BMW M3 Forum (E90 E92)
      10-02-2020, 04:09 PM   #1
Davisca455
Davisca455's Avatar
Drives: 2008 M3
Cabin Filter Housing Repair
Couldn't take it anymore and had to repair both of my cabin filter housings.
It appears that prior to my ownership, dealership techs had overtightened the fasteners, like 8 too many times, and "pooped" out the plastic mounting tabs.
I could have just purchased new housings for $181 each from Turner, but then there's the possibility they'd just suffer the same fate if I let other people work on my car.
Can't really argue with the price of a new one though, I certainly couldn't make one for $181, but I'm willing to find the next weak link in the housing with a permanent repair to the tab.
There might be an easier way to do this, but this is what I did.
I cut off the broken plastic tab right at the 90* bend, to leave the maximum amount of the vertical section of the tab (minus the thickness of the new tab).
(I later used the cut off piece of the tab as a rough gauge to give a bend angle to the new aluminum tab.)
After I cut off the horizontal part of the tab, I reinstalled the housing onto the car.
Carefully measured from the face of the vertical part of what was left of the tab, to the center of the threaded mounting hole on the cowl.
I wanted the aluminum to be behind the plastic, so after I made my measurement, I added the thickness of the plastic to my measurement, drilled the hole, radius'd the tip on the belt sander, then bent the aluminum tab to 90*, on the slight angle provided by the cut off part of the tab.
Did a test fit, then trimmed the vertical length and drilled for a pop rivet.
I used .077 aluminum sheet metal, a sheet metal shear, a sheet metal break, a drill, a vertical belt sander and a pop rivet.
Chris,
2008 E92
Appreciate 16
Ajolives922.00
wyatth3548.50
PACarGuy683.50
Space Fox1042.00
LPM37.50
trm005334.00
Johal E32163.00
Nairb167.50
DRLane3988.50
Z K1888.50
jun_e92140.50
      10-02-2020, 04:44 PM   #2
Ajolives
Ajolives's Avatar
922
Drives: E90 M3
2019 Audi SQ5  [0.00]
2008 BMW M3  [0.00]
Looks legit, paint it black and no one would bat an eye at it, unless you wanna admire your work, haha.
Davisca4552207.50
      10-02-2020, 11:56 PM   #3
romero1990
Drives: E92 M3, F25 X3
2017 X3  [0.00]
2009 M3  [0.00]
damn just right when I need it. thank you!
Davisca4552207.50
      10-27-2020, 09:40 PM   #4
Rabidcat77
Rabidcat77's Avatar
Drives: 2011 BMW M3 (E93)
Looks great! I have the same issue on mine, I'm thinking I'll do this over the weekend! Thanks for the idea on how to go about it...
Davisca4552207.50
      10-28-2020, 07:34 AM   #5
amrazM
mTekMods
amrazM's Avatar
Drives: like a granny.
Next step, timeserts in the windshield cowl as they always strip out.
2011 Frozen Black/Fox Red E90 M3 650+WHP
G-Power Supercharged
First DCT to Manual Conversion Worldwide
KW CS, BBS RI-A, BW Headers, Snow 2.5
Davisca4552207.50
derbo3610.00
      10-11-2022, 11:47 AM   #6
chenium
31
Drives: Porsche 911, 2010 E90 M3
Long shot since this is so old but do you have an idea of the length of the bracket? Both my covers have broken tabs and I unfortunately don't have the tools to create a bracket. My idea is to use what I can find from Home Depot or Amazon.
Do you think something like this might work? The slotted bolt hole is 5mm so I think the 8mm bolt should work fine. My concern is if the bracket is long enough to reach the bolt hole. Thanks!
https://www.amazon.com/dp/B09ST91HYG...v_ov_lig_dp_it
Hoping something like this will work, sure beats paying 200+ for each cover.
      10-11-2022, 12:28 PM   #7
Davisca455
Davisca455's Avatar
Drives: 2008 M3
They might actually work if you attach them to the front face of the vertical tab, rather the rear face like I did?
Chris,
2008 E92
SAMM3Y3085.00
      10-11-2022, 03:43 PM   #8
chenium
31
Thank you for such precise measurements! I think these have a good shot at working. These measurements should help me find some other ones to try as well. Thanks again!
