BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Cosmetic and Lighting Modifications (exterior/interior) > Remove powered seats without power
      11-11-2016, 11:12 PM   #1
Klooney
Drives: None yet
I'm trying to remove a pair of front seats from a wrecked e90. I can unscrew the front bolts but can move the seat forward to get the rear bolts. Tried everything to provide power to the car but nothing seems to work. Any idea on how to get the seats out?
      11-12-2016, 10:56 AM   #2
katsooba
katsooba's Avatar
85
Drives: bmw 135i
if it's a crashed car, the positive wire have a detonator on it, and i guess it got.. well.. detonated in the accident
in the trunk you need to provide power to the terminal after that wire.
135i N55 / KW V3 / MHD Flash / Tons of grip mods / CP-E charge pipe / CP-E 7" FMIC
      11-12-2016, 11:32 PM   #3
Klooney
Drives: None yet
How far into the trunk do I need to go? Cut the casing on the red wire and apply power?
      11-14-2016, 10:41 AM   #4
katsooba
katsooba's Avatar
85
Drives: bmw 135i
not far
just follow the wire that connects to the battery back to the body
you will find a double connector for the + wire, just connect to it your external battery
i hope this image helps
      11-14-2016, 07:22 PM   #5
Klooney
Drives: None yet
I'm assuming you connect to both positive in the diagram and the negative cable at the battery termination point
      11-15-2016, 10:03 AM   #6
katsooba
katsooba's Avatar
85
Drives: bmw 135i
you dont need to connect directly to the batt-
you can use any ground you like with external battery, this connection bypasses the blown + cable terminal.
this is how i powered my car after an accident and a totally dead battery
also i need to note, that after the battery dies the onboard CIC goes into transportation mode which limits car and stereo functions.
this can be disabled via INPA
      09-16-2023, 05:03 PM   #7
lime
lime's Avatar
15
Drives: 335i
For anyone who comes across this thread in the future I have made a video showing the quickest way to remove seats from a wrecked or junkyard E90.
      03-06-2024, 06:03 PM   #8
StradaRedlands
StradaRedlands's Avatar
Drives: 2006 BMW 330i MT
2006 BMW 330i  [8.21]
2009 BMW 328i Touri ...  [7.90]
2013 BMW X5 35i  [7.63]
2011 BMW 528i  [8.75]
2006 Mazda3  [5.50]
lime Do you know what pins those go to? I like the idea of jumping them, but connecting at the pin in the connector would keep the connector intact.
      03-09-2024, 03:06 AM   #9
Onizukachan
Great Teacher
Onizukachan's Avatar
1088
Drives: 06 e91 325ix
2006 E91 325ix  [10.00]
2006 Mini r53 JCW  [0.00]
2005 Mini r53  [0.00]
Without watching it, I’m going to guess you used a 12-14v drill battery and a couple of jumper wires?
‘06 e91 manual 325ix BarriqueRot
over Terra (one of 1), Nav, Sport, L7
A few OEM+ mods:
MTech front bumper, MSport wheel & handbrake, 4AD trim, full rear shades, more to come…
