BMW M3 Forum (E90 E92)
European Auto Source (EAS)
      03-10-2014, 04:32 PM   #89
kenwelch
Drives: 2008 E92 M3 M-DCT & 2017 440GC
Short of a Blackstone or other professional testing, the visual appearance and change of smell will often give you lots of information about the fluid. The more transmission rebuilding experience the observer has helps also.
Looking at a picture of used fluid and no observation of what is in the transmission pan and filter is not conclusive either. Smell-o-vision would help, I hear they are working on that.
      03-30-2014, 09:40 PM   #90
tinman831
Drives: M3
Does anyone know how to change the gasket on the pan on the side of the transmission? Seems like the upper bolts are almost impossible to get at without dropping the tranny? or am I overlooking something?
      04-22-2014, 05:10 PM   #91
S1RC
9
Drives: 2008 M3 Coupe
I'm looking at changing the fluid on my DCT soon, I've already purchased some fluid, getting ready to buy the filters when I stumbled on this post.
- Has anyone actually changed the filter (not the suction filter) themselves? It sounds like it's really difficult to get to.
- When changing the suction filter, do you have to replace the DCT oil pan gasket? It looks like the gasket is built into the pan so probably requires a new pan to replace.
I also found this post: http://e89.zpost.com/forums/showthread.php?t=442369
Sounds like (from that post) BMWNA doesn't suggest changing the DCT fluid and won't do it even on customer request. With my car being almost 100km and I'm unsure if it was changed, I'm debating now if I should even bother. I bought the car back in February and have plans to track it, just don't want to do more damage than good.
      04-23-2014, 09:03 AM   #92
dparm
Stop the hate, get a V8
dparm's Avatar
Drives: C7 Corvette GS, AMG C63 S
My shop changed the filter. I don't know what they specifically did, but they did have my car for quite a while.
BMW claims it is a lifetime fluid and the DCT is a sealed unit, yes. From what we've seen in some analyses of used fluid, the factory-fill Pentosin FFL-4 (aka BMW DCTF-1) is very stout and the transmission itself doesn't create a ton of particulate matter. Even at 50-75k the fluids looked good.
If you want peace-of-mind, change it. The fluid is $15-20/L and you'll probably pay about 1.0-1.5 hours of labor. Figure around $200 for your total cost.
Now: 2017 Corvette Grand Sport, 2021 AMG C63 S sedan
Past: 2011.5 M3 sedan ZCP
      05-03-2014, 01:12 AM   #93
BzsBimmer
BzsBimmer's Avatar
3274
Drives: '23 G80 FO M3, M3 & MY Tezzy's
Posted here
http://www.m3post.com/forums/showpos...64&postcount=9
I'm lost. Are we still using Pentosin or SAF-XJ + FM Booster?
      05-06-2014, 12:26 AM   #94
BzsBimmer
BzsBimmer's Avatar
3274
Anyone?
      05-06-2014, 02:25 AM   #95
SenorFunkyPants
SenorFunkyPants's Avatar
2511
Drives: 2019 M5
SAF-XJ + FM Booster is the fill for the differential and absolutely should not be used for the DCT.
Pentosin FFL-4 is the only approved First Fill and Service Fill transmission fluid for the new generation of BMW double clutch gear transmissions (DCT). = correct.
      05-06-2014, 03:10 AM   #96
m45
m45's Avatar
Drives: 2011 E92 M3
Just found this posted on another forum. The recommended torque for the filler plug is 25 Nm (+/- 3Nm).
SI B28 03 08
Double-Clutch Transmission with Drivelogic July 2008
Technical Service
SUBJECT
M Double-Clutch Transmission with Drivelogic - Transmission Filling and Fluid Level Checking Procedure
MODEL
E90, E92, E93 M3 with S65 and M DCT transmission
SITUATION
The current version of BMW TIS does not contain the M DCT (GS7D36SG) transmission fluid filling (fluid checking) procedure. Use the following procedure when the M DCT fluid fill (check) is required.
Important:
The M Double-Clutch Transmission (DCT) requires a special lubricant/hydraulic fluid: DCTF-1 Pentosin (P/N 83 22 2 147 477). This fluid is specific to the double-clutch transmission and should not be substituted with any other product.
Substituting the DCTF-1 Pentosin in M Double-Clutch Transmission (GS7D36SG) may cause significant damage to the internal clutches of the transmission assembly, requiring replacement of the complete gearbox, transmission oil cooler, and cooler lines.
The BMW DCTF-1 Pentosin fluid does not require regular service. It is an extended-life type of fluid and should not be replaced. Currently the fluid is in extremely short supply, and can be obtained only after a PuMA case is submitted to TeileClearing (Enhanced Technical Support). Refer to SI B28 02 08 (May 2008) for more information related to M DCT TeileClearing.
1. The vehicle needs to be leveled and secured on the appropriate workshop lift. Connect the vehicle to the DIS/GT1 loaded with the current version of diagnostic software (V53 or higher).
2. Remove the transmission's under-cover to gain access to the refilling plug (1). Make sure that the transmission is at ambient temperature (engine should not be warmed up).
