BMW M3 Forum (E90 E92)
  TireRack
      05-28-2012, 12:42 AM   #1
Drifty//
Drives: A4 quattro 3.2 MT6; E92 6MT
Inflation of non-OEM sizes?
My car had 19" 220M's. I'm running 275/35R18's now (square). What should my tire pressures be for street? The sticker on the door sill says Front=33 PSI Rear=35 PSI. I did 35/36, for now.
      05-29-2012, 10:34 PM   #2
Drifty//
Anyone? I know a lot of you are running non-OEM tire sizes. Do I stick with recommended inflation?
If not, are there guidelines I should follow?
      05-30-2012, 11:21 AM   #3
kmarei
kmarei's Avatar
Egypt
687
Drives: 2018 Audi RS5 coupe
2018 Audi RS5  [0.00]
i use this table
http://www.m3post.com/forums/showthread.php?t=519804
      06-02-2012, 05:46 PM   #4
Drifty//
Originally Posted by kmarei View Post
Thanks for this and your many other helpful posts I've read while researching & prepping this car!
Here's what I found (thanks, tirerack!):
245/35-19 PS2: load index 93(XL) @ 33 PSI = 1178
265/35-19 PS2: load index 98(XL) @ 35 PSI = 1430
275/35-18: load index 95(SL) @ 26/27 PSI = 1164/1199
275/35-18: load index 95(SL) @ 33/34 PSI = 1407/1443
Note that the Dunlop Direzza Sport Z1 Star Spec have SL load range, whereas the Michelin Pilot Sport PS2 have XL load range. Therefore, I used your chart to get the load for the PS2's, but the chart I posted later in that thread to find the PSI for the SS.
So, it looks like I should be running 26/34 F/R on my Star Spec square setup. I'm a bit surprised at the bias. I think I'll actually do something closer to 29/32, since I'm guessing some of that bias was to give the front tires a larger contact patch for a bit more bite. Switching to 275's should reduce the need for that and I wouldn't mind a slightly larger contact patch in the rear.
I'll also be keeping an eye on how the tread wears.
Last edited by Drifty//; 06-02-2012 at 06:07 PM.. Reason: Fixed to use SL chart for Z1 SS tires
pressures, psi, square, tire
m3post
