Exhaust setups
02-07-2024, 02:06 PM | #1 |
Rep 38
Exhaust setups
Hi guys,
Looking to put a cat back on my 2011 e90 335 What are some of you guys running? I’m preferably looking for a 3.5” with resonator and muffler. Want something that won’t have a lot of drone or minimal but still loud. Let me know what you guys recommend thanks! |
02-07-2024, 05:31 PM | #2 |
28
Rep 161
I recently bought a Becker P catback for the E90.It does have a drone around 2k rpm. I think if you can get an x pipe with a resonator it should minimize drone. Planning to go alibaba valvetronic exhaust soon though.
02-07-2024, 06:23 PM | #3 |
Rep 38
Yeah I’m looking for something that will be direct bolt on and reputable not really looking for eBay or cheaper options tbh
02-07-2024, 07:14 PM | #4 | |
28
Rep 161
Turner or Bomiz has their valvetronic exhaust. They both have videos on their sound. Most exhausts are direct bolt-on if they have the flange to the downpipe unless you go custom or get a halfway kit. |
brodysbimmer0.00 |
02-07-2024, 07:43 PM | #5 |
Rep 38
I just feel like with those valvetronic they still don’t eliminate drone that much since it’s just mufflers no RES. I was looking at the turner tho.
02-08-2024, 07:41 AM | #6 | |
Rep 1,539
I used the generic stainless pneumatic valved exhaust. Pretty well built and cheap, paid around 220 $ cad. Mainly closed on normal driving. Also had a ''auto'' mode, the vacuum force is limited, so the flap opens with exhaust higher pressure. Yes you'll need a exhaust shop and a welder, but nothing expensive. I went : HFC + Vibrant resonator 18'' and pneumatic valved muffler Last edited by oVeRdOsE.; 02-08-2024 at 03:08 PM.. |
02-08-2024, 10:25 AM | #7 | |
307
Rep 394
Really makes the exhaust pleasing to listen to with no drone. MBRP makes some nice ones that are loops on the inside instead of baffles. |
02-08-2024, 01:25 PM | #8 |
Rep 3,645
N55 with downpipe and golf tee mod satisfied all my exhaust desires. IMO it sounded amazing, and better than any other car I've owned.
PE or PE mod is great 335is rear section will provide a similar sound for cheap VRSF exhaust is relatively proven but overpriced for what it is AE exhaust is by far the best exhaust for n5x but is discontinued--if you can find a used one, buy it Cobb is a cool design, my friend has one on his N55 and likes it |
02-08-2024, 01:59 PM | #9 | |
Rep 38
02-08-2024, 02:12 PM | #10 | |
Rep 38
02-08-2024, 03:13 PM | #11 | |
Rep 1,539
So you dont really enjoy it, and on a cold start you still annoy the neighbor. cut-out on the OEM exhaust line is a nice option too. |
02-08-2024, 03:16 PM | #12 |
Rep 3,645
Do you have a downpipe? If anything I wouldn't have minded mine a hair quieter but it was super fun and as loud as I'd ever want a street car
02-08-2024, 03:53 PM | #13 | |
Rep 1,539
it's loud and the sound is nice, but it wont scream at high rpm like my other cars do. on my N54 when the valve is open, the muffler is straight. And the channels in the muffler might act like a helmholtz resonator to limit drone |
02-28-2024, 12:42 PM | #14 |
Rep 60
I'm using the VRSF racing downpipes with the 3.5" VRSF catback + muffler delete. Have some clips on my youtube https://www.youtube.com/@Hauteknits
03-06-2024, 08:31 PM | #15 | |
Rep 38
03-13-2024, 01:45 AM | #16 | |
Rep 96
03-13-2024, 01:46 AM | #17 |
Rep 96
You are correct. The bomiz and turner sound practically the same to me, both drone/rasp below 3k without a resonator. The main difference is the h-pipe on the turner system vs the x pipe on the bomiz, and that turner uses electric instead of vacuum actuated valves.
03-13-2024, 01:49 AM | #18 |
Rep 96
Any chance you can help me with the process? I'm putting muffler bypasses in my system that are going to be similar to the f80 valvetronic exhaust, but I need to find a shop that wont pull my pants down over the price. Did you wire yours to a (single?) switch or did you use a remote?
03-13-2024, 01:54 AM | #19 |
Rep 96
I'd be lying if I said I didn't like their ecoboost race exhaust. Does yours sound similar to that? I know it will be different since that has 3" piping, but if it's close I might go with that over vibrant resonators.
03-13-2024, 07:25 AM | #20 | |
Rep 1,539
All in 3''. My muffler got indeed a remote to : open/close/auto. the control vacuum box is in the back of the car. Im planning to tear down the remote and integrate it in the oem dummy button in the car console. you have 3 main option for the muffler. - 1 single exit - 2 mufflers - 1 dual exit muffler. in example in this link (you can find those wayyyy cheaper on ali, same same) : https://valvedexhausts.ca/collections/valve-mufflers |
03-13-2024, 10:30 AM | #21 |
24
Rep 67
I've a Gravity Performance exhaust ready to fit to my car once I sort out some air and fuelling issues. It has a couple of small resonators and an X pipe, whereas the stock exhaust seems to lack resonators. Hopefully it will sound good without drone!
03-13-2024, 02:08 PM | #22 |
Rep 674
I had a VRSF catless downpipe and I did the Performance Exhaust mod on my stock exhaust but I made sure to put back the fiberglass insulation to supress unwanted reverberations.
Never had it drone, sounded smooth and loud enough, not to a point to be annoying and obnoxious on long drives, but still plenty of noise.
TOTALED | 2011 E90 335i xDrive - BMS Cold Air Intake - ETS Charge Pipe - ETS 7" FMIC - MHD Stage 2+ - GFB DV+ - PE Mod - VRSF Catless Downpipe - xDelete - xHP Stage 3
2015 E84 X1 35i M-Sport |
