08-09-2011, 11:24 AM | #1 |
Rep 404
Problems Posting
I have recently encountered a problem posting from my laptop. When I try to post I get an error message indicating essentially that the message portion needs to contain at least 1 character. I have typed several sentences. I've posted from my home laptop in the past.
I'm able to post from my work computer. I sent an email to the web master but no response as of yet. Any ideas?
08-09-2011, 12:16 PM | #2 |
Moderator / European Editor
1545
Rep 6,754
I guess you're using IE9. If so, try to disable the WYSIWYG editor in your UserCP (Edit options --> Miscellaneous options --> change from enhanced editor to standard editor). Then you should be able to post again. Hope this helps until there's a fix for IE9.
Best regards, south
IK6SPEED4495.00 |
09-14-2011, 04:23 PM | #4 |
Rep 12,276
I have this same issue. Can you be more specific about the workaround? Is this an IE configuration change, or elsewhere in Control Panel?
I think it is bad luck to be superstitious |
09-14-2011, 05:22 PM | #5 |
1545
Rep 6,754
It's in the UserCP on this site (first link to the right of the header image), and then follow the steps mentioned above. Let me know in case you didn't find it and I'll send you a PM.
Best regards, south
08-25-2012, 02:01 PM | #7 |
15
Rep 86
can't reset edit prefs
I received the same 'at least 1 characters' message and came here after several attempts to post. When I disable WYSIWYG and save changes, the page switches over but no changes are actually saved. I tried the reset--nothing seems to be resetting. No matter how it is done, nothing changes...
09-26-2012, 07:56 AM | #9 |
Rep 682
Hi,
For my first post, I am attempting to reply to an existing thread but am receiving the following error message: you do not have permission to access this page. This could be due to one of several reasons: 1.Your user account may not have sufficient privileges to access this page. Are you trying to edit someone else's post, access administrative features or some other privileged system? 2.If you are trying to post, the administrator may have disabled your account, or it may be awaiting activation. My account is already validated. Is there anything else I need to do before replying to threads or creating my own new thread? This was the only forum that I could successfully post a reply. Thanks. |
09-26-2012, 08:13 AM | #11 |
Administrator
41159
Rep 21,246
New users may no longer create new threads immediately. They must first make some posts (and then wait a day or so).
Check on the Latest BMW News
Become a fan of Bimmerpost Facebook Follow us on Bimmerpost Twitter Subscribe to Bimmerpost Youtube Channel |
09-26-2012, 08:38 AM | #12 | |
Rep 682
Are there any forums that don't count for the number of posts? |
10-23-2012, 02:09 PM | #14 |
Rep 1,710
Well since I can't start a new thread, I've sent a message regarding upgrading my status over a week ago and I gotten no response yet. I still cannot send PMs and begin new threads. I have had well over the required posts needed in said timeframe and it still says the same message across the top of the page.
11-06-2012, 07:48 PM | #16 | |
33
Rep 391
Is the limit actually 3 posts or 5 posts as someone else is saying in this thread? thanks, CK |
11-06-2012, 09:53 PM | #17 | |
Administrator
41159
Rep 21,246
There are certain sections where posts don't count towards your post count, like the Off-Topic section.
04-11-2013, 08:59 PM | #20 |
Rep 17
I really think someone should either get a better anti-spamming software because 3 post+ 48 hrs by the time you want too figure out something you are a week away from an answer. For example I'm looking for a solid answer on what exactly is needed for M3 suspension on my 335i as they will be giving to me for free and I have too wait 3+ days too post in suspension when the m3 suspension is only available tomorrow no one wants too wait 3 days+ to get an answer when every search thread says you need complete different things for m3 suspension on a 335. 1 thread says you need m3 knuckles, brakes, sliders when that can't be right another says you don't need anything for the fronts and just need to get m3 camber plate for the rears the answers are so misguided the whole point of a forum is you signup to get answers to your questions not wait 1 week+ and miss your opportunity to get the info you need.
