2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Anyone up 100k Miles on their F10?
      07-16-2020, 04:07 PM   #23
JackMikk
Drives: BMW 7 and 5\ Camaro SS 19
Coil and consumables changed, nothing more.
      07-17-2020, 08:29 AM   #24
OnlyGerman
OnlyGerman's Avatar
Drives: F15, F13, F10, E60
Originally Posted by lsturbointeg View Post
old thread lol! i'll add that i'm at 103k and the only thing that had to be done was the notorious OFHG leaking
Crazy how sometimes we focus on the bad parts but forget how reliable others can be. I hope to get 200k on mine, even if I have to replace a turbo. Starting to doubt if I needed a warranty but oh well, high miles so always a risk.
      07-17-2020, 08:32 AM   #25
530iDriver
530iDriver's Avatar
Drives: 2017 BMW 530i
Originally Posted by Chad20 View Post
I got a buddy with a 2011 528i 198k Miles no issues just cosmetic
That's a N52 NA 6 cyl, last year it was offered in the F10 528i. 2012-2016 were 2 liter N20 turbos.
2017 BMW 530i, Sport Line,Alpine White, Canberra Beige Sensatec, 19 inch V-Spoke wheels, basic plain Jane build with no options whatsoever..... "Less is more".
Before: 2011 BMW 328i E90 sedan, Platinum Bronze Metallic, Dakota Brown leather, 17 inch wheels, 6-speed auto, N52 6 Cyl inline N/A goodness....
      07-17-2020, 12:44 PM   #26
AmooManiak
Drives: 21 X5 M50i -> M2C -> 21 M5C
My independent said to run away from n63 told me valve stem seal job at his cost is $3,800 and that’s at 100 an hour. Said timing chain job is 1800$ . Told me most expensive job he’s seen on 535i was something to do with the oil leaking from cam or driveshaft bedding . Can’t remember honestly but was around 1200-1400$ job . I was in your same boat a few weeks back and went with 535i and I’m able to continue normally sleeping at night . The car is so comfortable I don’t even care too much about not having tune yet lol
You are buying at 70-80k car. You can't expect to pay 20k and not having to do maintenance on it up to $10k. People would never upgrade to new cars if you are expecting M3 level performance with Carmy level reliability. When I bought each variation of the N63, I put 10k to the side for any unexpected repairs. It comes with the territory.
Things to keep in mind.
1. You have to pay to play
2. You get what you pay for
Appreciate 4
      07-17-2020, 12:53 PM   #27
dzz
Drives: 2015 BMW 535xi, MHD Stage 2+
2015 BMW  [0.00]
2015 535xi, at 84K miles now. I had valve cover gasket replaced at 45K miles under warranty, leaking radiator replaced at 80K miles under extended warranty, spark plugs replaced and brake fluid flush done at 52K miles under extended maintenance. Then front rotors replaced and another brake fluid flush performed at 77K miles under extended maintenance too.
I am planning on flushing power steering and transmission fluids in the next couple of months. Valve cover gasket is a known issue, other than that, no major issues and except for the leaking radiator, mostly maintenance items.
      07-20-2020, 05:03 PM   #28
Trout1
Drives: 2020 M550i , 2021 X3, M40i
Smile F10 Mileage
Hi Guys - Just turned 123,000 miles on my 2013 550i xDrive M Sport...Tom
      07-25-2020, 05:50 PM   #29
sszablya
35
Drives: 2011 F10 550xi
119,200 on my 550i. Just finished the drivers CV boot. Joints and bushings look to be in great shape still.
      07-25-2020, 06:54 PM   #30
535I_G37X
Drives: 535I_2016
New to the forum and first BMW with low miles.
      07-26-2020, 10:41 AM   #31
Trout1
Smile Mileage on F10
Good morning Guys - I have 123,450 as of today on my 2013 550i xDrive M Sport. I had the valve seals replaced under the recall in 2019. Other than that, the car runs great!...Tom
      07-28-2020, 05:13 PM   #32
hawkjr1
Retired US Army/Police Officer
hawkjr1's Avatar
30
Drives: F10 M-Sport, E-92
I have a 2013 535i sport with 91000. I have replaced the valve cover gasket (DIY) both pulleys up front (DIY) plugs (DIY) A/C leak (under warranty) two sets of tires.
