Coby Wheel
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Photo/Video/Media Gallery > E91 Leonia
      03-07-2021, 09:23 PM   #45
bshambam
bshambam's Avatar
196
Drives: bmw e91
Hey all,
I need some help.
I can't for the life of me reach the back E12 bolt for the Waterpump.
Can someone give me some advice as to how to get it out?
PelicanParts Waterpump DIY seems to have a different configuration than my chassis? Perhaps due to it being an LCI?
Thanks
William Mackenzie
IG: Shambam_makes
Twitter: B_Shambam
      03-17-2021, 05:39 PM   #46
bshambam
bshambam's Avatar
196
Drives: bmw e91
well... I finally managed to pull the sucker out....
Not a great way of doing it to be honest... It scratched up the AC compressor quite a bit.
I question if the installation method will result in the same amount of 'damage' cosmetic or otherwise...
William Mackenzie
IG: Shambam_makes
Twitter: B_Shambam
      03-17-2021, 05:41 PM   #47
bshambam
bshambam's Avatar
196
Drives: bmw e91
I also disconnected the coolant Dump tube from the exhaust side of the engine as the gasket area looked like it was wet and low-n-behold
William Mackenzie
IG: Shambam_makes
Twitter: B_Shambam
      03-17-2021, 05:43 PM   #48
bshambam
bshambam's Avatar
196
Drives: bmw e91
I'm really happy to have the time to slowly work on this chassis while I don't need the car. I'm picking up the new piece of rear passenger window glass on Friday morning, as well as a new Regulator.
I'm excited to start putting all the pieces back together.
With that in mind,
This piece dropped from the subframe/tray. Can anyone tell me what its' from?
Looks like part of a hose?
William Mackenzie
IG: Shambam_makes
Twitter: B_Shambam
      03-17-2021, 05:45 PM   #49
bshambam
bshambam's Avatar
196
Drives: bmw e91
This was one of the old radiator hoses I had to hack off as it was stuck.
William Mackenzie
IG: Shambam_makes
Twitter: B_Shambam
      03-23-2021, 11:34 AM   #50
bshambam
bshambam's Avatar
196
Drives: bmw e91
Here is the new Pump from Hella???? & thermostat
William Mackenzie
IG: Shambam_makes
Twitter: B_Shambam
      03-23-2021, 11:36 AM   #51
bshambam
bshambam's Avatar
196
Drives: bmw e91
The dump tube is all cleaned up and reinstalled
William Mackenzie
IG: Shambam_makes
Twitter: B_Shambam
      03-23-2021, 11:38 AM   #52
bshambam
bshambam's Avatar
196
Drives: bmw e91
And the rest of the re installation went smoothly.
I jacked up the engine about 1-2" and that gave me plenty of room to maneuver and get the pump in without any scratches or damage.
William Mackenzie
IG: Shambam_makes
Twitter: B_Shambam
      03-23-2021, 05:58 PM   #53
whyzee125
Drives: Dinan stage 2 335i
What a beauty! Your water pump looks like a turbo from the top lol!
bshambam195.50
      03-27-2021, 11:36 PM   #54
bshambam
bshambam's Avatar
196
Drives: bmw e91
I started putting the transmission back into the car.
Some optimism in tough times.
You can see the 3d printed support on the bottom, balancing the entire transmission as it gets jacked up
William Mackenzie
IG: Shambam_makes
Twitter: B_Shambam
lab_rat394.50
      03-28-2021, 08:28 PM   #55
squaredphoto
Poland
369
Drives: E91
2018 BMW 340i  [0.00]
Love the progress!! Keep it up
bshambam195.50
      03-29-2021, 10:50 AM   #56
bshambam
bshambam's Avatar
196
Drives: bmw e91
Thank you squaredphoto!
Lots of new developments and purchases as of this month to get the car up and running by May 1st.
I'll space out my posts as needed as to not spam, but I'm really excited haha
William Mackenzie
IG: Shambam_makes
Twitter: B_Shambam
      03-31-2021, 11:50 PM   #57
bshambam
bshambam's Avatar
196
Drives: bmw e91
Another point of victory! Installed the final Oxygen Sensor.
William Mackenzie
IG: Shambam_makes
Twitter: B_Shambam
      04-04-2021, 06:00 PM   #58
bshambam
bshambam's Avatar
196
Drives: bmw e91
I went ahead and installed the upgraded adapter onto the oil filter housing.
William Mackenzie
IG: Shambam_makes
Twitter: B_Shambam
      04-05-2021, 09:49 PM   #59
squaredphoto
Poland
369
Drives: E91
Are the pre updated ones known to fail?
      04-05-2021, 11:09 PM   #60
bshambam
bshambam's Avatar
196
Drives: bmw e91
I don't have enough experience with the n52, nor the e-chassis in order to tell you. What I do know is that when I remove anything rubber/plastic from this engine, it is brittle AF.
I think it's the classic case of, if it ain't broke, don't fix it.
ie: when i removed the hose, i broke the old plastic fitting.
William Mackenzie
IG: Shambam_makes
Twitter: B_Shambam
      04-05-2021, 11:31 PM   #61
bshambam
bshambam's Avatar
196
Drives: bmw e91
Another new project that I will be planning is the Front Crankshaft Seal Installation/Removal tool..
I created the Rear Seal installer... so I kind of set myself up to create the Front Seal installer too, Not to mention that if I were to purchase the tool, it would cost several hundred dollars.
More to follow.
William Mackenzie
IG: Shambam_makes
Twitter: B_Shambam
      04-11-2021, 08:02 PM   #62
bshambam
bshambam's Avatar
196
Drives: bmw e91
Ok! Shifter linkage is all greased up and re-installed!
William Mackenzie
IG: Shambam_makes
Twitter: B_Shambam
      04-11-2021, 08:09 PM   #63
bshambam
bshambam's Avatar
196
Drives: bmw e91
ah bugger.... I just realized I installed the shifter linkage the wrong way...
William Mackenzie
IG: Shambam_makes
Twitter: B_Shambam
      04-11-2021, 08:14 PM   #64
bshambam
bshambam's Avatar
196
Drives: bmw e91
only after I reinstalled the transfer box haha
William Mackenzie
IG: Shambam_makes
Twitter: B_Shambam
      04-19-2021, 01:12 AM   #65
bshambam
bshambam's Avatar
196
Drives: bmw e91
Pressure washed the engine and removed the belt & main crankshaft pulley. Nice and clean compared to the previous 10-year old gunk.
William Mackenzie
IG: Shambam_makes
Twitter: B_Shambam
lab_rat394.50
      04-19-2021, 01:16 AM   #66
bshambam
bshambam's Avatar
196
Drives: bmw e91
I also addressed the sagging issue that I noticed w/ the Coolant pump and replaced both left & right motor mounts!
Passenger side:
Really wanted to do this while the car was up on jacks... It went smoothly... until the engine ground cable just withered into two....
William Mackenzie
IG: Shambam_makes
Twitter: B_Shambam
lab_rat394.50