3. Using an Allen M8 wrench, loosen the fluid filling plug (1).
4. For refilling (empty gearbox after repair):
• Remove the filling plug from the transmission housing and refill the transmission with approximately 8 liters of DCTF-1 fluid, until it starts to overflow.
5. For checking the fluid level:
Carefully start removing the filler plug until the DCTF-1 fluid starts to flow.
Do not remove the filler plug completely!!!
With the correct fluid level and the gearbox filler plug removed while the engine is NOT running, approximately 1.5 liters of transmission fluid will escape, leaving the gearbox underfilled. (The total capacity of the DCT transmission with oil cooler and cooler lines is approximately 9.5 liters.)
6. Install the filler plug (do not torque it yet).
7. From the DIS/GT1 diagnosis menu, select
Service Functions, Transmission Controls, Calibrations, and Oil calibration.
8. Start the engine with the DCT gearbox in the P position.
9. Follow the "Oil calibration" test plan by running the engine at 2,000 rpm for 1 minute (reaching the maximum cooler line pressure of 5 bars).
10. Using DIS/GT1, observe the transmission fluid temperature. When it reaches approximately 40° C, open the filler plug again (with the engine running), and top off the fluid level until it starts to overflow.
11. Install the filler plug and torque it to 25 +/- 3 Nm.
WARRANTY INFORMATION
For information only
[ Copyright © 2008 BMW of North America, LLC ]
      05-07-2014, 07:57 PM   #97
BzsBimmer
BzsBimmer's Avatar
3274
Whaddafluck is wrong with me... hahaha
WHY am I thinking DCT is a rear differential!
DOH
      05-17-2014, 04:49 AM   #98
4er_Meister
4er_Meister's Avatar
Drives: 2015 F82 ///M4
Nice DIY!
      05-26-2014, 01:14 PM   #99
SimiM3
SimiM3's Avatar
25
Drives: 2010 E90 M3
I am looking into doing this for my E90 M3 and had a question: After running the engine at 2k rpm for a minute, do you leave the engine running while you top off the fluid? One post states that you do, but the TIS (see below) is not clear.
Topping up transmission oil after a repair:
Stand vehicle on a level surface and secure against rolling off.
1. Open fluid adjusting screw (1). If fluid emerges, close screw again immediately
If no fluid emerges, top up until fluid emerges and close fluid adjusting screw (1) again
Note: If fluid has been replenished here, a further refill must be carried out during the actual
fluid adjustment
2. Connect diagnosis system and start service functions (drive).
3. Start engine (drive position N or P)
4. Record transmission temperature using the diagnosis system
5. (Drive position P)
6. Permissible starting temperature ≤ 32 °C
7. Idle speed: maintain at approx. 2000 rpm for 1 minute.
8. Open fluid adjusting screw (1)
9. Fill until oil emerges
Max. transmission oil temperature 40 °C
10. Insert screw
See this post also:
Thanks for the help.
Great write up!
      07-10-2014, 12:06 AM   #100
da jemster
da jemster's Avatar
78
Drives: E46 M3,E93 M3,F22 M235i,i1 i3
OP, thanks for the write-up. Here's my new vs. old at 72K. One thing though, I had 5 1/2 liters come out of mine. I placed a level on top of the car, jacked the car up and placed them on jackstands and got close enough to level as when I started. I replaced the suction filter as well. So, the kit that I bought from ECS was insufficient as I needed one more bottle.
As for the cylindrical transmission filter, has anyone gotten to replace that yet? (You...if you had first-hand experience, not a shop that you left your car with). I was able to move the two heat exchanger lines #12 and #13 on the diagram, by unbolting the one bolt on the drivers side and the three bolts on the passenger side. But I was just inches from clearing the lines from the filter opening. I attempted this after I had replaced the suction filter, re-installed the DCT Tranny oil pan and filled it up with 5 bottles. I think if I left the oil pan off, I could've moved the tubes to clear the opening.
      07-17-2014, 01:14 PM   #101
tdott
Drives: M3
Yes.
      07-17-2014, 01:19 PM   #102
tdott
Drives: M3
Happy to see I wasn't the only one with fluid that looks 'dirty'. I'm planning another flush soon with the left over fluid I have and a filter change, but haven't got around to doing it yet, haven't driven the car much since taking it out of storage.
      07-19-2014, 04:46 PM   #103
SimiM3
SimiM3's Avatar
25
Drives: 2010 E90 M3
Thanks
      07-20-2014, 12:42 AM   #104
SimiM3
SimiM3's Avatar
25
Drives: 2010 E90 M3
I just finished a DCT fluid service on my 2010 E90 M3. I had some kind of leak around the pan.
Name:  DCT pan leak.jpg
So I had to pull the pan and replace it. I would have replaced the gasket only, but it is not available without purchasing the complete pan and gasket. I purchased the compete DCT service kit from ECS tuning which included both filters and the fluid along with the drain and filler plugs. I also replace the trans oil cooler line o rings. ECS has those as well.
I did remove the pan and suction filter first.
