BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Cosmetic and Lighting Modifications (exterior/interior) > Small Orange Bulb in Headlight Corner
      08-05-2011, 07:18 PM   #1
MattGrantham
2008 e93 335i
Drives: 2008 e93 335i
Does anyone know what the hell this small amber light is for in the corner of the e92 headlight and is there any way to replace it with a white bulb?
joe3250.00
      08-05-2011, 09:48 PM   #2
onesuperboi
onesuperboi's Avatar
Drives: '08 e92 335i COBB 4.01 Stage 1
Can't replace it. You can code it out.
      08-05-2011, 10:17 PM   #3
MattGrantham
2008 e93 335i
Thanks, anyone know of a good coder in Toronto?
      08-06-2011, 12:53 AM   #4
jpirelli
Power is nothing without control
jpirelli's Avatar
33
Drives: E90 + E92
You can replace it if you really wanted to. Solder a new one in.
      08-06-2011, 07:39 AM   #5
roadkillrob
Drives: 08 335i,22 X3M, 2012 C63 Black
You can replace it, but you may have to open the headlights to do it, I had mine coded out, it is there for some stupid north american side marker light law of some sort that they don't have in europe (just like the ugly side reflectors).
2022 X3M Brooklyn Grey
2008 E93 335i FBO
2012 Mercedes C63 Black Series Alanite Grey
      08-06-2011, 08:24 AM   #6
Dark_Knight_335
Came to the N55 Darkside
Dark_Knight_335's Avatar
Drives: 2011 335 E93 M-Sport
Ahhh so THAT'S what happened to mine lol...Luis coded it out when he did my OSS lights
Mystery solved.
      08-07-2011, 09:01 PM   #7
Super Amjo
16
Drives: 09 335i
Shane did my coding (BMW knight) but I was told the led on the e92 couldn't be coded out - was I mislead?
      08-07-2011, 10:51 PM   #8
Dark_Knight_335
Apparently. Mine was coded out by Luis just fine
      08-08-2011, 11:43 AM   #9
LuxAngelEyes
LuxAngelEyes's Avatar
Drives: BMW
you can replace it if you open the headlights. I've done it but its a PITA!
      08-08-2011, 12:41 PM   #10
nizzle
Drives: 2008 335xi
Do these corner lights blink amber when the turn signals are on as well? If so, does the coding mentioned here disable that as well?
      08-08-2011, 04:06 PM   #11
01stang
01stang's Avatar
Drives: E92
u can just cut one of the wires in the harness and it wont light up and no error at all did that on my 07 i have to dig up the thread if u need that info, plus u can have quick connect on it so u can plug it back in if needed
Mods: Black out kidney grill, 6000k d1s, 6500k foglight, mtech angel eyes and cornering light, m6 reps, m3 tri color steering wheel, somewhat matching shift boot and brake boot, led lisence plate, led interior, led rear signal, led side marker, aero front lip, cf emblem overlay
      08-08-2011, 08:47 PM   #12
MattGrantham
2008 e93 335i
01Stang: Please let me know, that sounds like the best solution by far!
      08-08-2011, 11:54 PM   #13
MyE92
El Presidente
MyE92's Avatar
Drives: your mom wild.
Mystery solved.
Unless he coded your car with the headlights in, I doubt he really coded it. To actually code it, you would need to have the USB connected to the OBD port.
He probably just cut the wire.
I got mine coded by Sal@Camber-Toe, and its doesn't come on anymore.
      08-10-2011, 05:28 PM   #14
01stang
01stang's Avatar
Drives: E92
found the you tube there was a thread here like 4 yrs ago got a wire diagram that was drawn on a piece of paper could not find it tho... im still trying
      08-10-2011, 05:37 PM   #15
Dark_Knight_335
I think you're actually right bro. My bad. How are you doing man?
      08-10-2011, 05:37 PM   #16
Dark_Knight_335
This was for MyE92
      11-04-2011, 10:30 PM   #17
engotski
oh haiii
engotski's Avatar
Philippines
43
Drives: e92 328i
Ok to bring this thread back before I cut my wire...
I have a 2007 E92 that has my corner lights coded out but that small corner LED is still on. For some reason its not deleted on mine but later-build e92s have been completely deleted with the code.
Is it possible for pre 07 build to have this unfortunate issue that I HAVE to cut the wires to get rid of the corner LED?
      11-05-2011, 02:04 AM   #18
qclik
qclik's Avatar
Hong Kong
23
Drives: e92
Not really need to cut off the wire, just unplug it but yes headlight must be open. Check out poor man oss thread on DIY section.
      11-06-2011, 12:51 PM   #19
engotski
oh haiii
engotski's Avatar
Philippines
43
Drives: e92 328i
alot harder to go that route vs cutting of that wire like the youtube link 01_stang shared no?
      02-08-2024, 09:58 PM   #20
xxbetrayed
Drives: 2007 328i
How can I code it out using bimmer code
