11-15-2019, 04:01 PM | #1 |
1445
Rep 2,673
APEX Wheels | Classic Forged Line
Questions? Call: 925-245-0773 Email: expert@apexraceparts.com Web: www.apexraceparts.com Hours: M-F 9a-5p PST ARC-8R & EC-7R Everything you love about the original, now enhanced with all the added benefits of forged manufacturing. ➡︎ Significantly increased strength ➡︎ Improved brake clearance ➡︎ Paintless knurled beads ➡︎ New premium finishes Order Now ARC-8R / EC-7R Available Finishes Even More Strength “Forged” doesn’t mean strong. Many forged wheels focus on weight reduction so much that they end up with the same load rating as cast wheels. Think all forged wheels are stronger than cast or flow formed? Think again. We've added up to 1,000 pounds of extra load capacity per vehicle compared to our flow formed line. Learn more about why not all 'forged' wheels are strong. The flow formed ARC-8 was our first design, so it features our older barrel profile with compromised brake clearance. Typical blank forgings (the starting point many other manufacturers use) can have even worse clearance than our original flow formed wheel. By developing our own proprietary new profiles and new dies, the 18" ARC-8R and EC-7R can clear Brembo 380mm kits and the 19" version can clear BMW 410mm carbon ceramics. Learn more about why we had to create our own new forging dies to clear big brakes. Not all knurling is created equal. To reduce unwanted tire spin as much as we could, we protected our knurling from paint to keep them sharp. We didn’t take the cheaper shortcut of painting over the bead area, which makes the knurling smoother and rounder. See and feel the difference. Learn more about why our forged wheels have unpainted knurled beads. Our forged wheel line enabled us to release premium finishes we’ve always hoped for. Fully polished aluminum and hand brushed with tinted clear now join a wide range of painted finishes, with more to come. Our forged wheels not only deliver performance, but also provide distinctive new styling as well. APEX is known for stocking a wide variety of chassis specific fitments to meet the needs of a very diverse enthusiast community. We’re releasing those same street, track and race proven fitments and more in our new forged line. New lower production requirements allow us to cater to even the most niche segments of the BMW market that may have previously been off limits. We conducted extensive Finite Element Analysis to reinforce high-stress areas and to remove material where it didn’t improve strength. The end result is a fully forged wheel with an ideal balance of strength and weight. Many companies promote their wheels as being certified by the VIA when they actually aren’t. That’s like using the USDA logo on food without permission. APEX Classic Line forged wheels are tested and registered by the VIA in Japan, and we have the proof to back it up. Japan’s JWL is a standard for wheel load ratings. Our forged wheels exceed those ratings by almost 20%. Most manufacturers only meet the minimum, while some even fall below—yet they still claim to be JWL. Always verify load ratings before you buy. Additional Features Hub Centric - All APEX BMW wheels with a 5x120mm bolt pattern are purpose built featuring a 72.56mm center bore. No centering rings required. Center Caps - We don't charge extra for caps and we design our BMW wheels to be interchangeable with the OE roundel cap for enthusiasts seeking a clean factory look. All wheels come with our gloss Black APEX caps included. We also offer optional gloss red or gloss blue APEX caps. Hardware - APEX wheels can be used with all OEM mounting hardware, proper aftermarket hardware and wheel spacers. Wheel locks and stud conversion kits also work perfectly. TPMS - All APEX wheels accept OEM and aftermarket Tire Pressure Monitoring Sensors and standard fit valve stems. If your vehicle isn’t equipped with sensors or you choose to bypass them for your track/race car, then select from our metal stems available in multiple finishes. All our forged wheels come with a lifetime structural warranty and 1 year finish warranty, so you can be confident in your purchase. Let’s face it: Whether you are a weekend warrior practicing at the track, a club racer pushing the limit for a podium finish, or your daily commute involves crater-ridden minefields known as city roads, mistakes happen and parts will be damaged along the way. We are not really a performance company if we sell wheels in a way that penalizes the pursuit of driving at the limit. For this reason, we stepped up and created a program to significantly reduce the costs of properly maintaining a set of wheels by making replacements extremely affordable. Our unique APEX Wheel Replacement Program offers eligible customers replacement wheels at 50% off our standard prices. Learn more We know what fits. From direct bolt-on to all-out race fitments and everything in between. We've street and track tested extensively to save you the trial-and-error. View our fitment guides. For your convenience, wheel and tire packages are now available at APEX. Our knowledgeable BMW Product Experts hand pick some of the best compounds available from prominent brands like Michelin and Nitto, and we’ve priced them competitively. All wheel and tire packages include free mounting and road force balancing by our trusted enthusiast technicians. We use high-end, touchless equipment and inspect every wheel and tire combo thoroughly before they leave our warehouse. Order Now ARC-8R / EC-7R Questions? Call: 925-245-0773 Email: expert@apexraceparts.com Web: www.apexraceparts.com Hours: M-F 9a-5p PST
