Studio RSR
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > E90 auto transmission cooler hose
      03-27-2015, 10:32 PM   #1
davidlo19a
Drives: E90 320D 2007 Euro
Hello,
Recently I noticed my auto transmission cooler hose is weeping a little from the cooler-hose connection.
(Sorry, I have to steal pictures here and there).
This is where the leak is, the big quick-fit connector to the cooler (ignore the text, since I stole the photo from somewhere)
After a bit of research, there are a few options:
1) Bite the bullet, and buy the original BMW hose, the WHOLE hose, flexible and rigid, which is quite expensive.
2) Exchange the flexible part, and use regular hose clamps, as outlined below:
http://www.starquestclub.com/forum/i...owtopic=125941
3) Take off the original connector, replace the O-ring, which may or may not work.
I'm thinking of going with option 3, since it's the cheapest.
Question is, does anybody know the size of the O-ring inside the connector?
      03-27-2015, 10:57 PM   #2
Dozhdbog
Dozhdbog's Avatar
Drives: 2011 335i Sedan
Those damn O rings...
2011 E90 / Premium Package / Stage 2 PPK / Performance Suspension
      03-28-2024, 10:07 AM   #3
Welcro
Drives: E90
Hi, sorry for bumping an old thread but did you ever find the O-ring size? I’m having this problem right now.
      03-28-2024, 01:15 PM   #4
mainbearing
Drives: BMW 328i
I was looking for the same information. The idea of needing a set of new rubber hose and metal pipe assembly is just plain stupid. A plain hose with two clamps at the ends would have been more reliable.
You may be able to search up the original pictures and diagrams. The numbers I got off it then were 19mm-OD x 14mm-ID x 3mm. I suspect 12.5mm-ID may offer a better seal (the 14mm-ID may be hardened diameter).
There are two o-rings in each connector separated by a plastic washer (or three washers I do not remember) that go on either side of an o-ring.
This whole ATF cooler setup by BMW is just a poor design.
Expired site:
https://www.fightchaos.com/2020/08/r...il-cooler.html
Welcro5.50
