08-17-2020, 04:45 PM | #1 |
Supreme Allied Commander
3868
Rep 54,426
Drives: F80 M3
Stoptech Stainless Steel Brake Line Kit 135i 335i
Stainless Steel Brake Lines for 135i 335i
SportStop stainless steel brake lines improve pedal feel and reduce the amount of time between applied pedal pressure and actual deceleration by preventing expansion, which stock rubber flex lines allow. This provides a quicker pedal response, and allows the driver to maintain consistent brake pressure and precision brake modulation. SportStop brake lines consist of a TeflonŽ inner line that is covered with a layer of stainless steel woven braid. The Teflon tube is very resistant to expansion under pressure and will not degrade from exposure to brake fluid. The stainless steel braid provides support for the Teflon and the weave is extremely durable against incidental impact and abrasion. SportStop brake lines feature a Clear Abrasion Resistant Cover for maximum protection against chaffing. BMW E82 135i and E9X 335i ***Front kit contains 2 lines and rear kit contains 4 lines, for a total of 6 lines*** Order front lines here: https://www.hpashop.com/products/sto...fe6004b6&_ss=r Order rear lines here: https://www.hpashop.com/products/sto...fe6004b6&_ss=r Last edited by HP Autosport; 10-20-2023 at 06:57 PM.. |
