2010 2011 BMW 5 Series Forum F10 Thoughts on sedan secondary N55 or N63TU |
03-25-2024, 04:06 PM | #1 |
Rep 9
Currently own a F15 X5D enjoying the N57 engine, but I have given up on finding a Msport 5D at this point that's on the east coast.
Moving into gas there are a bit more Msports available between N55 and N63TU. I'm not afraid of maintenance and having been slowly acquiring all the necessarily tools / 2-post lift / ISTA+ to work with, but looking at the 15/16 models. I'm thinking a 550i (or xi) while base price is more expensive, will be a more fun beater car to work on / drive than the 535i (or xi). Open to any suggestions or thoughts, been torn reading through both. |
04-02-2024, 12:49 AM | #2 |
Rep 2
I have a ‘15 550i xDrive, and I can tell you this much: maintenance isn’t going to be your problem. Repairs will be your issue. Random things will crop up here and there and before you know it, even if you took care of it, you’ll have sunk some $$ into it. Doing the work yourself will save you a lot of money, but still.
I love the power I get from the 550, but unless you live somewhere that you can open the N63 up and go, the 535 will treat you nicer. If you’re looking for an N63 that’s more reliable, you’ll need to go 18+ and get an M550i. Also, be warned that the N63 is thirsty for oil and gas. I burn about two quarts between oil changes, and get a solid 12.7 MPG. |
StradaRedlands4946.00 |
04-02-2024, 09:27 AM | #3 |
168
Rep 268
I bought a 16' 550 RWD about a year and a half ago and it's been a dream. I made sure to get an N63TU. I also am very meticulous on maintenance. No major issues, nothing broken, and it pulls hard. I'm BM3 stage 1 and as the previous poster stated, it does burn some oil. I installed the sport oil cooler valve, plugs and coils. Gas mileage isn't great but I work from home so I don't worry about it too much. It's honestly more of a lifestyle question. Do you have the time, funds and energy to take care of it. If so, I don't think you'll regret it.
ChiltiCoatl891769.00 StradaRedlands4946.00 |
04-02-2024, 03:39 PM | #4 | |
Rep 9
I am definitely only looking at N63TU (so 14+) RWD (I don't want to deal with another xdrive), but I do have the BMW tools and home lift, so I think knowing eyes wide open what I'm getting into. |
04-02-2024, 03:42 PM | #5 | |
Rep 9
2 quarts? Wow - that's a lot it's eating, gas mileage I think depends how hard you push - I do tend to open up some on the highway, but the 535i just doesn't have that V8 feel/growl. Basically baby-M5. |
04-03-2024, 03:12 PM | #6 |
Rep 1,146
Drives: F10 550i
Garage List 2020 BMW M340i [0.00]
2019 RAM 3500 [0.00] 2020 BMW X3 [0.00] 2016 BMW 550i [0.00] 2000 Ford F450 7.3l ... [0.00] |
I have a '16 550i xdrive, and its been the most reliable BMW I've owned. Its been really quite good for me. Of course I have the N63TU, with about 98K miles. I do all maintenance on time, and much myself. I race it and it held up great. The only thing I might suggest is doing some preventative. I swapped to a 90C thermostat, replaced all my filtered air ducts, intake, PCV etc. Basically all the plastic shit that goes to crap under the hood. I also did coil packs/plugs recently, and actually do aggressive maintenance as its my race car (more frequent fluid changes and all fluids). Mine is NOT TUNED! I do push it to the max sometimes, and I enjoy the muted V8 sounds.
The only limp dic er I mean limp mode I hit was last year when a turbo pneumatic pressure converter failed. Otherwise for the last 5 years no problem! ONE big reason to get the 550i xdrive, is its one of the last BMWs with hydraulic steering. Not the much disliked electromechanical. Would I get the 6, sure its fine if it suits your price point and tastes. Would I buy the V8 again definitely. Though I really like the B58 in the m340i. I'd say its a better more responsive power train then the 550i. |
04-04-2024, 05:57 PM | #7 |
23
Rep 13
Drives: 2011 BMW 535i Xdrive
I have a 2011 535i Xdrive, and can speak to reliability in my 7 months of ownership. I got a very clean one-owner example, and I think the specific ownership from the past makes a large difference. In 21,000 miles, has given me zero issues, and knock on wood it stays that way. currently at 131,000 miles. Gas milage is a nice plus of the n55 over n63. I have not owned an n63, so will not speak on them.
04-04-2024, 06:10 PM | #8 |
Rep 435
535I(XI) its pretty good on gas, has plenty usable power, and is Definately cheaper to own than the N63TU, alas, I have owned my 535i since June last year, and hasn't given me any issues whatsoever that popped up, I travel often, so mainly highway miles thus far, I get about 28-30mpg. N63TU is a beast of an engine, if you have equipment as stated and the lift, and time and the money, stick to what you heart is telling you and get a N63TU, I know you won't regret it. I was on that same big decision make last year and decided to go I6 Turbo, I am very pleased and happy with my N55.
04-04-2024, 06:27 PM | #9 | |
Rep 832
Outside of a standard oil change, everything else requires digging in on the N63 engines...and digging in means more plastic pieces that will break. Even the metal clamps that hold the O2 sensor wires as they meander from the front of the engine to the rear, distort and break very, very easily. You will get very efficient in removing the two air boxes, and ducting....and the beauty cover, whose plastic securing points break off rather easily and requires the whole cover to be replaced when more than 2 break off. The N55 in the F10 is SOOO much better to work on, there is plenty of room to get to things, unlike the N63....not even 4 fingers can be slid between anything... Remember things like the PCV/CCV fittings are plastic and LOVE to break at the most inconvenient time. Both on the N63 will run you $350 each (before tax and shipping) Have plenty of nickels and dimes for the plastic parts on an N63 if that is what you end up getting. If the plastic parts don't use those nickels and dimes, the gas and oil consumption/leaks will.... The N55 engine might outlast your suspension...... |
04-04-2024, 06:27 PM | #10 | |
Rep 9
ChiltiCoatl891769.00 |
04-05-2024, 08:03 AM | #11 | |
Rep 1,146
Drives: F10 550i
04-05-2024, 04:06 PM | #12 | |
Rep 9
04-05-2024, 04:09 PM | #13 | |
Rep 9
But will the N55 make me smile vs that V8 growl? It's why I'm in no rush for rush and making sure whatever N55 or N63TU has been in good shape. |
04-05-2024, 04:29 PM | #14 | |
Rep 435
