E92 N55 not hitting target boost
12-29-2023, 06:55 PM | #23 | |
Rep 696
That damaged peice is what people call the boost pipe (#16 in the picture) The part you linked is an aftermarket version vs. OEM. Nice that it's aluminum, but I see it doesn't have the hump hose on the outet that mates to the intercooler inlet. I'm still on my original oem boost pipe, so I'm not sure if you can swap the hump hose part of the damaged boost pipe on your car over to that one or not? Perhaps somebody else here knows? For sure an oem one would fit without issue. People don't generally have issues with the boost pipe failing like they do with the charge pipe that connects to the throttle body. But clearly yours failed. How does your charge pipe connection to the throttlebody look? That's usually what fails. Oh yeah, it probably goes without saying, but that damaged pipe looks like the smoking gun for your boost issue. I bet the smoke you saw before was actually coming from here. Still be good to check for other leaks once you fix this, but hopefully that resolves your issue. Last edited by wheela; 12-29-2023 at 07:13 PM.. |
12-30-2023, 12:07 AM | #24 | |
Rep 31
The boost pipe I've sent should actually come with a hose as I see on other websites. For the charge pipe - I've gone ahead and installed an ECS one today. Last edited by pwns; 12-30-2023 at 12:55 AM.. |
12-30-2023, 10:14 PM | #26 |
9
Rep 51
It's a little hard to see, but yeah that looks like your turbo outlet charge pipe that connects into your intercooler, if there's a crack there that's going to be a huge boost leak. And yeah you ordered the right part. Replace that and you should be good to go
02-05-2024, 03:56 AM | #27 |
24
Rep 69
Any update on this thread? I also have some air and boost leaks in that area that I need to get sorted!
02-05-2024, 04:58 AM | #28 | |
Rep 31
Did smoke leak test again and it was all good, no leaks. BUT still not hitting target boost…I’m dropping the car off at a good BMW mechanic in a couple days. I’ll keep you updated. |
02-05-2024, 04:15 PM | #29 |
24
Rep 69
I'll be interested to hear any outcome. I will also post my updates when I am able.
My leaks require replacement of parts 10, 15 and 16. I am also considering spending a silly amount of money on some intake parts. |
02-05-2024, 05:26 PM | #30 | |
Rep 31
I’ve never seen that hose you linked - wish I would have ordered that! If I were you I’d stay on OEM air intake - there’s plenty of threads stating that aftermarket CAE’s cause the car to run funny and have weird idles. Might have been same issue with me. I bought a used OEM intake and installed it. I would just upgrade the boost pipe since you’re replacing it and get a charge pipe. I’d also do intercooler, like I did since I was already there. This will bring you to stage 1+. All that’s missing is a downpipe for stage 2,2+. Keep up updated with your journey as well! |
02-06-2024, 04:18 AM | #31 |
24
Rep 69
Thanks, I will continue to update.
I'll stay with the stock intake, but it might make sense to replace the section from the intake to the turbo as per the part I linked to. However, it is a lot of money and part 16 isn't cheap either! I might just live with replacing the gaskets and clamps along with part 16 to keep costs down. I have been unable to find an aftermarket replacement for part 16 so far. I have already upgraded the charge pipe and am at MHD stage 1. I wouldn't mind doing the intercooler, but after just having replaced the HPFP, LPFP and LFPF filter/regulator my wallet is a lot lighter, and I need to replace the sensor on the HP fuel rail too! |
02-06-2024, 09:58 AM | #32 |
49
Rep 64
For what it's worth I'm getting 2BC0 and my charge pipe is slightly fractured and cracked at the throttle body side so have ordered a metal replacement which I should have fitted next week.
If this solves my 2BC0 I'll update and let you know. (2012 E92 N55 also with a rebuilt engine & reused stock turbo on 120k miles) I've also ordered the following o-rings to change as well: 13.71.7.568.031 11.31.7.791.469 11.61.7.791.470 I don't have MHD so don't have any logs to compare info unfortunately. |
02-07-2024, 04:08 PM | #33 | |
Rep 6
02-22-2024, 08:59 AM | #34 | |
Rep 31
-Cracked TIC pipe replaced with upgraded aluminum one -Charge pipe installed -Intercooler installed -OEM air intake installed instead of BMS Intake -HPFP,LPFP replaced -MAF sensor replaced -MAP sensor cleaned thoroughly -Boost solenoid replaced (pressure converter) -Crankcase vent hose replaced (looked old and taped together) -No apparent leak showing from DIY smoke test. (Does system need to be pressurized?) One random drive I was randomly hitting decent boost, then never hit again. Which made me think the boost solenoid was acting up the whole time. Replaced it, but did not solve my issue. LOG: https://datazap.me/u/pwns/hit-boost?log=0&data=4-14 *Currently after all those fixes, I still have rough idle, and no boost. RECENT LOG: https://datazap.me/u/pwns/still-no-b...og=0&data=4-14 My LTFT seems a lot better? Do you think my MAP sensor needs to be replaced? I've read it could cause lean issues although I have cleaned it thoroughly. Could it be coil issues? Spark plugs? Although my issue is a lean code? Thanks |
03-07-2024, 05:20 AM | #35 |
49
Rep 64
I'm waiting for my MHD adapter to be delivered then I'll take some logs as the new charge pipe didn't cure my 2BC0 and I don't think I'm hitting full boost most of the time.
