      07-10-2012, 05:07 PM   #1
Dackelone
European Editor
Dackelone's Avatar
Germany
10642
Drives: N54 e82
Arrow DIY installing LCI tail lights (Blacklines)...
I thought I would put together a little DIY in how to install LCI tails on a pre LCI car.
This is a super easy job to do. All you need is an 8mm deep 1/4 socket/ratchet and a flat blade screw driver or panel removal tool(to remove the carpet plugs) for the trunk liner.
Here we go...
This video might help you see what all is involved with the swap... I did not remove the rubber trunk seal though. You can use your finger to go around the rubber part of the new tail lights.
Note: no DOT stamping!
Here are my LCI "sports". Looks like BMW makes three versions of the LCI for our cars. The standard clear versions (OE), then the Blacklines which are much darker and then these "sports" with a lightly smoked color. Take a look at the turn signal indicator to see the difference in darkness.
I have a US spec 135i (Jan/2010) production with Xenon and AHL (adaptive headlights). IF you want these slightly smoked ones... you also need the parts guy to select "sport" under the tail light options. Here are the part numbers for my lights...
BMW Blackline LCI tail light part numbers:
63217327273
63217327274
price was 136 euros each w/o MwsT 19% sales tax.
or...
a better deal is to order BMW's Blackline LCI kit which come with both tail lights at a slightly discounted price point.
BMW p/n 63212225282
http://realoem.com/bmw/showparts.do?...63&fg=20&hl=11
A lot of 1Addicts order thier Blacklines from Schiedermann.de
http://www.schmiedmann.com/632122252...uctnumber.aspx
Blackline LCI Taillight Group Buy *Feeler*
http://www.1addicts.com/forums/showthread.php?t=674384
FIRSTM143.50
      07-10-2012, 05:34 PM   #2
Eddie135
N55 Commando
Eddie135's Avatar
Australia
55
Drives: 135i - DCT - N55
Good write up on the DIY bro...
      07-10-2012, 06:51 PM   #3
BSM 135i
BSM 135i's Avatar
208
Drives: 08' BSM E82
Nice writeup! I want to do the lci swap but was gonna go with the oe's since I didn't like how dark the blacklines are so I'm glad to know they have these "sports" that arent as dark. Are the part numbers you listed for the "sports"?
      07-10-2012, 07:03 PM   #4
Dackelone
European Editor
Dackelone's Avatar
Germany
10642
Drives: N54 e82
,,,turns out the sports ARE the same as the Blacklines. They really aren't as dark as I thought they be. I rather like them. So only two LCI versions... regular and Blacklines.
LCI tail lights- can you retrofit them to an 08/08 E82
http://www.1addicts.com/forums/showt...512006&page=12
      07-10-2012, 07:27 PM   #5
dan_brooks
dan_brooks's Avatar
Australia
Drives: '09 135i Manual
Good write up!
I did this yesterday with my Blacklines, and it took all of 30mins from start to finish - very simple install!
Work has blocked the video, but one thing I recommend is to test the lights before bolting them back up tight...
Thanks Dackel!
      07-12-2012, 02:19 PM   #6
Pol
Pol's Avatar
Belgium
1122
Drives: M2 CS BMS DCT August 2020
Hey Dack, did you disconnect the negative pole of the battery before starting the job ?
      07-12-2012, 02:26 PM   #7
Dackelone
European Editor
Dackelone's Avatar
Germany
10642
Drives: N54 e82
No. I simply unplugged each connector (two per tail light) and mounted the new Blacklines. This is a super easy swap.
      07-12-2012, 02:27 PM   #8
Pol
Pol's Avatar
Belgium
1122
      07-12-2012, 02:29 PM   #9
Dackelone
European Editor
Dackelone's Avatar
Germany
10642
Drives: N54 e82
Here are some new daylight pics of my Blacklines. I really like the new tails...
      07-12-2012, 04:13 PM   #10
Canasian
It has finally arrived. It's pretty cute!
Drives: 2013 135is Space Gray DCT
2013 BMW 135is  [0.00]
Great photos and write-up Dackel thanks! Can you do daytime pics with the lights on?
