Go Back   6Post.com | BMW 6-Series Forum > BMW 6 Series Forum > BMW M6 Forum (F12 / F13)
      11-09-2023, 11:55 PM   #331
Z.Design
Drives: '15_X5_35d & '07_BMW_328_conv.
Hi guys! Need an FSC code.
I got a cable, 64g usb stick, got a map (Road Map North America Next 2024), map start reading by my X5 correctly... But I stuck on E-sys installation. Actually have to install, somehow enter expired token, able to run E-Sys, connect, but it doesn't allow me input me string"0x63". Looks like E-sys still not proper installed/tokened... So I'm stuck on that and need FSC code.
my VIN F0N08597
current NBT version on car NBT_M15392A
Could some one help me with that please?
      12-15-2023, 09:55 AM   #332
rlasalle15
Drives: 2018 BMW X5 35i F15
New here
Thanks for the thread. I am new here and have tried to read most of the replies to get a feel for what is going on. just a few questions.
Are the new maps posted just for the NBT Map update?
Is it possible to get a FSC code gernerate?
I have a 2018 x5 35i F15. VIN:0X93748 NBTevo_L
Current map: Road Map NORTH AMERICA EVO 2017-2.
If the maps are just for NBT could someone point in the right direction for the EVO maps.
Thank you!
      12-15-2023, 10:14 AM   #333
shawnsheridan
General
shawnsheridan's Avatar
Thank you!
PM sent.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
      12-15-2023, 11:04 AM   #334
rlasalle15
Originally Posted by shawnsheridan View Post
PM sent.
Thank you.
      01-07-2024, 12:58 PM   #335
FalconB
Drives: BMW F25 X3 2013
Europe Next 2024-1 Maps Link
Originally Posted by BadSeed View Post
2024-1 North America NEXT map is now available.
Note: I don't sell FSC codes.
MAP file part 1 here >>>: https://drive.google.com/drive/folde...-X?usp=sharing
MAP file part 2 here >>>: https://drive.google.com/drive/folde...lP?usp=sharing
>>> Fix download quota exceeded <<<
1: Select link with the file which you are trying to download
- when the web page loads, login with your Google account
2: Right click on file & select make a copy
3: Navigate to your google drive, My Drive folder & locate the file you want to download
4: Right click on file & click on download
5: When you finish downloading, delete the file from your My Drive folder then go to the trash & delete it forever.
Repeat steps above for the 2nd map link.
>>> Saving map files|folders to USB Flash drive <<<
- 64GB or bigger capacity required
- FAT32 file system
1. Free software to format large capacity USB Flash drives to FAT32 >>>: http://ridgecrop.co.uk/download/fat32format.zip
2. Free software to format large capacity USB Flash drives to FAT32 >>>: https://rufus.ie/en_US/
- Boot selection = Non bootable
- Partition Scheme = MBR
- File system = Large FAT32
1. Map files|folders must be saved on the root of the USB Flash drive
2. When viewing contents of the USB Flash drive, you should ONLY see the files|folders below.
3. If they are inside another folder or if there are hidden files (added by using a MAC\OSX) then it will not work.
From wt888
Many drives are seen by the PC as "Local Drive" in "My computer", as if they were backup hard drives, not portable memory sticks.
After inserting the USB drive into your car and getting a message to update it, an error message then says to insert the USB drive, and you can't get past it.
The solution is actually to use a USB FLASH drive that is recognized as "USB Drive" in "My computer".
If it shows up as Local Drive, your car won't see it as a USB drive either.
The solution is to get another USB Flash drive.
