Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Photo/Video/Media Gallery > 2013 E92 328i M-Sport 6 Speed Build Thread
      12-05-2023, 09:24 PM   #1
dudemanppl
Drives: 2011 E92 M3
Origin Story
N52s (or N51 in this case ) have always been neat to me and my friend was getting rid of this thing for cheap after I called first dibs on it so here we are!
Crazy build spec; 2013, single owner (effectively), slicktop, single hump, manual seats, M-Sport, and 6 speed. Ideally, it wouldn't be black nor have wood trim, but the latter is an easy and relatively inexpensive fix.
I'll get photos some other time, its completely stock and Black Sapphire Metallic, extremely un-noteworthy.
Build Plans
Trying to turn it in to a car where I don't have to worry about anything mechanically, look sick, and be fun in corners.
So far I have ordered:
Maintenance
  • Water Pump/Thermostat Kit w/ aluminum Mickey Mouse hose
  • All coolant O-rings
  • Oil Pan Gasket w/ new bolts
  • All the valve cover gaskets + OFHG
  • Engine Oil, Trans/Diff fluids
  • Cabin/Engine Air filters
  • OEM Motor/Trans Mounts
  • Ignition Coil/Spark Plugs
  • LUK DMFW/Clutch kit
  • Tie Rods/boots
  • OEM Clutch Pivot Pin
  • OEM Differential Bushings
  • Selector rod joint bushing
Suspension/Performance
  • Kinematic Speed Shifter
  • RedShift Motorsports Street Coilovers 5/7k
  • PMC Camber/Caster Plates
  • IRP Spherical Lower Shock Mount
  • AKG Upper 85A Upper Shock Mount
  • IRP Poly Subframe Bushings
  • Meyle Trailing Arm Ball Joints 3147100005
  • Camber arm knuckle Ball Joint
  • IRP Camber Arm Inner Spherical Bearing
  • PMC Full Rear Adjustable Arm Kit (Toe, Guide, Upper) w/ Spherical rod ends
  • M3 Front Tension Arms w/ IRP Spherical Bearing
  • Non-M Front Control Arms w/ AKG Spherical Bearing
Wheels
  • Apex VS5RS 18x9.5 ET22 square in Motorsport Gold
  • Michelin Pilot Sport 4S 245/35/R18
Note: Apex recommended against this fitment, planning to run -3.7F/-2.5R for camber, zero toe F/R. It'll also likely require a rear fender pull, roll, and/or shave. I'm also running smaller diameter and narrower tires than usual. Backordered until ~April 2024 so I guess I'll find out then!
Future Plans
In the immediate future, mechanically, it needs new front wheel bearings and a new transmission as the third gear synchro is gone.
Cosmetics
The car is definitely a 10 footer as it sits, but honestly it would be just a paint correction, maybe a front and rear bumper respray along with a lip, spoiler, and maybe side skirt extensions. The rear parcel shelf is sun faded, so I'll respray that. Headliner and pillars are good!
Powertrain
Not sure on plans for the exhaust just yet, the Condor SE9x headers seem to put out good power.
I'm also pretty interested in the yet-to-be-released 22RPD trumpet setup along with some MILVs if those ever come back in to existence.
The 163k mile motor also has a decent lifter tick so I may tackle that down the line as well... or get an N52 to put in (and also do the lifters on that preventatively).
No current codes for VANOS, DISA, or Valvetronic motor but I wouldn't be surprised if those become an issue.
Driveline
Will probably pick up a 3.73 diff to rebuild with a plated LSD along with a REM polish of the ring gear and pinion.
No current CSB or guibo issues, will check the condition whenever I get under this thing.
Brakes
No plans yet other than new fluid.
Feel free to chime in with any other common N51/2 issues I won't be addressing as I'm new to the E9x platform!
whyzee1251681.50
      12-05-2023, 10:21 PM   #2
whyzee125
Drives: Dinan stage 2 335i
Welcome! Love to see pics of your new beast, sounds like a super fun project and I"m drooling over your mod/maintenance list already. Should be a blast!
      01-26-2024, 09:22 PM   #3
dudemanppl
Drives: 2011 E92 M3
Motor has a hole in the block now before even starting wrenching on it, oops! Selling the car after putting a new motor in if anyone is interested.
      02-01-2024, 07:45 AM   #4
whyzee125
That sucks! You already ordered so many parts for it too.
