TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Unknown fault code with V4
      05-07-2010, 10:33 PM   #1
Stanky19
Friends don't let friends early apex!
Stanky19's Avatar
Drives: "The Turbo Schnitzel"
2007 E92 335I  [0.00]
Has anyone encountered a 10882 code (numerical)? I got the code # when checking/clearing in the Procede Software. There wasn't a hexidental translation available, and i don't have an obd II scanner. It did cause a "no boost limp mode" though.
Any help would be great!
07 Space Gray E92 335i "Turbo Schnitzel"
Wavetrack LSD, KW V3, M3 Aluminum Arms, E93 M3 Front Sway Bar, Dinan Toe Link, Catless DP's, AE Quad Exhaust, DCI, Vishnu PWM Meth, Vishnu V2.5 440whp/460wtq (stock cats)
      05-07-2010, 11:40 PM   #2
AltecBX
AltecBX's Avatar
Drives: BMW 335xi Sedan; BMW M3 ZCP
2018 BMW M3 ZCP  [0.00]
2007 BMW 335Xi  [0.00]
Found a mention on this HERE.
335xi Sedan 6AT | Weather(70-85°F) | N54 Tune Comparison Chart || N54 Turbo Upgrade Comparison Chart
-PROcede Rev. 2.5 ~ v5 (3/17 maps) / JB4 (8/21 maps) / COBB (Stg2+FMIC LT Aggressive maps)
†Procede Map2(UT 45 - IGN 40) Aggression Target 2.0 | 0-60 in 4.0sec || †Cobb E30 LT (35% Ethanol/65% 93 Octane) | 0-60 in 3.9sec
AR Design Catless DP | BMS DCI + OCC | ETS 5 FMIC | Alpina B3 Trans Flash |235/265 19" Michelin PSS
      05-07-2010, 11:58 PM   #3
jpsimon
Team Zissou
jpsimon's Avatar
Drives: 2022 AWD M3 Comp - SMB
"2A82 Inlet-Vanos variable cam control test"
      05-10-2010, 02:48 PM   #4
Stanky19
Stanky19's Avatar
Thanks guys, Rob from vishnu just called to confirm this.
I guess this means i'm going back to the dealership...... hoooray!
10882, code, fault, fault codes, procede
