04-02-2024, 08:02 PM | #1 |
42
Rep 196
Multiple malfunctions - LDW, cruise control, blind spot
My 2018 440 started having multiple errors - Cruise control malfunction, following by lane departure malfunction and then blind spot malfunction. I also noticed my steering wheel heater stopped working. The light comes on but no heat.
I have to assume it must be 1 common thing wrong or loose wire. Any help or thoughts would be appreciated. |
04-05-2024, 03:26 PM | #2 |
Rep 1,703
Drives: 2014 428i and 2018 X5
Have you checked the condition of your battery? Weird things like this can happen when the battery is going bad.
___________________ 2014 F32 428i M-Sport 2018 F15 M-Sport |
04-07-2024, 10:25 AM | #4 |
42
Rep 196
Thanks guys for input. I have appt set for card to be looks at. However - weird thing, all 4 issues went away a few days ago. So must be loose wire??
No errors and steering wheel heating again. Definitely all related. Any idea what might be loose or could it be battery? |
04-07-2024, 12:03 PM | #5 |
Rep 16,184
Intermittent faults tend to be in the wiring, usually a loose connector. Avoid the knee jerk reaction of assuming it's the battery, most of the time it isn't. Get a scanner, even if it's a freeware app. It will do at least 75% of what a dealer scan will do, and the dealer will charge you upwards of $100.
04-07-2024, 08:19 PM | #6 | |
25
Rep 111
04-07-2024, 10:31 PM | #7 |
Rep 16,184
Thieves. Scanning tools were supposed to lower repair costs by making it easier to diagnose problems. Instead dealers use them as cash cows.
04-15-2024, 01:37 PM | #9 | |
41
Rep 30
My f31 had cruise control issues and other steering wheel issues until i replaced mine. I did it myself for $200 with a used Switch Cluster Steering Column assembly off ebay (making sure all my options match, like for like, this includes the clockspring already). If you're going through the dealer, expect to pay 1.5k-2k because the part alone new is ~$900 Google "bmw clockspring assembly" or "bmw Switch Cluster Steering Column" to understand it a little better. here is an example of one. Try to find one for your model. https://www.fcpeuro.com/products/bmw...BoCZoMQAvD_BwE If you install it yourself be very careful to center the clockspring upon install. Could also find one at a salvage yard. |
