Studio RSR
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > Australia > DR-JEKL's 335i Intro & Build Thread
      09-18-2012, 05:15 AM   #89
DR-JEKL
Australia
900
Drives: Space Grey E92 335i 6MT
Originally Posted by ABC99G View Post
It's a DAS-6. Looks like you have this covered. I believe an orbital is not as effective as a rotary polisher but less likely to do damage if you don't know what you are doing.
Ahh huh, I was going to buy a orbital but decided to man up and proceed with caution and to be honest it wasn't all that difficult. I had the black onyx on my lexus looking better then the day I had picked it up!
The initial outlay is reasonably hefty but I much prefer to spend $ on equipment and do the DIY method then spend the same amount paying a 'pro' do the work on most items for my cars.
      09-18-2012, 05:17 AM   #90
Scootah
Scootah's Avatar
Australia
27
Drives: F80 M3CP
Originally Posted by DR-JEKL View Post
Im itching to have the DP's etc installed! Do you recommend a charge pipe and bov also?
I have read that pulling the plug out is a more effective and easier but it logs an error code? I had wondered why only the RH side pipe upon starting seemed to be the only side 'open' and emitting exhaust gases...
Well it seems most 335's I had viewed are affected by dull looking calipers etc, it really tidies the car up when you have the paint trims etc looking good also
I can't comment on the charge pipe and bov as I haven't installed , next addition to mine will be Dinan dci - more expensive than other dci's but it looks the best IMO
I pulled the plug on my car and have had no codes
      09-18-2012, 07:38 AM   #91
Steve500
BLACK is BEST
Australia
Drives: E90 335i,R53 Cooper S,MB 380SL
Shane, car is progressing nicely!
Make sure you retorque your wheel bolts in about 500 km with your new spacers.
Ultimately not necessary,but go for the ER charge pipe and Forge DV's.
That's what I have not had any issues.
Pulling the plug for the golf tee mod only logs a shadow code, nothing to worry about. Just plug it back in when going into the dealership.
      09-18-2012, 05:41 PM   #92
DR-JEKL
Australia
900
Cheers Steve!
Thanks for your advice once again mate
      09-18-2012, 05:44 PM   #93
IDriveACamryNow
Australia
67
Drives: Yes
Do you mean the Dinan Cold Air Intake, the one that has the cf snorkel to the front left air duct?
If so, Advan have one for sale. Its in good condition and it would be a lot cheaper than buying new from Dinan and the shipping/customs charges you would have to pay.
      09-18-2012, 06:42 PM   #94
dontask
Australia
13
Drives: White BMW 135i
If you're seriously considering Dinan, you should also consider this:
http://www.glück-gfk-technik.de/airbox-135i.html
Its modelled from the Alpina B3 airbox, but with a larger intake tract.
Modded 135i
RHD Bumblebee
      09-18-2012, 10:25 PM   #95
Scootah
Scootah's Avatar
Australia
27
Drives: F80 M3CP
Thanks Drawn05
That is certainly the one I want, I appreciate the tip and will give advan a call
Cheers Scootah
      09-18-2012, 10:26 PM   #96
Scootah
Scootah's Avatar
Australia
27
Drives: F80 M3CP
Thanks dontask
I will check out the link
      09-25-2012, 06:07 AM   #97
DR-JEKL
Australia
900
Well a few small updates.
I spent the weekend with my rotary trying to polish out the swirls and small paint defects.
I have only ever had JDM cars, and it seems as though the paint is somewhat harder on the BMW and the Lake Country orange CCS pad with fine cut cleaner wouldnt remove the defects that I could remove in the past on my JDM cars.
The sealant used by BMW still maintained a glossy finish, but under afternoon light you could see the paint was riddled with fine swirls. Also running your palm across the paint you could feel the built up contaminants in the paint:
Having said that the car looks great, but with my car being space grey it didn't really look that bad to the untrained eye initially, and even now it doesn't 'pop' like a black car would unfortunately!
I had sealed the car using zymol titanium but I have some nanolex sealant to use which I will do in a months or so time.
It took me about 20-30hrs in total, and I'm still not happy with it, I either need to man up and either try a courser cutting compound in conjunction with a coarser cutting pad and paint depth gauge, or even possibly seek professional help and wet sand a few defects.
On another note my Lux V3 arrived and I couldn't wait to install them. Christ what a damn right pain in the arse they are to install!!! I have quite large hands and trying to squeeze your hand into the headlight housing orifice and then to twist the globe into position was near impossible... I think it took me close to 2 hrs
Anyway finally they are in the results are obvious!
