09-26-2023, 06:41 PM | #1 |
Rep 658
How to avoid windshield fog?
I was driving on the highway when my windshield fogged up. I pressed the Max button but it made it even more foggy for a good 20 seconds until it cleared up. I had to put my hazards on and slow the hell down.
Only time I ever have these issues was any bmw I ever had |
09-26-2023, 07:00 PM | #2 |
Primo Generalissimo
4675
Rep 4,027
Drives: All of them
Garage List 2017 Porsche 911 Ca ... [10.00]
2023 BMW M2 [9.00] 2023 Porsche Macan GTS [10.00] 2022 Ford F-250 Tremor [8.50] |
Windshields fog up easier whenever the inside of the windshield is not clean. You probably have offgassing VOCs on the glass you are not aware of. I’d simply clean it up and it should alleviate the issue to some extent, but that’s also why you have a defogger.
09-26-2023, 07:11 PM | #3 |
Rep 658
Yeah but the defogger fogs it more for 20 seconds until it slowly defogs and was a bir dangerous today hah
09-26-2023, 07:19 PM | #4 |
Primo Generalissimo
4675
Rep 4,027
Drives: All of them
09-26-2023, 08:59 PM | #5 |
sportscars only
3272
Rep 3,206
Are you vented to outside (good) and not recirculate? Also, weather-permitting, you may be 'forced' to switch on the AC.
The richest one percent of this country owns half our country's wealth, five trillion dollars. One third of that comes from hard work, two thirds comes from inheritance, interest on interest accumulating to widows and idiot sons and what I do, stock and real estate speculation...It's bullsh*t. I create nothing. I own. We make the rules, pal...Now you're not naive enough to think we're living in a democracy, are you buddy?
09-26-2023, 09:33 PM | #6 |
Rep 569
In my experience, when that happens, turn to windshield mode and turn up the heat! It’ll evaporate the moisture on the windshield. Then, give the inside of the glass a thorough cleaning, every few weeks, and you should be good.
I have a ‘windshield wow’ that allows me to clean both the exterior and interior of the windshield at the same time. Helps a bunch. |
09-27-2023, 10:53 AM | #7 | |
Rep 3,585
I find that hitting defrost in either of my cars (both BMW) takes care of any fogging very quickly, just a couple seconds. I can't think of a case where it's been made worse. |
09-27-2023, 11:22 AM | #8 | |
Rep 15,858
Were you already running AC for dehumidifying, before it fogged with MAX? If not, there is your answer... |
09-27-2023, 02:16 PM | #9 | |
sportscars only
3272
Rep 3,206
09-27-2023, 07:47 PM | #10 |
Rep 658
09-27-2023, 08:51 PM | #11 |
Rep 6,292
Drives: 2018 340i M Sport
Garage List 2018 BMW 340i M Sport [8.58]
2020 BMW M340i xDrive [9.00] 2018 BMW 340i M Sport [7.38] 2006 BMW 330i Sport [5.83] 2004 BMW 330i ZHP [7.13] 2000 BMW 328i [6.17] |
Did you have the climate system set to recirculate? Lots of folks these days use recirculate all the time. If you have the system on recirculate you MUST use the a/c to dry out the air. In the “old days” before all of the automatic hvac systems people kept the system set to fresh air. If you use fresh air in the winter or wet weather you will not get foggy windows. Setting the system to Defrost will automatically engage the a/c to dry out the air.
www.bmwcca.org member #388003 - Use me as a referral & you could win a one day ///M Driving School!! ___________________________________________ |
Westside Guy5812.50 |
09-29-2023, 01:52 PM | #12 |
109
Rep 296
Drives: 2016 340i X Drive
If my windows are closed I keep the a/c on with recirculation off. The windows will not fog up with these settings.
10-01-2023, 10:02 AM | #14 | |
Rep 15,858
But we do heat the cabin in the process. Using Climate Control with AC running in the background, no fogging at any time. Plus no heat or cold disturbances, due to having to manually intervene or interfere. |
10-01-2023, 12:07 PM | #15 | |
Rep 6,292
Mavus2037.00 |
10-01-2023, 06:14 PM | #16 | |
2037
Rep 2,677
10-02-2023, 03:28 AM | #17 |
Rep 15,858
10-04-2023, 11:59 AM | #18 | |
2037
Rep 2,677
Another thing that happens is you could be driving from one area to another, such as valleys and hills, with changing microclimate unique to that area where conditions change within minutes. As an example Watkins Glen has its own unique microclimate. The point is that when dealing with humidity in the cabin the quickest way to defog is to ensure warm air is blasting for a few mins and in my case I do that manually and it works every time. HVAC auto often blows cold air even if I increase temp setting. |
10-04-2023, 12:40 PM | #19 |
Rep 14,121
Drives: G82 M4C X-Drive
Air Conditioning on along with some heat will dehumidify faster than just heat. The act of conditioning air removes moisture from it. This is why in california winters above 40°C, I still run the AC, but combined with the heater.
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
10-04-2023, 01:50 PM | #21 | |
Rep 15,858
In similar start situations, which I also encounter here in the Highlands, I simply hit the demist button and leave auto settings alone. Same as I will hit the MAX button for a short time in heat, while leaving other settings alone. As to microclimates, I see that all the time here in the Scottish Highlands, massive changes in temperature and humidity during the same trips. HVAC runs in the background with no issues at all. Are you sure something isn't wrong, if auto settings (with AC running), can't prevent fogging and misting without intervention? I had a VW Passat which would mist in some damp conditions. Car would also mist so easily, when stood over night. Problem was identified as water ingress, into the HVAC system. That solved, no further issues. |
10-04-2023, 04:08 PM | #22 | |
Rep 6,292
With automatic hvac systems these days the system determines whether the air conditioner is on and it determines whether the air is set to fresh or recirculate. It chooses recirculate the majority of the time and as a result the air conditioner is also necessary. I only set my system to recirculate when the interior of the car is very hot and I turn on the air conditioning in order to cool the interior air more quickly. This also happens when you choose the Max cooling setting when the car is hot. The Max setting automatically sets the air to recirculate. With so many folks just using the automatic system these days not many people understand the significance of the recirculate setting anymore.
