04-04-2024, 06:21 PM | #1 |
51
Rep 69
Cluster Showing Up Multiple Errors.
Hi peeps. Hope all is well. I have 2013 328i Cluster is showing up multiple errors. Bonnet open, tpms, abs etc.
Ive brought a new battery incase that was the fault. Same issue. On the diagnostic machine shows up multiple faults to the cluster. Not sure if its the cluster that needs replacing or if its earth/ground cable. Any help would be appreciated. Thank you |
04-12-2024, 06:57 AM | #2 |
Rep 1,599
Do you have MOST? If yes, check that.
Ground check is a good idea too. OEM cluster? Try diagnosing with ISTA+. May need to re-flash KOMBI and DME, etc.
Help each other: if you manage to fix your issue (especially with help from this forum), don't be a d*ck and disappear. Follow-up by posting the solution so you can help others.
