aftermarket speaker slightly hitting the window
12-04-2023, 10:05 AM | #1 |
150
Rep 307
Hello, I was wondering if you guys could help me with a problem I'm having. I have an E92 HiFi system, and I bought an aftermarket speaker for my front doors – the Alpine S2-240C. While I managed to mount them properly, the window slightly touches the back of the speaker. The window does roll up and down, but you can see that the window pushes the speakers a little bit out. Is there any way I could create more clearance?
01-18-2024, 02:53 AM | #3 |
87
Rep 236
Drives: e92 335iA
I had the same issue with Eton 2 compo speakers, had to trim a bit of the plastic doorboard speaker surroundings/mounting plate to move it away/more inboard from the sliding window... also make sure that the foam water barrier is not torn... and sound deaden the door skin and doorboard... and the area under the tweeters location, surprisingly a lot of NVH/aero is coming through there...
"If everything seems under control, you're not going fast enough.” Mario Andretti
TiAgAu150.00 |
