09-29-2016, 05:00 AM | #23 |
Rep 655
know your body type, know your hormone levels, understand your electrolyte managements, count your caloric intake.
theres so much to physique training and body sculpting its crazy be realistic with your goals and understand why you have limitations. |
09-29-2016, 05:01 AM | #24 | |
Rep 435
Drives: 2017 BMW M4CP SO
09-29-2016, 05:06 AM | #26 |
Rep 655
know what foods to eat to promote what you want
white button mushrooms boost free testosterone naturally, this creates more atp which fuels the body. for example |
09-29-2016, 08:56 AM | #27 | |
Rep 3,554
to your 2nd point, Im pretty sure everyone has told him to watch what he is eating and to track his intake. The thing is, to cut quickly and efficiently, you need to either severly restrict your intake, which leads to less energy and muscle loss, or use a workout regimen that puts you into a calorie deficit, while still getting the fuel to keep your muscle and strength up. I know you are going to argue with me on this that all he needs to do is go Keto; thats your answer for everything, but trust me on this. Ive been going though cutting and bulking cycles for over a decade now. This isnt a "I want to lose 10 lbs, how should i do it?" this is a "I want to get cut, how should i do it?". There is a difference. |
09-29-2016, 09:24 AM | #28 | |
Rep 435
You're wrong about calorie restriction leading to less energy and muscle loss. It really depends how you do it. If you run on carbs, yes you will suffer if you restrict them. If you run on fat, you won't because you have so much of it stored around your body. High fat diet tends to preserve protein, so you will not lose muscle, even at a calorie deficit. You need to keep lifting, but the muscle loss from inactivity is much slower than most people think. It will happen much quicker through catabolism because of dieting on a carb rich diet. I'm not saying he needs keto, I'm just saying it's the most efficient way. I can't trust you, because I've been going through this twice as long as you did and I know the science, where you don't. I used to bulk up and cut the old school way, and I got a lot leaner a lot quicker after attempting the same with keto. There is a difference, true. But the difference is between ignorance and knowledge. |
09-29-2016, 09:48 AM | #29 | |
Rep 3,554
We get it. Keto is the only way to do anything... |
09-29-2016, 10:27 AM | #30 |
Rep 435
09-29-2016, 01:53 PM | #31 |
Rep 3,554
09-29-2016, 05:30 PM | #34 |
Rep 435
09-29-2016, 05:39 PM | #36 |
Rep 655
do you know what catabolism is? do you understand if youre not anabolic while cutting that you ARE burning muscle for fuel
so yeah too much cardio can be a bad thing. and to the OP if your hormone profile sucks you will stay a pudgy man. period no ifs and or buts about it! |
csu872134.00 |
09-30-2016, 07:15 AM | #39 |
Rep 6,088
Update guys...
Instead of just running at 7-8 mph for 10 mins, I've started an HIIT routine and definitely feel a difference after my workout. I'll full on sprint for a minute, then speed walk for a minute, and keep doing that for like 5-6 cycles. I lift before Cardio but don't do as many sets...maybe 2-3 instead of 3-4. My workout doesn't take any longer, but boy is it more intense. Also stopped eating plain oatmeal (w/ water) as my 5 p.m. snack as oats are filled w/ carbs and spike insulin. That was probably my most unhealthy snack of the day, as otherwise I just have protein shakes, protein bars, greek yogurt, and fruits. Switched over to a slice of Ezekiel bread w/ 1/2 an Avocado instead of the oats. This bread has a very low glycemic index compared to normal organic wheat bread. I'll report how I feel in a few days. Thanks again for the suggestions. Last edited by Germanauto; 09-30-2016 at 07:30 AM.. |
09-30-2016, 07:29 AM | #40 | |
Rep 655
09-30-2016, 09:11 AM | #41 | |
Rep 3,554
HIIT is definitely a good way to burn fat and keep up explosiveness for your cardio program. What is your lifting program? Did you increase weight while decreasing reps/sets? |
09-30-2016, 10:24 AM | #42 | |
Rep 435
09-30-2016, 10:50 AM | #44 |
Rep 3,554
All depends on how his body reacts to exercise. Keep in mind he is running AFTER he is lifting, which means he is already burning calories. This is just the icing on the cake to burn even more. Intense, shorter duration workout > low intensity, long duration workout.