      07-12-2012, 04:21 PM   #11
Dackelone
European Editor
Dackelone's Avatar
Germany
10642
Drives: N54 e82
Sure, will do.
      07-14-2012, 04:23 PM   #12
.b0link
14
Drives: 2012 LMB 135i
Man those contrast awesome with Silver!
      07-15-2012, 10:01 PM   #13
froop
froop's Avatar
Australia
171
Drives: 08 AW 6MT E82
Great write up Dack.
I've ordered a pair for my Alpine White 135i vert and I can not wait for them to arrive so Ican install them. Will post some pics when I do.
      07-16-2012, 08:54 AM   #14
Dackelone
European Editor
Dackelone's Avatar
Germany
10642
Drives: N54 e82
It was an overcast and rainy weekend here in Bayern. I was down in Berchtesgaden - but it was daylight! lol FYI... my AE have been coded to run slightly brighter than normal(stock AE bulbs).
      07-16-2012, 10:15 AM   #15
TheSt|G
Resident Tamed Racing Driver
TheSt|G's Avatar
Drives: 911, 130is, E39 M5, E36 M3
I would just mention that when you are installing, don't be concerned if they appear to not line up with the body panels initially. The tightening down performs a surprisingly large amount of alignment.
2005 E46 M3 Interlagos/Cinnamon with Sunroof Delete
      07-16-2012, 12:13 PM   #16
Canasian
Attachment 721715
Attachment 721716
Attachment 721717
Attachment 721718
Looks awesome! I also appreciate a nice lush green environment. Thanks!
      07-16-2012, 12:37 PM   #17
J-Sin
The Artist
J-Sin's Avatar
Drives: 2011 E90-LCI & 2008 E82
2008 BMW 135i  [0.00]
2011 BMW 328i  [10.00]
i LOLed at this write up. You definitely made this procedure idiot proof. 6 photos of you pulling the old tail lights off. HAHA
Thanks for the write up bro, good stuff. You Airforce or Army? I just got back to the states last year from a long tour of Italy.
Betty White - 2011 E90LCI 328i - SOLD
Black Betty - 2008 E82 135i
      07-18-2012, 06:35 AM   #18
1_dez
Australia
Drives: 1er
thanks for the write up it made my life a whole lot easier - although it did take me 2 hours to install them
basically i ran into a problem, where the one of the DRL's (or __ they are called) was not automatically turning on when i flicked the lights on.. i ended up taking it off and figured out the top light on its own, is where the DRL gets its electricity from, i cleaned the terminals and made sure the light plug was in correctly and bingo!
      07-24-2012, 07:03 AM   #19
Swadeness
Drives: 2011 135i
2011 135i  [0.00]
Looks good man, I'm looking forward to seeing them in person.
      08-23-2012, 05:48 PM   #20
Oni_
Drives: ...
Thanks Dackelone. It made my process easier than it already was to know what I needed to pull back, and what I could leave alone.
Just don't drop your socket if using a ratchet - as that added a good 10-15 minutes to retrieve below the carpet.
      08-30-2012, 08:02 AM   #21
froop
froop's Avatar
Australia
171
I just installed mine tonight
I have an 09/08 build E88 135i and they work perfectly. No need for any coding or FRM etc.
Just one thing to note. There is a little play in where the screws sit as its a square shaped hole. This allows you to shift the light slightly when fitting it so you can ensure an even alignment around all the sides. If you just screw it in you'll find on one side there's no gap at all and the other side there's a large unsightly gap depending on how it was sitting when you tightened it. Get it right the first time so you don't have to take it apart and do it again.
Ask me how I know!
      08-30-2012, 04:33 PM   #22
Section147
Good To Be Alive!
Section147's Avatar
Drives: Lotsa Stuff
1). Ordered from ECS Tuning yesterday.
2). UPS shows up at my door this afternoon.
3). Half-hour later:
Love the look. Very subtle. Wasn't going for the can-of-tint-spray or the Lamin-x-type wrap effect. As someone mentioned (Dack?),
the look is very much like a VW tail. Very nicely smoked...classy. It separates the tails (especially on a red car) better that the ones
that came on the vehicle.