03-07-2024, 11:17 AM | #36 | |
Rep 674
Decent compared to your other logs but still horrible unfortunately. It looks like it's taking a while to build boost and won't go past 10. Have you taken a look at your Wastegate Actuator? Or have you been hearing weird rattles? I suggest you take a look at it and even connect a manual vacuum pump directly to it and see if you can actuate it. I used to be Stage 2+ and randomly during last spring noticed that my car was slow. Took a log and I was way off boost. Could also hear weird rattling when I let of gas. I checked the usual chargepipe and other connections for major leaks but nothing. Next step was to test my wastegate but I didn't even need to. Quick peak at it and well I'll le the pictures speak for themself. I hope for your sake that the actuator is not rusted off like mine, because it was near impossible to change while not removing anything major. Or maybe I just suck.
TOTALED | 2011 E90 335i xDrive - BMS Cold Air Intake - ETS Charge Pipe - ETS 7" FMIC - MHD Stage 2+ - GFB DV+ - PE Mod - VRSF Catless Downpipe - xDelete - xHP Stage 3
2015 E84 X1 35i M-Sport |
wrevilo23.50 Malteser_wfj48.50 |
03-08-2024, 08:32 AM | #37 | |
Rep 31
Hey neighbour! WOW holy shit, I'll def take a look at my actuator - but I did just find out that I have the wrong injectors in from the rebuild lol. They put in EU6 injectors when my DME is programmed for EU5. I'll keep yall updated.. |
03-08-2024, 01:06 PM | #38 |
Rep 696
Holy crap, they put the wrong injectors in??? That explains the persisting lean codes... Not sure about your boost, I wonder if the DME will limit boost when lean codes are present? It would make sense to protect the engine... It will be intersting to see how everything performs once you get your injector issue sorted. Thanks for the update!
03-08-2024, 01:08 PM | #39 | |
Rep 31
It sucks to pay for injectors, but I’m exited to finally have it running. Would you know if all PWG N55’s use EU5 injectors? |
03-08-2024, 01:30 PM | #40 |
Rep 696
03-09-2024, 11:47 AM | #41 |
49
Rep 64
Cleared my 2BC0 and 2C42 and took these logs:
My first time logging and I think they look good for a standard car with no remap. Not sure when coils were last changed but they're Delphi https://datazap.me/u/lemansn55/07032...22-23-24-25-26 https://datazap.me/u/lemansn55/07030...ta=3-8-9-18-20 https://datazap.me/u/lemansn55/07032...data=2-3-18-20 https://datazap.me/u/lemansn55/07032...ta=2-3-4-18-20 https://datazap.me/u/lemansn55/07032...a=2-3-10-18-20 I've recently moved so am still finding the suitable roads to do a full 6.5krpm pull in 3rd and then into 4th (car is manual). I'm fairly new to the N55 too so can only assume the difference between my pedal being 100% and the throttle being at 100% is because of valvetronic? But thankfully I'm fitting boost and lambda target so I'm happy for now |
03-09-2024, 12:11 PM | #42 | |
Rep 696
Edit: Load% is mass airflow normalized as a percentage of cylinder fill. The tune has a table that correlates torque to load% vs. RPM. There are also modifiers thar adjust the estimated torque per load & rpm based on AFR, etc. Last edited by wheela; 03-09-2024 at 12:24 PM.. |
bmw335ie90535.00 Malteser_wfj48.50 |
03-13-2024, 11:31 AM | #43 |
Rep 4
Drives: 2011 E90 335i 6MT
Having similar issues on my N55e 6MT. The engine just got a rebuild but stayed with stock turbo, I'm making little to no boost, could someone take a quick look at my data log to see if there's a dead give away or any other concern that I have no knowledge of? Would be greatly appreciated!
https://datazap.me/u/dan1nugs/2011-e...og=0&data=3-13 |
03-13-2024, 02:00 PM | #44 | |
Rep 674
I saw in another thread you mentioned your wastegate was rattling. Try to check it from under the car and see if it still looks in good shape or if it's cooked, like in the pictures I posted above.