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers /// ML-10 Survey Last edited by ApexWheels; 11-12-2021 at 05:26 PM.. |
11-15-2019, 04:02 PM | #2 |
1445
Rep 2,673
Introducing the ARC-8R Race Silver Anthracite Satin Black Brushed Clear Polished Introducing the EC-7R Race Silver Anthracite Satin Black Brushed Clear Polished
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers /// ML-10 Survey Last edited by ApexWheels; 12-16-2020 at 02:53 PM.. |
03-26-2020, 06:39 PM | #3 |
1445
Rep 2,673
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers /// ML-10 Survey |
09-10-2020, 05:40 PM | #4 |
1445
Rep 2,673
APEX Forged: Stronger than ever and ready to ship. Our new forged offerings have significantly higher load ratings with over 1000 LBS of additional capacity for 4 wheels in an 18" diameter compared to our already strong flow-formed wheels! The increase in load rating allows these new wheels to better cope with the demands that sticky tires, heavy cars, and high downforce present. This M3 is running our Polished EC-7Rs: Specs: 18×10.5″ ET22 EC-7R Forged Wheels in Polished 275/35-18 Toyo Proxes R888R Tires JRZ RS One Suspension Hyperco Springs Ground Control Camber Plates Rotora 380mm BBK
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers /// ML-10 Survey Last edited by ApexWheels; 12-16-2020 at 04:08 PM.. |
kyippee1073.00 |
10-16-2020, 06:22 PM | #5 |
1445
Rep 2,673
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers /// ML-10 Survey Last edited by ApexWheels; 12-16-2020 at 03:56 PM.. |
11-06-2020, 02:42 PM | #6 |
1445
Rep 2,673
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers /// ML-10 Survey Last edited by ApexWheels; 12-16-2020 at 04:02 PM.. |
12-07-2020, 03:49 PM | #7 |
1445
Rep 2,673
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers /// ML-10 Survey Last edited by ApexWheels; 12-16-2020 at 04:05 PM.. |
01-04-2021, 06:49 PM | #8 |
1445
Rep 2,673
01-22-2021, 04:35 PM | #9 |
1445
Rep 2,673
The fully Forged ARC-8R Unlike our Flow Formed wheels, the Fully Forged APEX ARC-8R and EC-7R are offered with a profile 2 medium concave design even in the higher offset sizes. This allows all chassis to experience the awesome look of concave wheels.
02-05-2021, 04:17 PM | #10 |
1445
Rep 2,673
The Fully Forged EC-7R: More Brake Clearance Thank Any Other APEX Wheel The APEX EC-7R improves brake clearance over the impressive amount offered by the Flow Formed EC-7. Forging allows us to reduce spoke thickness without compromising strength. As a result, the EC-7R has more brake clearance than any wheel we've ever made.
03-11-2021, 06:58 PM | #11 |
1445
Rep 2,673
04-06-2021, 05:14 PM | #12 |
1445
Rep 2,673
04-20-2021, 05:48 PM | #13 |
1445
Rep 2,673
Bigger, Tougher Inner Lip The inner lip is the most vulnerable part of a wheel, because it has no spokes for support. By using forged 6061-T6 aluminum, and reinforcing this high-impact area with more material, we provide an extra layer of protection against track berms, potholes, and whatever else the road may throw at you.
05-18-2021, 06:44 PM | #14 |
1445
Rep 2,673
06-25-2021, 06:01 PM | #15 |
1445
Rep 2,673
09-01-2021, 05:07 PM | #16 |
1445
Rep 2,673
10-07-2021, 02:26 PM | #17 |
1445
Rep 2,673
12-08-2021, 01:14 PM | #18 |
3596
Rep 6,846
Paging BMW owners in the Bay area! If you're interested in free professional photos of your car on brand new APEX wheels, we are looking for volunteers for testfiitting and photoshoots! Volunteers will get copies of the photos, a discount on a set of APEX wheels, and APEX goodies/swag. If you're interested in volunteering, please email us at info@apexraceparts.com with your contact information, location, and a photo of your car. All are welcome. Show us what you've got! If you'd like to take an inside look at what these photoshoots involve, our good friend Blake made a video detailing the process of an 18" test fitment on his F82 M4 recently:
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers /// Project ML-10 Survey |
01-13-2022, 03:55 PM | #19 |
1445
Rep 2,673
4 Doors1169.00 |
01-26-2022, 05:57 PM | #20 |
1445
Rep 2,673
APEX 2022 Build Season Sale!! Save up to 20% off select Flow Formed and classic Forged wheels now through January 31st! Click Here to Shop Now!!
4 Doors1169.00 |
12-12-2022, 12:54 PM | #21 |
1445
Rep 2,673
Gear Up Now for the 2023 Track Season and Save BIG with our Year End Clearance Deals Our year-end Clearance Sale starts today! If you didn't get new wheels for 2023 during Black Friday, now's the time. Fair warning: when the inventory levels of certain fitments and finishes become too low, we will remove them from the sale, so... Place your order early to get the best selection. Up to 20% Off Select Flow Formed Wheels for BMW 30% Off All Remaining Classic Forged Wheels Both ARC-8R and EC-7R While Supplies Last – First Come, First Served
