Free Europe 2013 Premium Dvd's For Cic Nav
01-18-2013, 08:21 AM | #45 |
has left the building
90
Rep 3,359
01-24-2013, 11:28 AM | #49 |
Rep 405
by the time it cycles to all the members who has asked for it 2014 map will come out.
650i F12 - HUD, 6WA, SLI, Logic 7, Dynamic and Adaptive Drive, Comfort Access, Soft-close, top-view,
Previous X5 40d M Sports and 535d LCI |
02-02-2013, 07:27 AM | #50 |
Rep 425
I received the DVD's today. I will advised when I have completed the update of my CIC system; and post onto the next person.
BMW E93 Sold but not forgotten.
02-03-2013, 01:22 PM | #51 |
Rep 30
Brilliant Idea!
I appreciate that I might be waiting a long while, but I'd like to put myself on the waiting list for these discs please. Thank you Matt for suggesting this.
Cheers, Richard p.s. I'll keep an eye on the thread, but please PM me when it gets around to my turn. I'll of course, post straight on to the next member. |
02-04-2013, 05:25 PM | #52 | |
Rep 425
I have finish with the upgrade discs; I will send you a PM shortly. Everyone, please note that these are copies and the not the original DVD's as originally thought. I had a little problem with the first disc keep freezing around 17.5%, but a good clean solved that.
02-04-2013, 05:34 PM | #53 |
Rep 425
P.S. If you have issues getting hold of Sierra5 to obtain the FSC code; you can use this seller:
http://www.ebay.co.uk/itm/1609616297...84.m1497.l2649 I got the code from him with about 30 mins. Regards,
02-04-2013, 06:00 PM | #54 |
Rep 30
That was fast!
Thank you cage911! PM Received. I'll do my best to get the discs back out the same day that I receive them.
Many thanks, Richard |
02-04-2013, 06:09 PM | #55 |
Rep 425
Not sure if any else is waiting, so don't rush.
02-12-2013, 04:28 PM | #58 |
Rep 30
Done!
Hi folks,
Ok, all done and installed, but it took a while... If you've researched the installation process, then you'll know that you really need to keep the engine running, otherwise the ignition switches itself off after about 20 min, which stops/pauses the installation (there are ways around this, but you'll need a garage spec' battery charger). When I received the discs, cage 911 kindly explained that if the ignition switches itself off or if you switch the ignition off then you'll have to insert the previous discs again until it catches up with itself - e.g. if you're part way through disc 3 in the installation and switch off the ignition, then next time it starts, you'll have to insert disc 1 again for a minute, then disc 2 again for a minute and then back to where you left off with disc 3. It's a bit of an arse, but it does work. The whole process takes about 2 to 2.5 hours, but my commute is about 30 min, so it took a while and I couldn't be arsed to sit there with the engine running, not at today's fuel prices... I'm not 100% sure who is next in the list, so what I suggest is that of all the people who have specified an interest in the thread, the first one to PM me with their contact details will get the discs next. I'll post back here to confirm. Cheers, Richard |
02-21-2013, 02:31 AM | #61 |
Rep 27
02-21-2013, 02:45 AM | #62 |
Rep 13,043
Drives: BMW M340I G20
This update can take nearly 3 hours. It might depend on how much new info needs installing. The problem is unless you have a 3 hour journey your BMW won't stay powered up and like me you might have to go out to the car every 15 minutes and press the power button (no need to start the car)
If anyone knows a way of keeping BM's powered up I'd like to know. |
02-25-2013, 02:07 PM | #63 |
Rep 27
Help please
Hi guys any help with the disks please? I can't get hold of who has them and I can't download either. Dealers won't sell without a code so I think I've got no choice unless anyone else can help?
Thanks guys |
02-25-2013, 02:43 PM | #64 |
Rep 86
I have them currently, should be done with them at the end of the week Gouni if you msg me your location i can post them to you - alternatively as you're in london i work in central if you're around at some point during the week i can just hand them over.
02-25-2013, 04:01 PM | #65 | |
Rep 27
02-25-2013, 07:39 PM | #66 |
Bimmaaaa
23
Rep 635
Drives: E46 M3
I would like to be placed on the waiting list.
I'm from West London area, and can rotate discs within a day or two.
InstaGram: Ajerthan |
