'08 328i E90 Rough Idle, Vibrating & Shaking
05-25-2013, 10:30 AM | #45 |
Rep 150
Good info, thanks!
Interviewer: The most exciting moment during the race weekend?
Kimi: I think so it's the race start, always. Interviewer: The most boring? Kimi: Now. |
08-06-2013, 08:10 PM | #46 |
Rep 25
has anyone actually fixed this problem (varying 50-100 rpm at idle) by changing spark plugs and coils?
I changed the plugs to see if it would fix this and it has not. I'm debating about going for the coils next. 07 328xi /w 63k. |
08-06-2013, 08:17 PM | #47 |
Rep 35
Dealing with the same thing right now...could be bad coil, spark plug or gasket on the cylinder is leaking oil into the spark plug. Might need a new gasket.
08-07-2013, 10:23 AM | #48 |
Rep 88
I had something similar to this for a few months. I would feel a small thump as well. My idle was pretty stable though. If anything, it would change by 25-50 (needle barely moves). I changed spark plugs with no change in idle. But then I changed the coils a few months later and it cleared out the "thumping" and I gain back low end power and gas mileage. The coils weren't throwing any codes too.
08-07-2013, 10:47 AM | #49 |
Rep 3,854
Drives: 330i, 135i
Clean and swap your vanos and replace your air filter. So easy to do. Also do a techron bottle. My idle improved a lot since then.
08-11-2013, 09:28 PM | #51 | |
Rep 25
08-11-2013, 10:10 PM | #52 |
Rep 1,945
Drives: 2011 335xi Msport, Conv, Tech
Is your dme up to date?
|11 335XI N55 | M SPORT | VRSF CP | BMW PE | BMS INSTAKE | VRSF 7" IC | MHD STAGE 2+ | ER CP |
08-12-2013, 08:35 AM | #53 | |
Rep 1,012
it's going to be a long week.
work in progress..
08-12-2013, 08:38 AM | #54 | |
Rep 1,012
work in progress..
08-27-2013, 08:42 PM | #55 |
Rep 26
08-28-2013, 01:13 PM | #56 |
***** noob
1369
Rep 10,479
Drives: 325xi>M235i>428GCx Mspor
If you been on here long enough you will know that its the eccentric sensor, bmw techs are no better than a weekend DIYer...they just have all the right tools
2006 325xi (Sold)
2014 M235I (Current) 2015 428xi Gran Coupe (STB) |
11-03-2013, 01:32 AM | #57 |
34
Rep 189
If the coil is dead the car would vibrate pretty violently at idle and would be lacking power at higher RPMs. Dead coil would no doubt throw a misfire code. Don't deive too long with bad coil as it will cause catalitic converter to fail. If the vibration is low to moderate I would check Vanos solenoids and eccentric shaft sensor.
11-08-2013, 12:32 PM | #58 | |
Rep 108
I had a vanos solenoid replaced (exhaust i think) ~60-70K and it threw a CEL code and was missing at the higher RPM's. |
11-08-2013, 01:47 PM | #59 |
Rep 3,854
Drives: 330i, 135i
Me too i have a minor movement on idle at times. I replaced my spark plugs and idle did improve, I still have not changed my coils but would like to know if any coils is worn out ir in fact bad. Is there a way to test these? I dont want to spend $200 dlls on new coils if issue are not the coils.
11-17-2013, 10:07 AM | #60 | |
19
Rep 113
Is that something that could maybe be caused by the spark plugs? |
11-18-2013, 05:27 PM | #61 |
Rep 484
I had the same problem like two months ago. I took it to the dealer, and they reprogrammed the software. After like two days, it started acting up again, so i took it to another dealer, and found out that the oil got into the camshaft eccentric sensor.
02-21-2014, 10:19 PM | #62 |
Rep 25
03-08-2014, 04:37 PM | #63 |
Rep 3
feels like a misfire (shaking)
here is my story:
my car had a loud noise one day while driving and it shut off, it was hard to start back up. Once it did that loud whistling sound was there, kind of like a pulley gone bad. It turns out it was the oil seperator valve (I know there is another name for it too), it's a common problem with E90 and possibly even other BMWs. Once they replaced that, the car was still having codes and was hard to start. Once started it shakes and feels like misfires, the mechanic took it to the dealer and they told him that it's the crankshaft position sensor. I'm getting it replaced in a couple days, I will update to let you all know if that fixes my problem. Crankshaft Position Sensor problem Crankshaft Position Sensor was replaced, no more problems. Last edited by Erodinator; 03-16-2014 at 11:54 PM.. Reason: UPDATE: |
03-08-2014, 05:09 PM | #64 |
16
Rep 294
I had a similar issue to you. I changed out a coil and replaced all 6 plugs and it's running smooth right now. I would also clean out the VANOS solenoids with compressed air or MAF cleaner. Take a look at the engine camshaft sensor and the intake camshaft sensor. Try swapping them out.
Gloss Black Kidneys/Gloss Black Spoiler/AG M359/JB4 Stage II/VRSF DP/BMS Intake/BMW PPK
05-15-2014, 02:36 PM | #65 |
Rep 11
Had AFE oiled cold air intake for a year. (I do not recommend anybody to put this crap on their car because it makes your ECU throw CEL with P0172 code) So I decided to put back my stock intake.. Once i started up the car, the idle was really rough. It was shaking and vibrating but for only few second... Now this problem persist... every morning I start my car it does it.. anyone here know what it could be ?
TY
330xi e90/ AFE Pro5R CIA / AA stage 2 tune / obx catless headers / Megan lowering springs
328i, e90, idle, rpm, vibration |