USB Flash drive I use: https://www.amazon.com/Patriot-Super...tronics&sr=1-1
TIP: Buckle driver side seatbelt to prevent iDrive from going to sleep during the upgrade
>>> Create DE.FSC file which is required by the FSC Generator <<<
Requirement: E-Sys & ENET cable
Prerequisite: disable all firewalls, Antivirus. Set Ethernet to DHCP (not static). EDIABAS 7.3.0 installed
1. Connect ENET cable to OBD port
2. Connect ENET to laptop Ethernet port
3. Wait until ALL lights in instrument cluster\dash turns off
4. Turn on Ignition, press START button (DO NOT step on the brakes, engine does not have to be on)
5. Wait until Ethernet has yellow exclamation ! Open command prompt & type ipconfig
6. Ensure you have 169.254.xxx.xxx IP address for Ethernet
7. Wait 2 minutes
8. Launch E-Sys
9. Select Connect
10. Select appropriate Target (based on I-Level)
Note: Don’t use _DIRECT
11. Select Connection via VIN
12. Select Connect
13. Click Expert Mode
14. Select FSC Extended
15. Diagnostic Address (hex) = 0x63
16. Click Identify
17. Application Number (hex/dec) – 0xDE
18. Upgrade Index (hex/dec) – 0x1
19. Scroll down & select StoreFSC
20. Select Add to the batch button (>>)
21. Select Read
22. Select Save
23. Use the following naming format when saving FSC file. XXXXXXX_000DE001.fsc
Note: XXXXXXX is the last 7 of your VIN
Uploaded all the files I use here >>>: https://drive.google.com/drive/folde...Nl?usp=sharing
Free software to extract the compressed files & folders >>>: https://www.7-zip.org/
>>> Generating FSC code for map updates - BMW_CIC_FSC_Generator.exe <<<
All credit goes to the software developer(s)
1. Extract BMW_CIC_FSC_Generator.exe from the ZIP file
2. Open BMW_CIC_FSC_Generator.exe
3. Select OK to download Lookup.xml file (computer needs internet access)
4. Select OK then close and open the program again
5. Select NBT then use Browse button to select FSC file created with E-Sys & ENET
Map type = Next
Region = NORTH AMERICA
Maps = ROAD MAP NORTH AMERICA NEXT 2021-1
Suggestion: check mark on Lifetime
Select Generate button
>>> Determine Region & Map sequence code <<<
Note: requires HxD application: https://mh-nexus.de/en/hxd/
Region & Map sequence code - located in the 1st folder of the map files
File path = 1\INFO_MAP_NANT_#####\Info_Map.imp
North America NEXT:
BadSeed do you have links to the Europe Next 2024-1 map updates. Also would be great to know where to download the Esys and other files you have mentioned in your original post. Just got hold of the ENET cable , want to give it a shot.
      01-07-2024, 01:03 PM   #336
FalconB
to be specific the NBT.exe is what I am not able to locate from the files you have mentioned in the instructions in the word doc on the google drive.
      01-07-2024, 01:04 PM   #337
shawnsheridan
General
Europe NEXT 2024-1 is not even released yet.
      01-09-2024, 05:49 AM   #338
FalconB
thanks Shawn for reverting back, may be I will go ahead with the 2023-2 EU version then. BadSeed thanks for the detailed steps on getting the FSC code from vehicle, it worked like a charm. :-)
1004ron20.50
      03-01-2024, 07:46 PM   #339
1004ron
21
Drives: 2015 BMW X5 xDrive35i
Thanks to all those that contributed here.
I have all the files stored on my USB drive using the instructions but don't know anything about the FSC code.
Do I need to purchase a cable etc. and an app to complete this step, or is there another means of getting this code, and how is this code inputted to the system?
I have an OBDLink MX+, Bimmercode, and BimmerLink.
All help appreciated by this novice.
      03-01-2024, 11:43 PM   #340
shawnsheridan
General
PM sent.
      04-04-2024, 06:53 PM   #341
subzero06
Drives: BMW 535i xdrive
PM sent.
Thank you for the map files, all looks good and attached it to my USB - Please help me out with the FSC code part.
2013 BMW 535i xdrive
VIN: DU73146
Currently sitting on stock version North America NEXT 2013-1
      04-04-2024, 07:38 PM   #342
shawnsheridan
General
VIN: DU73146
PM sent.
      04-14-2024, 09:58 PM   #343
Andrake005
Andrake005's Avatar
Drives: 2015 BMW X5 xdrive 35i
Hi - can someone assist me? I created the USB with the NEXT Maps and already have an FSC code. I have the NBT EVO.
My problem is, when I insert the USB into the port and start the car, it seems that it doesn’t recognize the USB data as idrive does not prompt me to enter the FSC and update. (I’ve done this update before on my F15 successfully, but can’t seem to get this done on my F30). Thanks.
      04-14-2024, 10:02 PM   #344
shawnsheridan
General
EVO does not use NEXT Map. You must run EVO Map.
      04-14-2024, 10:14 PM   #345
Andrake005
Andrake005's Avatar
Ok, I suspected that I would need the NBT EVO map. Do you happen to have a link for the latest version? Thank you!
      Yesterday, 08:33 PM   #346
Issamsos
Drives: BMW X5 F15 , 2014
Hi guys
New in this forums, i'm trying to update maps and need an FSC code and the map file.
VIN: 0G65083
Model : X5 , F15
Current map version : Road Map Europe Next 2013-2
NBT_I14275A
Any help is appreciated, I have done a bit of reading and would prefer to get some assistance without purchasing online if possible.
Thank you so much
      Yesterday, 10:05 PM   #347
shawnsheridan
General
Originally Posted by Issamsos View Post
Hi guys
VIN: 0G65083
Model : X5 , F15
NBT_I14275A
Thank you so much
PM sent.
6post.com
