Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Upgrading my wheels... ???HELP???
      06-30-2014, 11:15 PM   #1
Blackjack2008
Admiral Halsey
Drives: 2008-328i
Exclamation Upgrading my wheels... ???HELP???
I am going to put lorenzo WL27 staggerd rims on my 2008 328i...
new tire sizes will be...
275/30/19
and
245/35/19
what set up will i need as far as spacers go? if any
original set is
205/55/16
buying tires soon... PLEASE HELP!
      06-30-2014, 11:50 PM   #2
MonacoBlueE90
MonacoBlueE90's Avatar
Finland
163
Drives: BMW E90 320D Half-LCI
You need to tell the wheel widths and offsets?
      07-01-2014, 12:01 AM   #3
Blackjack2008
Admiral Halsey
Drives: 2008-328i
Front is 19×9 os 32mm
Rear is 19x9.5 os is 32mm
      07-01-2014, 12:07 AM   #4
Blackjack2008
Admiral Halsey
Drives: 2008-328i
I have choices on the rear. Could also be
19x9.5 os 40mm
      07-01-2014, 12:20 AM   #5
dbjb
I sweat pheromones
dbjb's Avatar
203
Drives: e92 335i, retired SLK55
e90 or e92? will you roll fenders?
      07-01-2014, 12:42 AM   #6
MonacoBlueE90
Finland
163
19x9.5 os 40mm
Et32 to rear is better choice. With those tyre sizes i don't think you can add spacers to rear. At least not without fender roll and if you can 10mm is the max, but you most likely still have rubbing issues with 10mm spacer and 275/30/19 rear even if the fenders are rolled. You could try 5mm spacer.
This is how the 19x9.5 et32 will look http://www.e90post.com/forums/showpo...&postcount=134 This has 265/30/19 but tyres are Michelins which are closer to 275/30/19 at true width.
Front wont need spacers. Front will extend 6mm compared to that above. This basically applies to E92. Just realized that you could al so have E90 pre-lci which has little bit more room at rear.
      07-01-2014, 06:32 AM   #7
Blackjack2008
Admiral Halsey
Drives: 2008-328i
Vehicle is an E90
Fenders wont be rolled... will go with the et32 front and rear...
Will I need spacers for either front or rear with et32?
Car isnt lowered...
      07-01-2014, 07:50 AM   #8
MonacoBlueE90
Finland
163
Vehicle is an E90
Car isnt lowered...
Ok. 5mm spacer could work at rear without fender roll. Anything bigger and rubbing most likely will happen. Since you are not going to lower the car don't see the need for spacers.
This is how the the rear would look on E90. Except it's lowered and 265/30/19 tyre. http://www.e90post.com/forums/showthread.php?t=165963
Here is the same car with 19x9.5 et32, tyre 265/30/19 and 10mm spacer test fit. http://www.e90post.com/forums/showthread.php?t=283535
Front wont need spacers. Here is how the front looks except this one is also lowered http://www.e90post.com/forums/showpo...27&postcount=1
      07-01-2014, 02:25 PM   #9
Blackjack2008
Admiral Halsey
Drives: 2008-328i
What would be the best tire sizes for the rims?
The plan is
245.35.19 x2
275.30.19 x2
Please advise!
Ty
      07-02-2014, 12:11 AM   #10
MonacoBlueE90
Finland
163
The plan is
245.35.19 x2
275.30.19 x2
Please advise!
Ty
Hey are you sure that the front is 19x9 et32 i mean i can't find it from the spec list http://www.lorenzowheels.com/wheels/WL27/WL0272 Only 19x8 et32
      07-02-2014, 09:42 PM   #11
Blackjack2008
Admiral Halsey
Drives: 2008-328i
im mistaken, the front is 19x8
sorry about that...
-FLY FRIENDLY-
Johnny Bell
      07-02-2014, 11:51 PM   #12
MonacoBlueE90
Finland
163
sorry about that...
Well it doesn't change much. Except it isn't as flush at front as i was saying before. It's basically at same point as stock wheel. You could maybe add 5-10mm spacer. This one has 19x8.5 et35 which will extend 3mm more than the 19x8 et32 http://www.e90post.com/forums/showpo...5&postcount=93
Change the front tyre to 235/35/19 it fits better to 8 inch wide wheel and 275/30/19 rear.
lorenzo, rims, tires, wheels
