, e9xs, e70s....) through about 2013 or so, which comes in handy if you have multiples.
One minute DIY consisting of: unscrew cap, roll off old gasket, roll new gasket tightly up to top of cap, screw cap back on. Leaks gone for at least a few years! 😊
      05-14-2019, 03:37 PM   #6
wyatth
3549
Drives: E90 ZCP
Bumping this up ... any word on the PnP bracket or fitting?
      12-02-2019, 06:10 PM   #7
VtecforV8
17
Drives: 2010 E92 M3 6MT
Bumping this again myself. Would love to replace; the 1M reservoir is less than $40 from Amazon.
      12-02-2019, 09:35 PM   #8
GeorgeA
GeorgeA's Avatar
Drives: E92 M3
This is interested, exactly what hardware would we need?
      12-05-2019, 09:22 AM   #9
VtecforV8
17
I take it that the hoses are not long enough just to be switched, is that right? Anyone know the diameter of the hoses? If so, we can probably figure out this hardware thing ourselves.
      03-01-2024, 01:03 PM   #10
KRAZYE36
Drives: E36 M3, E46 M3, E90 ZCP M3
Has anyone figured out what hardware you need for this? I bought my 1M reservoir a few months back and I’m ready to install.
m3post