318IS-330IC-E90-E92 328i F10 535i M
      07-28-2020, 06:49 PM   #33
AussieBob
80
Drives: 2010 F10 "M5"
I'm just over 120,000 miles (194,470 Km) on a 2010 N55.
I just changed the oil cooler gasket (BAPMIC German part) and now the engine is leak-free and clean. I'm using a BMS Stage 1 Piggy-back booster and all is good with the engine. Only normal maintenance and consumables have been needed. The N55 in this variant appears to be pretty rock-solid so far.
Name:  oil cooler new gasket.jpg
      08-05-2020, 10:34 PM   #34
Tevzadze2.0
47
Drives: 2011 Bmw 535 xi
113k . Done ofhg, water pump , belts and pulleys
      08-08-2020, 01:57 PM   #35
5soko
5soko's Avatar
333
Drives: M5
N55 is good ol reliable solid! I have yet to do anything on my N55 besides normal maintenance
Current: E63S AMG 4matic RENNtech || M5 Evolve..Eventuri || F10 LCI 535i MHD
      08-08-2020, 03:15 PM   #36
BurrNinja
Drives: 2017 540i Bluestone Metallic
Got my 11 535i xdrive at 84k current at 103k.
Have done OFHG, oil cooler gasket, new valve cover, tensioner and belt, both front axles cause boots ripped, replaced wheel bearings while I was doing axles they were fine just figured while I was in there. Transmission pan and fluid change.
Instgram @burninja
      08-08-2020, 05:35 PM   #37
SWFLf10
SWFLf10's Avatar
Drives: 2016 Alpina B6, 2015 535i
105k here! Bought it two years ago with 70,000 miles and one previous owner. No major issues so far!
      08-08-2020, 06:57 PM   #38
550iFreak
45
Drives: 2011 BMW 550i 6MT
126k miles on my 2011 550i with the 6 speed manual.
Lots of upgrades, and no oil usage so far after performing valve seal repair at 100k
      08-13-2020, 07:10 PM   #39
junknat
Drives: 2012 535i (F10)
2012 535i, bought it around 55k miles and it now has 87k miles.
OFHG, VCG, AC compressor, water valve, condenser, mechatronic, HVAC buttons, soft close motor (driver), tension struts, rear differential-subframe mount, fuel injectors, belt tensioner, DMTL pump, HPFP, LPFP, HVAC blower motor, and HVAC regulator
      08-14-2020, 02:49 PM   #40
Procommuter
17
Drives: 2014 BMW 535D
2014 535d msport, 185,000K miles, 1000 miles plus a week. regular consumables,plus motor mounts, trans mount, carrier bearing, guibo, and diff bushings.
      08-15-2020, 07:22 AM   #41
Pierre Louis
Drives: 2016 535d
2016 535d 89,000 mostly gentle miles. So far only new (under warranty) headlights due to water seepage. Sensors around DPF are "out of spec" with no check engine light so far. Mechanic said transmission fluid was like new when changed at 80,000 miles.
      09-07-2020, 12:21 PM   #42
TheUtahX5M
TheUtahX5M's Avatar
138
Drives: X5 M
I'm at 131k in my 2014 535d Xdrive. Have had a few repairs related to emissions system, AC evaporator, normal maintenance. I bought it new and think I've spent probably $10k or so for all maintenance and repairs since I bought it. That's excluding warranty items.
      09-10-2020, 04:37 PM   #43
Napas
Drives: f11 520d m
160k Kms 520D LCI B47 + PPK Engine + Brakes
Zero repairs/issues, only normal maintenance and retrofits.
Car sleeps on a garage.
      09-10-2020, 04:56 PM   #44
Hoa
513
Drives: BMW
I am at 253K miles on my car
Appreciate 3
5post