E90-REP-28-10-000 Replacing suction Filter.pdf
I do think this helped make room to move the pressure lines out of the way to remove the pressure filter.
E90-REP-28-60-00 Replacing Pressure Filter.pdf
If you look at the above TIS, they want you to remove half the car and drop the trans, but I did not find it necessary. On page 2 of the pressure filter instructions above, the #1 bold needs to be removed which allows the lines to be pulled out of the trans. The bracket can be unhooked from the bottom line, which allows the lines to be separated. On the passenger side, the two pressure lines are attached with a bracket with one bolt in the center. Once the bolt (and metal sleeve) is removed, the lines can be moved out of the way. I pushed the top line above the opening to the pressure filter, and the lower line below the opening.
Name:  pressure filter.jpg
I used snap ring pliers to remove the snap ring. I can't imagine how difficult it would have been without the snap ring pliers. There was enough room to pull the cover then the filter.
Name:  pressure filter 2.jpg
Putting it back together and filling it up took some time, but it looks clean and it went into gear, so I would call it a success.
Name:  DCT clean.jpg
I did try to follow the torque specs as close as possible, but could not is some cases because of space limitations.
E90-AZD-28-1-10 Housing with add-on parts.pdf
and
E90-AZD-28-1-00 Transmission in general.pdf
So to answer your question, yes I think it helps to have the trans pan off first, before you take out the pressure filter.
Second, I noticed your diagram and notes reference the heat exchanger, but I only had to move the trans oil cooler lines.
My fluid looked in between the two samples you have in your photo. I am sending a sample to Blackstone to see what they think and will post the results when I receive them. My car has a little over 66 K on it.
I appreciate the original post and comments as they definitely helped me with this project.
Appreciate 6
JsL447.50
M43S7RO503.00
M3MPH1S592.00
AndyW670.50
kayzm33.00
      07-22-2014, 12:00 PM   #105
da jemster
da jemster's Avatar
78
I just finished a DCT fluid service on my 2010 E90 M3....
Hey, I'm in Simi too! I'm by Santa Susanna High.
Finally a post on how to remove that filter! Since I don't wanna spend on another 6 quarts, I'll wait another 30K miles before I attempt to follow your instructions and change fluids and suction filter.
BTW, were 5 quarts sufficient for you?
      07-22-2014, 05:53 PM   #106
SimiM3
SimiM3's Avatar
25
Drives: 2010 E90 M3
Cool, another M3 in Simi. I'm by wood ranch elementary.
I ordered an extra liter for a total of 6, but only used 5. I am a little worried that I did not get the level exactly right, so I am looking into having a shop verify it's correct. But it is running fine so far.
      07-22-2014, 08:38 PM   #107
da jemster
da jemster's Avatar
78
Did you leave the car running after the 2K RPM/1 MINUTE warm-up period while filling it up? And how did you get to disconnect the oil line - held by screw/clamp?
      07-23-2014, 06:40 PM   #108
SimiM3
SimiM3's Avatar
25
Drives: 2010 E90 M3
I started the car and held 2K for about 20 seconds. I was concerned that while I was under the car with it still running, that the temp would climb too high. I should have checked the temp but everything was getting hot under there, so I just filled it until it started to come out and installed the plug.
The oil lines are held in with just one bolt, #1 in the photo below. I used an 8 mm closed end wrench, which worked fine. Anything that is a 12 point, such as a socket or closed end wrench will work. I did not have a 12 point 8 mm socket, so I used a wrench.
Once the bolt is out, the clamp moves freely and the lines just pull out of the trans. After the passenger side clamp is removed, there is a lot of play to move the lines out of the way. My third photo from my original post shows the lines out of the way with the pressure filter removed.
I hope this helps.
M43S7RO503.00
M3MPH1S592.00
      07-24-2014, 10:28 AM   #109
da jemster
da jemster's Avatar
78
I hope this helps.
Yes it does. I'll change that filter at my 100K interval. Thx!
      07-24-2014, 02:08 PM   #110
tmntmn
///M
Drives: e92 M3/M-DCT
The oil lines are held in with just one bolt, #1 in the photo below. I used an 8 mm closed end wrench, which worked fine. Anything that is a 12 point, such as a socket or open end wrench will work. I did not have a 12 point 8 mm socket, so I used a wrench.
Attachment 1064415
Attachment 1064416
I hope this helps.
Planning on ordering the kit also to change out my DCT Fluid, if i change out the suction filter can i reuse my oil pan and gasket or do i have to purchase a new one?
for the pressure filter did you just pull it straight out?
do you have the part number for trans oil cooler line o rings you ordered?
THANKS TO:~<RPM>~ ~<SONICMS>~ ~<MODECARBON>~ ~<McKennaPerformance>~
MODS: MODECARBON V2 GTS FRONT LIP & REAR DIFFUSER, AA GREEN FILTER, RPI SCOOPS, PSW, Verstraβe Extended DCT Shifter, ZCP WHEELS (SEMI-GLOSS), OHLINS R&T, Megan Exhaust, AKRA XPIPE, BMW LED INTERIOR, BLACKOUT W/ORION V4 LED AE, OSRAM CBI
m3post