One more question, does your bolt hole have some padding or does the bolt sit pretty close to that diameter? I may have to widen the bolt slot so it might be better for me to find an alternative solution.
Found another one I think I will try. The bolt hole isn't slotted so i'll have to get pretty lucky for things to line up:
https://www.amazon.com/Eliseo-Bracke...%3D%3D&sr=8-39
      10-11-2022, 06:41 PM   #9
Davisca455
Davisca455's Avatar
Drives: 2008 M3
https://www.amazon.com/Eliseo-Bracke...3D&sr=8-39
Only about .020" clearance.
Chris,
2008 E92
chenium31.00
      12-19-2022, 12:22 AM   #10
dpeete
18
Drives: BMW e92 M3
Did you find something that worked for you?
      12-19-2022, 09:12 AM   #11
chenium
31
I didn't find a DIY solution and unfortunately went and bought new covers from FCP. Figured that I could utilize their generous replacement guarantee when they inevitably break again.
      12-20-2022, 03:41 PM   #12
Z K
Z K's Avatar
1889
Drives: E90 M3, G20 M340i
Looks legit!
Now if there's a fix for where the housing mounts to the car vents. The two 8mm bolt holes are stripped from over enthusiastic tightening.
Auto Detailing Enthusiast!
      12-20-2022, 09:13 PM   #13
buldogge
151
Drives: '00 MCoupe, '11 E90 M3
Originally Posted by Z K View Post
Looks legit!
Drill and install brass plastic threaded inserts...either the solder iron in type, or the knurled/slotted ones.
These are also useful for the airbox threadings.
https://www.mcmaster.com/brass-inserts/
-Mark in St. Louis
      11-28-2023, 03:30 PM   #14
E90325M
E90325M's Avatar
Drives: 2011 BMW M3
2016 BMW X5  [0.00]
2011 BMW M3  [0.00]
Thanks for sharing this, I just found my two covers have the same broken issues.
2016 F15 X5 xDrive 35i Space Grey M-Sport - BM3 Tune/ER charger pipe/afe power dry panel filter.
2011 E92 M3 DCT MW - AA intake/Akrapovic slip on/Ohlins R&T/Stoptech ST60 and ST40/Underdrive Pulleys/Antigravity H6 40ah/Alpine Tune
      11-28-2023, 04:08 PM   #15
E90325M
E90325M's Avatar
Drives: 2011 BMW M3
2016 BMW X5  [0.00]
2011 BMW M3  [0.00]
Yes, I also found both of my two covers have multi cowl strip out. any timeserts tool to recommend to do this or change a larger screws?
      12-05-2023, 09:13 PM   #16
Davisca455
Davisca455's Avatar
Drives: 2008 M3
I just went with larger screws myself.
Chris,
2008 E92
E90325M475.00
      02-04-2024, 12:08 AM   #17
E90325M
E90325M's Avatar
Drives: 2011 BMW M3
2016 BMW X5  [0.00]
2011 BMW M3  [0.00]
End up I filled the stripped holes with epoxy and drill a smaller hole after it got dry and it works for me, but don't overtighten the screws this time, airbox don't need much power to hold them, they are not heavy.
TboneS541043.00
Davisca4552207.50
      02-04-2024, 12:23 AM   #18
E90325M
E90325M's Avatar
Drives: 2011 BMW M3
2016 BMW X5  [0.00]
2011 BMW M3  [0.00]
https://www.amazon.com/gp/product/B0...e?ie=UTF8&th=1
This solution is really works for me. please do it in a warmer day so the plastic tab won't easy to be broken.
DrFerry6728.50
Davisca4552207.50
      02-06-2024, 03:46 PM   #19
TboneS54
YNWA
TboneS54's Avatar
Drives: 2004 M3 6spd & 2011 M3 DCT
I simply used a bigger washer under the screw in order to better capture, and sandwich down, the plastic that remains on that "ear." It works fine. I like the epoxy idea too, but I may not even need to bother with what I've done. You can even find/buy black washers so it doesn't stand out visually.
/// 2004 Silvergrey M3 · Coupe · 6MT · Slicktop · zero options
/// 2011 Jerez/Bamboo E90 M3 · DCT · Slicktop · IG: @na.s54
m3post