Next on the hit list is to install the Goodyear F1 A2's and get a wheel alignment
      09-25-2012, 06:32 PM   #98
pavo335
pavo335's Avatar
69
Drives: 3.5 wheeler
just a thought on your other thread about the msport front bar, you may want to consider the 'lip' that jason sells as it is ONLY for the non msport bar and imho looks pretty good, in fact i bought one only to find out it doesn't fit
      09-25-2012, 11:08 PM   #99
Scootah
Scootah's Avatar
Australia
27
Drives: F80 M3CP
Thanks Agian Drawn05 , bought the Dinan CAI and also the HPF intercooler from Justin at Advan
      09-25-2012, 11:12 PM   #100
Scootah
Scootah's Avatar
Australia
27
Drives: F80 M3CP
+1 i think the Aerolip looks great
Piccy of my car with the lip installed on this thread
http://www.e90post.com/forums/showthread.php?t=737294
      09-26-2012, 06:40 PM   #101
kaitan
kaitan's Avatar
73
Drives: The Dark Side VAG TDI Biturbo
Love the TLC that your giving the car!! I under the frustration of after long hours cleans the beast yet you are still not satisfied with the work
Maybe it's just OCD !! guess we have something in common :P do you use the machine or all done by hand?
      09-26-2012, 07:33 PM   #102
DR-JEKL
Australia
900
I actually don't mind the lip, but I'm sure you will agree the m bar with the big open air ducts look a lot tougher!
(albeit its a LCI I know)
v's
      09-26-2012, 07:38 PM   #103
DR-JEKL
Australia
900
Well I'm definately the fussy type, just frustrating when I cant get it 'just right'!
wash the car by hand
clay by hand
I used the rotary for the 3 stage polishing process (cut/swirl remover/glaze) then applied the zymol by hand literally (you wipe the wax on the palm of your hand rub your hands together then apply the wax onto the paint with your hands)
      09-26-2012, 07:46 PM   #104
Scootah
Scootah's Avatar
Australia
27
Drives: F80 M3CP
[QUOTE=DR-JEKL;12745248]I actually don't mind the lip, but I'm sure you will agree the m bar with the big open air ducts look a lot tougher!
I agree the M tech bars look tougher , but i decided to spend my money on performance upgrades rather than asthetics, though with the latest purchases i think ive now got that fully covered ( exc meth)
Anyway im sure you would agree the e92 looks great in anyform anyway
      09-26-2012, 07:49 PM   #105
pavo335
pavo335's Avatar
69
Drives: 3.5 wheeler
yeh but i think the lip on the non msport bar looks pretty good as well. not much in it imho
      09-26-2012, 09:32 PM   #106
DR-JEKL
Australia
900
What I really really want is this 1M custom style bar!
      09-26-2012, 09:36 PM   #107
pavo335
pavo335's Avatar
69
Drives: 3.5 wheeler
do it !!!!!!
      09-27-2012, 12:31 AM   #108
BMJ
BMJ's Avatar
52
Drives: 335
Mtec looks F%@king great! Well done Jekl
      09-27-2012, 03:33 AM   #109
DR-JEKL
Australia
900
do it !!!!!!
Hmm I would love to, I believe they are a custom order and are $2k a piece. You also have to take your car in to have the bar moulded to suit your car, and since they are based in the usa it would be near impossible....
Remember that outfit cyber in the early 90's, I reckon they could craft something like this up!
      09-27-2012, 03:41 AM   #110
DR-JEKL
Australia
900
Well I done the 'golf tee' mod this sarvo and yup it makes an immediate different under normal 1st gear acceleration it 'wails' and under deceleration there is now a lot more crackle n pop action happening!
http://www.e90post.com/forums/showthread.php?t=80661
It's hard to imagine the N54 sounding much better then it already is now, I ran out of sunlight to stick my head under the car to confirm if I have the BMW PE already (I cant believe the oem mufflers sound this good!)
I really cannot justify a PE costing $1-3k, and especially when the akra has a dyno chart like this:
[img]http://www.**********s.com/images/Products/akropovic/akrapovic-e9x-335i-exhaust-dyno-1.jpg[/img]
For the HP gains made a $100 DCI kit would produce similar gains I'm sure, providing much greater BFYB!
A few small mods arrived in the mail today that I might get around to installing this long w/e!
Foliatec top strip windscreen visor:
http://www.foliatec.com/foliatec/sho...425&groupId=74
BMS clutch stop:
http://www.burgertuning.com/clutch_stop_BMW.html
