10-23-2013, 02:20 AM | #1 |
Rep 1,252
new tires
I have 19' 403M with Bridgestone potenza S001 factory tires(rft)
225/40/19 Front 255/35/19 Rear i wanna get rid of them and get Michelin PSS , i have been searching for my sizes but couldn't find a front set idk if i can fit a little wider one (235/40/19) any ideas?
Docrace 6266
10-23-2013, 03:02 AM | #2 |
Rep 5,140
You have at least two options for the front tire:
235/40-19 (1% taller than OEM) 245/35-19 (1% shorter than OEM) Since the M403 wheels are 8" wide front and 8.5" rear a difference of 13mm I would have choosen 245/35-19 for the front. F: 245/35-19, section width 248mm R: 255/35-19, section width 260mm The tire widht differs by 12 mm which will make the tires fit similar on the front and rear wheel! |
10-23-2013, 02:28 PM | #3 | |
Rep 63
http://www.tirerack.com/tires/TireSe...=57430&tab=All Btw, any reason why you want to change them? I have the exact same S001 tyres in the same dimensions etc... and i find them excellent! So why the change? Just out of curiosity... |
10-27-2013, 12:41 PM | #5 |
Rep 1,252
any1 replaced factory RFT Bridgestone Potenza S0001 with their 19's
with new decent summer performance tires and what have you felt after replacing? i can't feel the edge of slipping with my car , sometimes i lose control without meaning to not sure if i should replace the tires soon or do some more miles on them.
Docrace 6266
10-27-2013, 03:17 PM | #6 |
Rep 643
10-27-2013, 06:29 PM | #7 | |
Rep 6,811
Drives: E82 135i / E92 328i / E60 550i
If you decide to change them out just pm me and I would be happy to work you up a fast quote. |
12-12-2013, 05:39 PM | #10 |
Rep 1,252
I have found Toyo Proxes T1 Sport & Nitto Invo for my rims on OEM sizes
toyo is cheaper than the nittos but not sure which are better in performance or even comfort as a DD & spirited driving .. anyone experienced in these tires?
Docrace 6266
12-12-2013, 09:07 PM | #11 |
Diligentia Vis Celeritas
559
Rep 1,476
Drives: 335i
Might want to try adding an LSD...
Ahead of the curve for specF30
